Reply 40 of 47, by RandomStranger
- Oldbie
Horun wrote on 2023-09-21, 02:22:kolderman wrote on 2023-09-21, 02:09:For games of this era more core are likely to cause problems not help.
What era ? The games mentioned by others are much newer than what I play on it and have never had an issue.. I guess if I played early Win95 games on it then I could but I also have run old Aldus PageMaker 4 and other old apps on that box recently w/o a problem ( I run 32bit which is more backward compatible (64bit versions are not))....
Need for Speed Underground 2 crashes on quad cores. That's a 2004 XP era game. Though you can set the CPU affinity.
