List of video card tech demos
Reply 40 of 77, by BEEN_Nath_58
nuninho wrote on 2023-10-04, 09:14:
Or check to click "EXE (327MB)*" for fast download - https://gpuopen.com/archived/radeon-hd-4800-s … eal-time-demos/ […]
BEEN_Nath_58 wrote on 2023-10-03, 19:29:
I have appended your post to my first post
If you shouldn't apologize me for your wrong name of demo (Dolphin), I get confusion, silly, angry and sad because I do NEVER say "Dolphin".
But no any solution for errors problem in log!???
My apologies 😔
But no there's no solution. It's not an error in your end. As said in one if the previous posts it's because of a feature AMD gives and Nvidia doesn't. You can compare it to trying a DLSS demo on AMD (you'll get an error)
Reply 41 of 77, by nuninho
BEEN_Nath_58 wrote on 2023-10-04, 09:23:
My apologies 😔
Yeah. 🙁 But it's possible we can run HD 4800 demo on NVIDIA videocard (but Fermi required) in future!
I can't run NV Design Garage demo since NVIDIA Kepler (eg: GeForce GTX 680) or newer NV card due to the crash at loading demo despite no error message 🙁 but my old GTX 480 and then my old GTX 580 yes. 😀
Current AMD Radeon RX (6000 and 7000) won't be able to run DLSS due to the CUDA or Optix API by... NVIDIA. We remember ATi-AMD Radeon cards do never work to enable PhysX acceleration (by CUDA). 😉
We hope likely fixed errors for NVIDIA card on HD 4800 demo in future... 😉
CPU: i7-12700KF
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 - NEW 😁
Opt. disc: LG BD-RE writer BH16NS40
HDD: SATA 1TB
SSDs: OCZ RD400 0.5TB+Crucial MX500 2TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 21" Sony E530 😁
Reply 42 of 77, by kurkosdr
nuninho wrote on 2023-10-04, 10:04:
Yeah. :( But it's possible we can run HD 4800 demo on NVIDIA videocard (but Fermi required) in future! […]
My apologies 😔
In order to end your confusion, it's important to understand there is a huge difference between games (which aim for broad compatibility with as many GPUs as possible to increase sales) and GPU vendor demos (which don't necessarily aim for broad compatibility).
Though keep in mind that some demos do aim for broad compatibiltiy. It's a case-by-case thing when it comes to demos really.
Common causes of why a demo won't run:
1) It checks for the presence of a specific graphics card.
For example, this is the case for the Matrox G400 demo, where it checked for the presence of a Matrox G400 otherwise it refused to run (although for this specific case you could bypass the check by adding "i_promise_i_will_go_buy_a_matrox_g400" at the end of the demo's cfg file, no I am not jocking). No game would ever do something this.
2) It requires custom API extensions that are only impelemented by the GPUs of a specific vendor.
For example, this is the case for the AMD demos that require AMD's custom API extensiosn for tessellation on top of Directx 10.1. Again, no game would ever do something like this. Even if a game uses the custom API extensions of some GPU vendor, it always provides a fallback for people who don't have a GPU from that vendor.
Also, it's highly unlikely NVIDIA will implement AMD's custom API extensions (like you hint in your post).
BTW Nvidia has had it's own custom API extensions that they dropped support for. Dawn demo requires them and won't run on modern NVIDIA GPUs (if i recall correctly). They might be doing something similar with the NV Garage demo. You can't know.
How to run demos:
1. Try to run them natively and see if they run. For older demos you can also try Windows compatibility mode.
2. For demos that don't require more than DirectX 9.0c, you can also try to run them with dgVoodoo2 (this also allows you to choose the name of the GPU)
3. If #1 or #2 doesn't work, try to fake the name in Windows (maybe someone can enlighten us on this). Obviously this won't help if the demo explicitly requires custom API extensions.
4. If none of the above work, there is no solution other than running it on original hardware. Find a YouTube video of the demo and call it a day, there is no solution other than writing your own virtualization software all by yourself.
Reply 43 of 77, by kurkosdr
BTW how did you reach that page? What link did you follow? I want to find the other AMD demos too.
Reply 44 of 77, by BEEN_Nath_58
kurkosdr wrote on 2023-10-04, 18:41:
By just a google search. Also the gpuopen site hosts more demos so I knew it was authentic.
