Pc-game Dark Side Of The Moon
Reply 40 of 66, by Nicht Sehr Gut
dud716 wrote:
...I see that there are several GE Force Ti200 cards out there, how do I determine which card to buy?
Basically, if it says it's a GeForce3, then it's a GeForce3 Ti200. Anything beyond that will be given an extra "ID" like "Ti 500" or some other "deluxe" type ID. Just stay away from MX boards.
Reply 41 of 66, by Snover
No, if it says it's a GeForce3, then it's a GeForce3. A Ti200 is an underclocked GeForce3, and a Ti500 is an overclocked GeForce3.
Yes, it’s my fault.
Reply 42 of 66, by Nicht Sehr Gut
Ok, I was basing this on the common availability of the Ti200 and yet most of the boxes I've seen don't specify Ti200 on them. Of course, I haven't been specifically looking for a video card for some time now. Of course, if you find a standard GF3 or GF3 Ti500 for $50, I'd grab that (except of course, that's kind of unlikely).
Reply 43 of 66, by dud716
Snover wrote:
The dangers of static electricity are HIGHLY overrated. Just be sure to touch your power supply (while it's still plugged in, but TURNED OFF) to ground yourself to prevent shock.
One thing I missed, Do I unplug the power cord while I'm swapping the cards? I was under the impression that leaving the power cord plugged-in would cause some components to still remain 'hot', am I correct?
Reply 44 of 66, by dud716
Nicht Sehr Gut wrote:
Of course, if you find a standard GF3 or GF3 Ti500 for , I'd grab that (except of course, that's kind of unlikely).
I'm becoming confused now, GF3 Ti200 vs. GF3Ti500. What gives? Is this just a matter of price? thanks, dud p.s. What is an MX board?
Reply 45 of 66, by Snover
Yes. Remove the cord AFTER you've grounded yourself but BEFORE you start pulling and adding components. (BTW, if you've got a switch on the power supply (not the computer's power switch!) you can just use that instead of messing with plugging and unplugging cords.)
The MX line of cards are cheap stripped-down cards with none of the functionality of the GF3. (Pixel programmers, etc.) DON'T BUY THEM.
GeForce3 Ti200 is the "budget line". Costs less than the regular GeForce3 for a moderate decrease in performance.
GeForce3 is the regular card. "The original."
GeForce3 Ti500 is the "performance line". Costs more than the regular GeForce3 for a moderate increase in performance.
Yes, it’s my fault.
Reply 46 of 66, by dud716
Colin, I updated my profile, take a peak, if you will. I'm still trying to find a Ti 200 card around here. Can you name a source and/or a part number? thanks, dud
Reply 47 of 66, by Nicht Sehr Gut
They're everywhere, seriously. Just look for GeForce3 and a cheap price (less than $100). I went to Google (which went to bizrate.com) and searched for "price GeForce 3". Found Ti200's for as low as $59, saw a Ti500 for $87 (you can ignore the one Xtasy 6964 with the price glitch, I can assure that $3281.53 is NOT the correct price. Heh).
BTW, did you try the "homemade" XP drivers for your Voodoo? Since your card already has 16 Megs, it might allow you to try out realMYST now. If you don't like the way they perform, you can always do a driver rollback.
Reply 48 of 66, by dud716
Nicht....I did not attempt to use the drivers that you sent me, not yey anyhow. How do I install them? do I have to uninstall the current drivers? How? In order to install the "new drivers" from the site, I must first download, then install. However, I'm not sure how to uninstall the 'existing' drivers. Second, If this fix doesn't work, how do I do a 'driver rollback'? thanks, dud... gobble, gobble..
Reply 49 of 66, by Nicht Sehr Gut
dud716 wrote:
Nicht....I did not attempt to use the drivers that you sent me,...
Err...I presume you mean the driver links I provided, as I didn't send you any drivers.
Either by a setup program (or script) that comes with the drivers or by going to the Device Manager, finding the entry for your video card and choosing "update Driver".
IOW, Go to Start menu,
Start-->Control Panel-->System-->Hardware (tab)-->Device Manager-->Display Adapters-->Your Video card-->Driver (tab)-->Update Driver then point that at the (unzipped) driver files (Install from a specific location).
While you're there, notice the "Roll Back Driver" button. That's what you click if you change your mind (it automatically goes back to your previous video driver).
If for some reason you can't seen your display afterwards, you can reboot and hit the F8 key at startup and choose "safe mode". Then proceed to "roll back" the driver, then shutdown and restart.
No.
