Gateway 2000 overdrive build
Reply 40 of 50, by maxtherabbit
Sphere478 wrote on 2022-09-13, 13:08:
Not sure what setting. I set everything back to default except larger than 1gb drive support and that worked.
can you post a pic of the settings screen now? we can compare to the previous one you posted where it wasn't working
I also notice you removed a jumper on the SCA adapter
Reply 41 of 50, by Sphere478
maxtherabbit wrote on 2022-09-13, 13:48:
The jumper fixed the id1 issue. Now id0.
    1.41 MiB
    1.44 MiB
    1.78 MiB
Sphere's PCB projects.
Reply 42 of 50, by Sphere478
I’ve now put all settings back where they were before except the adapter addresses. That must have been the problem.
chrismeyer6 wrote on 2022-09-13, 13:32:
Yeah none of those jumpers should set a size limit. It might have something to to with the scsi card. Which card are you running as their might be a bios update for larger hard drive support.
Adaptec 1540cf/1542cf
13h was disabled, I should probably check again if more drive space is visible.
Edit:
Seems windows still can’t see more than 8gb
    1.19 MiB
Reply 43 of 50, by Sphere478
Getting 2mb/sec read and write and 14mb/sec verify with around 8ms random access time.
6.5fps in quake
Reply 44 of 50, by Sphere478
Now that it seems I worked out the bugs, I reassembled the gateway 2000 in all its upgraded glory!
I ended up having to change the scsi dma channel to 7 after moving the card to the psu side with a network card below it.
Reply 45 of 50, by Sphere478
Can’t believe I got it to format a 128gb partition.
In fdisk it was saying 13gb but took forever to format.
I went and formatted it in windows and boom! 128gb (probably because of limitations of fat32)
I am still using a primary 8gb partition for windows 95c
    1.18 MiB
Reply 46 of 50, by Sphere478
Just booted pqmagic for dos and extended the 8gb partition all the way to 140gb and got this now.
I’m shocked. I thought windows 95 would never do this..
Reply 47 of 50, by Romain
Sphere478 wrote on 2022-09-14, 09:38:
I love your pic ... so nice.. I'm falling in charm.. 😜
Reply 48 of 50, by Sphere478
Thanks 😀
Reply 49 of 50, by Sphere478
Looks like I will finally be getting a anyclk for these.
Thanks galanopu!
Will post results and pics when I get it! :p
Reply 50 of 50, by Sphere478
I got the chance to try a gd-5434 isa in this. (The fastest ISA video card)
Results:
Pc player 4.5 with gd5434 but 5.9 with onboard
Must be a vl bus gd-5429 as others have said making it faster because of the increased bandwidth despite being a slower gpu
