Reply 40 of 49, by theelf
- Oldbie
ripsaw8080 wrote on 2024-07-10, 15:58:The attached loader program modifies the game in memory to have Roland music with SB speech/sfx. There are no Roland sfx when us […]
The attached loader program modifies the game in memory to have Roland music with SB speech/sfx. There are no Roland sfx when using SB speech/sfx because it is one or the other with those drivers; however, I think it works well with the MT-32 because there is less need for the extra sounds of the CM-series.
The program has a no-CD feature that allows the game to be run entirely from HDD, and it's probably easiest to just put it where the config and save files are stored.
AFAIK, all CD-ROM releases are supported -- version 0.0368 (Europe, UK, Germany) and version 0.0372 (US, Taiwan) -- the freeware release is version 0.0368
Note that speech + text can be selected from the in-game options (F5 key)
Example running from an HDD directory with all files from the CD copied to it:
SKYDRV CFG=.Example running from the CD:
D:
C:\SKY\SKYDRV CFG=C:\SKYKeep in mind that the loader program executes SKY.EXE in the current directory when trying other arrangements. The CFG= parameter specifies the directory where the config file and save files go -- \STEELSKY is the default if not specified.
Update: The loader program now uses the hardware configuration rather than always relying on the game's auto-detection. The "Port Addresses" in INSTALL.EXE all default to auto-detection, so if SB sound is not working on your system then select port, IRQ, DMA and "Save Setup".
Hello, I know this is an old post, but I want to run your patch on my 486. I have an AWE64 + MT-32. When I run the game normally, I get music and FX through the MT-32 without problems, or music + FX + voices through the AWE64. But with your patch I can get sound FX with SB, but no music with MT-32
One thing I notice is that when i load SKY with your patch, my MT32 get crazy, the screen show strange and random things, and i need to turn off/on to have sound again in another game. Funny thing i tested with a MT32-Pi and same thing happen! no sound in another game only when turn off PC, and the screen show random stuff too
Any ideas?
I get this error in the game, i dont know is relevant? maybe not
It’s in Spanish: the first screenshot says MISSING TEXT OR GRAPHICS, and in the second screenshot it says BUY A HARD DRIVE, NOW.
Thanks!
