Reply 40 of 44, by 8bitbubsy
- Member
CJ Grass wrote on 2025-03-07, 13:59:Great work! However, I have a query - when I run pt4dos.exe from a shortcut on the desktop or from the start menu (win98se), a m […]
Great work! However, I have a query - when I run pt4dos.exe from a shortcut on the desktop or from the start menu (win98se), a message appears:
"WARNING: Couldn't detect a Sound Blaster sound card! If you really have a Sound Blaster card installed, make sure its drivers are properly installed.
Press any key to continue with no sound..."
On the other hand, when I run the pt4dos.exe program from Windows Commander everything works fine. My card is an AWE64 CT 4520.
Hm, I don't have this problem on my 1GHz P3 Windows 98SE machine w/ SB Live! (SB emulation). It works fine when starting from both a shortcut on the desktop and Total Commander.
I assume you downloaded the latest version of PT4DOS recently, and didn't use an older version? I fixed some stuff in the SB detection routine a month or two ago.
EDIT: I made a quick version of PT4DOS that prints the Sound Blaster settings read from the BLASTER environment on startup. Can you try this and verify that the settings printed are the same when ran from the desktop and Windows Commander? https://16-bits.org/etc/testme.zip
386:
- CPU: 386DX-40 + 40MHz FPU + 128kB L1 cache
- RAM: 8MB (0 waitstates, 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: Sound Blaster Pro 2.0
- ISA PS/2 mouse card + ISA USB-stick card
- MR BIOS v1.65
