Reply 40 of 228, by GL1zdA
- Oldbie
Awesome news! I want this card so badly.
This is the best news I’ve read in a long time. This is HUGE.
This is really unbelievable 😀 great work!
Oh. Wow.
Almost blindly want to shout: "Shut up and take my money!!!", but maybe a check - "expensive and of premium quality"; what ballpark cost figure are we talking about here?
Awesome stuff. Next on wishlist is the 3DO Blaster... that should be easy enough, right? 😉
/s
scgfx - display graphics and animation on your Roland Sound Canvas
This looks to be incredibly awesome. 😁 Definitely will sign up for one.
Also, is the surround module designed to be compatible with the original Adlib Gold?
RichB93 wrote on 2022-05-30, 10:03:Awesome stuff. Next on wishlist is the 3DO Blaster... that should be easy enough, right? 😉
/s
If someone remakes the 3DO Blaster, pinch me. Add the GUS to the card to it and it'll be sweet.
Shponglefan wrote on 2022-05-31, 00:40:Also, is the surround module designed to be compatible with the original Adlib Gold?
Yes, it’s compatible. 😎
That is AWEsome! (no pun intended 😜 ) Very impressive! 😁
something tells me that the "limited run" will be way not enough for all the demands 🙁
btw: the more you produce, the less expensive it gets^^
ArGUS Parts list: http://bit.ly/2Ddf89V
Great project. Congratulations.
It's happening 😁
Each card has 1.792 smd pads and 245 thru-holes with ~50 different kinds of passives
It's no joke to solder - things get annoying soon 🤣
Beautiful! What is the floppy connector (P7A) for?
GL1zdA wrote on 2022-10-06, 09:55:Beautiful! What is the floppy connector (P7A) for?
CDROM Audio input:
a normal connector will be used for ease of use without having to hunt weird cdda cables
Tasty ~
The design, the components, it's all so gorgeous.
Sexier than my optician (and she is HOT 😜 )
Lovely card! I'm hoping to pick one of these up when the become available. Out of interest keropi, what Iron do you use?
Bancho wrote on 2022-10-06, 13:29:Lovely card! I'm hoping to pick one of these up when the become available. Out of interest keropi, what Iron do you use?
I use a couple of TS100 irons : one has the BC2 tip for smd stuff and the other the TSI tip for tht stuff - both running the custom fw ofcourse
what started as a cheap/compact iron to use ended up being my main one and I haven't looked for anything else since I got it , very satisfied with them
but you also need another bigger/sturdier iron , the TS100 is great for assembly but there are times you need brute force when dealing with old stuff 🤣
Ooooooh yes. Sexy stuff. Amazing guys!