Reply 50 of 66, by dud716
Nicht,...I went to voodoo files.com and downlaoded the following:
3dhq Voodoo3 Windows 2000/XP drivers 1.09 Beta 7
The latest, best drivers for Voodoo 3 cards under Windows 2000 or XP.
OS: Windows 2000/XP
These are the steps that I followed:
1.) Uninstall realMYST.
2.) disable anti-virus.
3.) install "new" drivers from "voodoo files"
(....3dhq 1.09 Beta 7)
4.) shut down, and reboot.
5.) reinstall realMYST.
6.) attempt to open the game......nothing happens.
7.) I even tried changing the compatibility, again nothing happens.
Because of time constraints, (it's f#$@ 'n turkey day), I have'nt been able to try the drivers from the "other" site. I have a question, ....are the drivers from the two sites identical? If not, perhaps I should try the drivers from the other site. I'll give them a try when I get the chance. Any ideas?
.......P.S. from what you have found, should my Voodoo 3 AGP card work for realMYST, and other 3D games as well? .....thanks, dud
Reply 51 of 66, by Nicht Sehr Gut
Well, uninstalling the game shouldn't be necessary, but disabling the antivirus during an install is a good idea.
Is this the full game or the playable demo? I know the demo had a separate configuration program that you need to run before running the game (realMYSTSetup.exe)
Because of time constraints, (it's f#$@ 'n turkey day),..
Just be thankful it's not "Living Under the Scourge of a Maniacal Dictatorship Day".
Other than trying them out, that's hard to tell. All 3D drivers for XP are "homemade", so there's no certainty about any of them.
...should my Voodoo 3 AGP card work for realMYST, and other 3D games as well?
Should work for most titles that need a Glide/D3D/OpenGL card with 16Megs of memory or less (presuming they don't require specific hardware <like Hardware Transform-and-Lighting> or Direct-X 8 specific features).
Reply 52 of 66, by dud716
Nicht,......thanks for the info...I'm away from my computer, so I'll need a few days...I'll try installing the drivers from the other site when I get back in town.
The game is entitled: REAL MYST (The Ultimate Director's Cut, in Realtime 3D.) It is the full game. ...and it cost me $4.50 + tax at Staples.
Reply 53 of 66, by Snover
"The Ultimate Director's Cut" is not a part of the game's name. (Just a little FYI.)
Yes, it’s my fault.
Reply 54 of 66, by dud716
Colin, do you have anything to add to the capabilities of the video card and/or the drivers suggested by Nicht? Might I just upgrade to another card anyhow? thanks, dud
Reply 55 of 66, by Stiletto
Stiletto wrote:
I have realMYST Test (Different from the demo?) and it will happily play on my shit-ass computer (see profile) using Glide under Win98SE. Sure, it's at 800x600@16bit, but it works - at maybe 30 fps. 😉
I even have a screenshot around here to prove it. I forget where... on my hard drive at home, I think... I'll get it later...
realMYST Test
Version 1.2 for 95 / 98 / 2000 / ME
Settings:
3D Hardware - Glide
3dfx Interactive [Glide]
Screen Resolution - 800x600 16 bit
Texture Quality - Medium
Mouse Options - Default
Movement Options - Default
DirectSound3D - Enabled
do the Fandango!" - Queen
Stiletto
Reply 56 of 66, by dud716
Well Nicht, I tried the 'homemade' drivers that you suggested, and I still experienced the same problem. 'No suitable rendering device found'
I guess I'm SOL, that, or get a new card. thanks, dud
Reply 57 of 66, by Nicht Sehr Gut
Sorry to hear that. It was worth a try.
Reply 58 of 66, by dud716
Nicht, Snover, et al, Happy Holidays!
I just came back from a computer show and sale, in search of a cheap (inexpensive Ge Force 3 Ti 200 card. I thought for sure that I would find one, but alas, everybody is now selling Ge Force 4 cards, and they are mostly all MX cards to boot!
I've got a few tricks left, after that, I'll go online and see if I can find one for cheap.
I'll keep in touch, 'til then, have a Happy New Year!
thanks, dud
Reply 59 of 66, by Snover
Don't bother. Seriously. Save your money and wait for a GeForce FX. It'll be worth it. 😀
Even if you don't want to wait, I wouldn't get a Ti200. Get a regular GeForce3.
Oh, and a note on the DVD of DSOM: I believe that it was poorly mastered, in that both drives I've run it on (that were on processors slow enough to handle the game) have had trouble playing video and switching between videos smoothly, whereas the CD-ROMs did not manifest this problem.
Yes, it’s my fault.