Reply 45 of 77, by marxveix
In the subdirectories below you will find some nice 3D demos showing
all 3D capabilities of the ATI 3D accelerators. To run the demos you need
an ATI 3D graphics card with the 3D Rage II graphics accelerator and at
least 4MB of video memory.
CUBES
FAIRY
LAPUTA
PIXIE
SCRNSAVE
VIDSAMPL
One more demo (3d-demo.zip) available from RageProTweaker:
Re: 3D Accelerated Demoscene Demos for DOS/Windows List (Proprietary APIs - including 3DFX)
ATI 3DCIF DEMOS download links:
https://www.upload.ee/files/15998562/3dcif-demos.7z.html
https://archive.org/details/cebit-97
download/file.php?id=92053
All these demos need ATi 3DCIF capable hardware and correct driver, i have used Rage XL 8MB AGP.
https://gona.mactar.hu/ATI3DCIF/
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
Reply 46 of 77, by BEEN_Nath_58
marxveix wrote on 2023-11-30, 07:59:
In the subdirectories below you will find some nice 3D demos showing all 3D capabilities of the ATI 3D accelerators. To run the […]
CUBES
FAIRY
LAPUTA
PIXIE
SCRNSAVE
VIDSAMPL
Thank you, added.
Reply 47 of 77, by marxveix
BEEN_Nath_58 wrote on 2023-12-01, 06:26:
CUBES
FAIRY
LAPUTA
PIXIE
SCRNSAVE
VIDSAMPL
Thank you, added.
Thank you for adding them!
ATi Mach32 cant run these ATi 3D demos, demos are made for ATi Mach64 based cards:
RageII/II+ / RageII+DVD / RageIIC / Rage Pro / Rage XC / RageXL
Rage LT / RageLT Pro / Rage Mobility C / EC / L / M2 / P / M / M1
https://en.wikipedia.org/wiki/ATI_Rage_series
Upload link we should change for more permanent one, this 3dcif-demos.7z link expires after month or two.
Reply 48 of 77, by BEEN_Nath_58
marxveix wrote on 2023-12-01, 15:09:
Thank you for adding them! […]
CUBES
FAIRY
LAPUTA
PIXIE
SCRNSAVE
VIDSAMPL
Thank you, added.
Right, Mach32 is definitely wrong, I will change it with the link.
The Mach64 brand is confusing because it overlaps with the Rage branding. My original categorisation was based on series and not architecture (eg, Maxwell card in gf700 series).
Yet another confusion is the driver disc says Mach32
Reply 49 of 77, by marxveix
BEEN_Nath_58 wrote on 2023-12-01, 17:10:
Right, Mach32 is definitely wrong, I will change it with the link. […]
Thank you, added.
For me they are for Rage II / Rage Pro (cards) or Rage2 / Rage3 (architecture). Rage128 cards are Rage4, they do not have ATi 3DCIF. File name is CEBIT_97.iso and it has drivers for Mach64 and Mach32 + other stuff, on the actual CD - jpg image i cant see Mach32 or Mach64 written on it.
New graphics accelerators at CeBIT'97
ATi@CeBIT'97
ATI has announced the release of the new 3D Rage II+ DVD graphics processor, continuing its series of 3D accelerators based on 3D Rage technology. Software playback of DVD movies will be available on any computer with a Pentium MMX processor thanks to the presence of motion compensation in 3D Rage II+ DVD, which relieves the CPU by 15-30%. ATI plans to supply graphics cards bundled with software for playing DVD movies from CompCore Multimedia and Mediamatics. Hardware playback of DVD movies will be implemented using a special expansion card based on an MPEG-2 decoder (IBM), connected via an expansion connector available on all accelerators of the 3D Rage ATI Multimedia Channel (AMC) family. In addition, the new generation of 3D Rage II+ DVD processors includes a number of technological improvements that enhance performance when working with 3D and 2D graphics: integrated 200 MHz digital-to-analog converter (DAC); by optimizing hardware functions, performance when rendering 3D graphics is increased by 30% compared to Rage II; By increasing the RAM clock frequency (SGRAM) to 83 MHz, performance when drawing 2D graphics is increased. The new 3D Rage II+ DVD processor will be produced in Taiwan at UMC facilities. The first ATI DVD cards will go on sale in June, MPEG-2 software players - in September of this year.
