Reply 40 of 43, by shock__
- Oldbie
Just as a small update, I managed to repair the 3.3V generation and my DX4 is now working on that board without any workarounds.
Current Project: new GUS PnP compatible soundcard
[Z?]
[Z?]
I was going through my spare systems the other day (stuff I bought and haven't touched yet) and found that I had yet another v1.7 board. To top it off, it came with a an IBM - Cyrix 5x86 100.
Just finished pulling it out of the case because the case it was in is an old Everex Step 286 case that is going top be my 286 build.
Anyway, it has the 12-01-1995 BIOS on it AND it is working with Write-Back L1 cache set. Going to try the POD83 and see if WB cache is working with it as well.
This 1.7 board is different in that it just has a white serial number sticker instead of the golden date/serial number sticker on the last ISA slot.
WB is still not working on the POD83 according to the cpuchk program. Tried a bunch of different jumper settings as well since I thought maybe there was a jumper combo that changes between at and wb like on some board but it didn't help.
Will try AMD 5x86 another time to see if WB works on them.
Out of the context but I would like to ask something, just bought one with 8MB of FPRAM. But I dont have any more FPM. I have EDO modules. Can I use EDO RAM on this board?
System:1
Cyrix 5x86-100GP
Lucky Star LS-486E
System:2
AMD K6-2-475(Changing frequently with Cyrix 6x86MX PR-233)
Asus P5A-B
System:3
UMC U5S-40
486UL-P101
System:4
P3 Coppermine 800EB
Gigabyte GA-6BX7
