Little update,
added a USB 80mm fan to the heat sink, heat was building up on a long shift (Probably more my paranoia @ 65 Deg c), will run PCSX2 @ 49-60 FPS depending on pal or ntsc, keeps below 45 deg c,
Must have been really throttling back before with the knackered heat pipe. barely 20 fps before with a lot of stuttering (video and Sound).
Added a GTX 660 eGPU. given it a few stability issues, working through them. Total system wattage around 200w inc. monitor
all in all positive out come.
Bottleneck cleared -74mhz from the gpu core.
just a note, these can't boot from NVME drives, but with an PCIe adaptor is possible to access as a secondary drive with the Lenovo NVMe Driver in Windows 7 64bit
Windows emulation seems non existent on this version of Embedded windows 7 Pro,
Glass of Linux WINE anyone??
I Like Charity Shops, they're like steam and GOG but cheaper.
Windows 98se - Wyse V10LE 1.2Ghz, 1 Gb, 16Gb SSD
Windows 98se - Compaq Evo 550d SSF, P4 2Ghz, 1Gb, 60Gb(Partitioned)
Dos 6.2 - HP7510 512Mb, 4Gb
