Slotket Tualatin mod journey
Reply 40 of 49, by PARKE
PcBytes wrote on 2022-06-02, 14:15:
PARKE wrote on 2022-06-02, 13:37:
It was just meant as illustration for flaws in early boards, not as a 1 on 1 comparison. What type of frequency generator is your Soyo accomodated with ?
Cypress W40S01-04 clockgen, ITE 8671 SuperIO.
According to the datasheet that is a ram buffer chip with 48 legs.
On the online photos of the board the frequency generator has 28 legs - located on the right of the upper pci sot.
Reply 41 of 49, by PcBytes
My bad.
The clockgen is still a Cypress though, model W196G.
Reply 42 of 49, by filurkatten
Did some quick tests just to compare cpus.
Ran 3DMark2001 and Quake III.
My old 850MHz 100fsb P3 got the results, 6280 and 74.5fps.
Then I ran the tualatin 1133MHz 133fsb at 100fsb so it was clocked just under 850MHz, the result where 6927 and 90fps.
Thats quite the increase!
Thought that was knterestind, so the cache does matter atleast for 3D mark and Quake.
Reply 43 of 49, by PARKE
Nice!
Found a more involved piece of info on comparison between Tualatin with 256 and 512 cache here:
https://www.overclockers.com/a-case-study-on- … pu-performance/
There is a difference between Coppermine and Tualatin cache management that -may- explain (a small) part of the performance increase you notice - it is called data prefetch, you can google it.
Vogons member pshipkov found a difference between Coppermine vs Tualatin in Quake here:
Re: 3 (+3 more) retro battle stations
Reply 44 of 49, by filurkatten
Got my 1400MHz P3 tualatin so I ran 3DMark2001 and Quake III with it aswell.
Here are my results (C=Coppermine, T=Tualatin, P3=Pentium III, Ce=Celeron):
CPU                      3DMark2001   Quake III
C P3 850/100@100 6280 74
T P3 1133/133@100= 850 6927 90
T P3 1400/133@100=1050 7654 101.5
T P3 1400/133@112=1150 8339 115
T Ce 1200/100@100 7477 94.5
T Ce 1400/100@100 7922 100.8
I would say just from these two tests that the cache seems to be worth it, especially with Quake III.
If I can only overclock it a little bit it would outperform the Celeron 1400 in 3DMark2001.
Also it performs better then the Celeron 1200 even when its underclocked, if I can get a stable OC then I'll have the best CPU I could on this setup.
What would be the prefered stability test to run if/when I try to overclock it?
EDIT
Updated the list with a small OC, from 100fsb to 112fsb, seems to be running stable.
And yeah, it outperforms the Celeron at this point.
My setup is;
ABIT BX6 rev 2
384MB PC133 RAM
Geforce4 TI 4280
WinME
2 ISA sound cards
PCI sound card
network card.
HDD is a sata 120GB SSD with a generic adapter.
Reply 45 of 49, by filurkatten
Did some more OC, the furthest I can push this CPU seems to be 124fsb before I get disk read errors.
So thats where I left it, 1300MHz 124fsb.
Can post exact scores tomorrow but it was closer to 9000 in 3DMark01 if I remember correctly.
I tested stability by first running Prime95 for ~8h, then CPU Burn In i think it was called for ~8h.
No problems so I played Morrowind at stable 30fps highest rendering distance for a couple of hours, all seemed good! Before Morrowind played at a quarter of rendering distance at ~18fps so thats a great improvement in this game.
Im happy!
Reply 46 of 49, by filurkatten
Here are the score for the Tualatin 1.4;
T P3 1400/133@117=1200 8573 118
T P3 1400/133@124=1300 8927 124.2
Reply 47 of 49, by PARKE
Interesting.
How far can you overclock the Celeron 1400 ?
Reply 48 of 49, by filurkatten
Here are the Celeron 1.4GHz results:
T Ce 1400/100@112=1570 8564 113.5
T Ce 1400/100@117=1640 8834 115.5 Note: Was unstable at default voltages so I needed to bump it up by 0.5V EDIT; after playing games it still was unstable
That was as far as it went.
At 117fsb it was unstable at first, got a bunch of crashes and read errors but after increasing the voltage by 0.5V that went away.
When I tried to OC it further all I got was disk errors at startup, raising the voltage more didn't change that.
So even if the 1.4GHz Celeron is overclocked and the P3 Tualatin is underclocked it outperforms it.
If the Celeron would be stable at 124fsb I guess it would beat the P3 Tualatin but at least in this system that wasn't possible.
BTW, the CPUs are the models:
Celeron = SL64V
P3 =SL5XL
So my conclusion is that I'll be using the P3 in my system.
EDIT
I did these test and checked stability with Prime95 and CPU Burn In for 8h each but the Celeron at 117fsb with bumped up voltages that passed these test still became unstable when I was playing some Icewind Dale II today.
Was playing for about 2h and then I started to get dll errors, same errors I have seen with other failed OCs on this system, and then the system froze.
Reply 49 of 49, by PARKE
Well , you gathered useful information for future explorers. As already noted earlier in this thread it seems that the ABIT BX6 rev 2 motherboard is likely the weak link in this particular setup. If you ever get a more 'advanced' BX board you may succeed in running the 1.4Ghz Tualatin in its full glory.