Games with 3D Rage technology - presented@CeBIT'97?
Actua Soccer - Gremlin Interactive
Assault Rigs - Psygnosis (Included with ATI 3D Xpression)
Battle Arena - Playmates Interactive
Toshinden - Entertainment
Black Knight - Formgen
Descent II - Interplay
Havoc - Reality Bytes
Mech Warrior 2 - Activision (Included with ATI 3D Xpression)
VR Soccer '96 - VR Ports
WipeOut - Psygnosis (Included with ATI 3D Xpression)
WIRL - VREAM (Included with ATI 3D Xpression)
Zone Raiders - Virgin Interactive Entertainment
Advantages: support for software and hardware playback of MPEG-2 videos and DVD films, good performance when working with 2D and 3D graphics.
ATi text is taken from (more to read here):
https://www-osp-ru.translate.goog/pcworld/199 … &_x_tr_pto=wapp
From that list WIRL is also like a Demo, but it uses Netscape Navigator browser (browser needs to be installed before to use it). WIRL does not need 3DCIF i think, tested with Rage XL + driver that does not support 3DCIF.
ATi 3D Rage - WIRL - VREAM
https://archive.org/details/wirl_20220201
Reply 50 of 77, by BEEN_Nath_58
marxveix wrote on 2023-12-01, 23:54:
For me they are for Rage II / Rage Pro (cards) or Rage2 / Rage3 (architecture). Rage128 cards are Rage4, they do not have ATi 3D […]
ATi@CeBIT'97
I better just keep in under the ATI3DCIF brand without a card name. Specifically all of it was branded for Rage technology only, which spans over multiple generations unlike my original series-wise listing.
I kept WIRL under DirectX but could you veey it it really uses DX or plain GDI or something else like OGL?
Reply 51 of 77, by BEEN_Nath_58
ATI3DCIF demo attachments 1:
Reply 52 of 77, by BEEN_Nath_58
ATI3DCIF demo attachments 2:
Reply 53 of 77, by marxveix
I do not know exactly at the moment, one WIRL example page probably java, all other pages needs to be checked somehow closely. It does not need special hardware i think, i like 3D Rage demos and screensaver more, WIRL examples are not that fancy, but also its 1996 web browser 3d demos.
Now we have many good looking 3d games over html, back then it just started, if i have to guess it is 2d/3d animation, FutureSplash / Macromedia Flash / Adobe Flash type of thing.
https://en.wikipedia.org/wiki/Browser_game
https://en.wikipedia.org/wiki/Adobe_Flash
Reply 54 of 77, by Dothan Burger
I found an older version of chameleon demo, titled "Chameleon Multiskin" on a GeForce 3 installation CD that seems to fix the issues I was having running the demo in 98. Previously the application would fatally error attempting to exit.
Also, blobby dinosaur I didn't see on that list.
Reply 55 of 77, by BEEN_Nath_58
Dothan Burger wrote on 2024-01-29, 06:35:
Could you share the demos? I can't find any instance on them on google
Reply 56 of 77, by Dothan Burger
BEEN_Nath_58 wrote on 2024-01-29, 07:30:
Here is the GeForce 3 chameleon demo that works for me in 98. https://archive.org/details/chameleon_20240129
More specifically this version works with .VXD sound card drivers.
For me the publicly available version runs without sound card drivers installed. But once a Live/Audigy/YMF744 .VXD was installed it would crash. The WDM had other issues with crackling and instability as well.
Reply 57 of 77, by BEEN_Nath_58
Dothan Burger wrote on 2024-01-29, 07:33:
Here is the GeForce 3 chameleon demo that works for me in 98. https://archive.org/details/chameleon_20240129 […]
Added. And the blobby dinosaur?
Reply 58 of 77, by Dothan Burger
BEEN_Nath_58 wrote on 2024-01-29, 08:59:
The Blobby Dinasaur Demo. https://archive.org/details/blobby-dinosaur
Another demo on the disc is called "Isle of Morg" not sure if that's the same as X-isle.
Reply 59 of 77, by analog_programmer
Several years ago nVidia removed all the tech demos with female characters from their site for a(n) (un)known reason. But some "politically incorrect" person has uploaded one of them (Dusk Ultra) here: https://archive.org/details/nvidia_demo_dusk_ultra
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
