Windows for Workgroups TCP/IP Disk
Reply 40 of 99, by myne
Bit of necromancy here, but anyway the iso template I made includes the TCP add on by default.
I built:
Reply 41 of 99, by sgray
Hey guys, just thought I would memorialize this here in case others in the future have trouble locating clean copies of these old Microsoft Windows 3.x updates and TCP/IP packages. Although the Microsoft FTP (SoftLib section) is gone except for some remaining mirrors, in my archival work I have found that the TechNet Software Library Archive CD has that SOFTLIB folder containing all the final versions of those files. I believe that the NT 3.51 installation media may also contain a copy of just the stack and there are certainly some modified/updated versions out there, but that Technet CD is a great source of the clean originals!
Attached is the file list document from the root of that CD. Happy to provide a clean disc image to Vogons or anyone that needs it.
Reply 42 of 99, by GigAHerZ
Upload it to archive.org. 😉
A little about software engineering: https://byteaether.github.io/
Reply 43 of 99, by elszgensa
It's already there, that sllist.txt is from the September 1998 release.
Reply 44 of 99, by Grzyb
maxtherabbit wrote on 2024-12-03, 04:12:
So what? Win3.0 sucks and I don't really understand the point you're trying to make.
I thought this all goes back to wanting to find the mystical "TCP/IP for Microsoft Windows for Workgroups". Which, if found, would do the exact same things...
If you feed wfw3.1 a NDIS2 based protocol stack with TCP you will get the features of wfw3.1 on a TCP network. Just like when you do the same with win3.11, you get the features (and limitations) of win3.11 on a TCP network
The point is:
DOS client + regular Windows =/= WfW
The key idea behind WfW is peer-to-peer - it's not just a client, it can also be a server.
And another point:
Microsoft Network Client version 3.0 for MS-DOS seems to be incompatible with WfW 3.1...
I've tried to install them both:
First, the Client, using TCP/IP - everything's fine.
Next, WfW, with default settings...
- if I let it modify CONFIG.SYS and AUTOEXEC.BAT, it breaks the DOS Client
- if not, WfW starts with some network error message, and without any network functionality
Nie rzucim ziemi, skąd nasz root!
Reply 45 of 99, by Jo22
Hi, is that same relationship between Novell Netware and Personal Netware?
Reply 46 of 99, by Grzyb
Jo22 wrote on 2024-12-08, 06:47:
I think so.
The original NetWare is dedicated-server.
NetWare Lite and Personal NetWare are peer-to-peer.
Reply 47 of 99, by maxtherabbit
Grzyb wrote on 2024-12-08, 04:08:
The point is: DOS client + regular Windows =/= WfW The key idea behind WfW is peer-to-peer - it's not just a client, it can also […]
The point is:
And another point:
Well I never expected it to work "out of the box" (and to be fair it may not work at all) - what I was suggesting was manually editing the autoexec/config/protocol.ini to provide a stack that WfW is happy with and includes the TCP TSRs and protocol driver.
You're actually in a position I've been meaning to try out myself for quite some time. If you could post your configuration files both before and after the WfW install I'd be happy to try to help you get it working
Reply 48 of 99, by Grzyb
maxtherabbit wrote on 2024-12-08, 23:43:
Here you are...
first, the DOS Client:
FILES=20
device=C:\dos\HIMEM.SYS
DEVICE=C:\DOS\SETVER.EXE
DOS=HIGH
device=C:\NET\ifshlp.sys
LASTDRIVE=Z
C:\NET\net initialize
set path=C:\NET;c:\dos;c:\bin;c:\vc;c:\mtcp
set mtcpcfg=c:\mtcp\mtcp.cfg
set TZ=CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00
set tmp=c:\tmp
set temp=c:\tmp
C:\NET\netbind.com
C:\NET\umb.com
C:\NET\tcptsr.exe
C:\NET\tinyrfc.exe
C:\NET\nmtsr.exe
C:\NET\emsbfr.exe
C:\NET\net start
[network.setup]
version=0x3110
netcard=ms$elnk3,1,MS$ELNK3,1
transport=tcpip,TCPIP
lana0=ms$elnk3,1,tcpip
[TCPIP]
NBSessions=6
SubNetMask0=255 0 0 0
IPAddress0=0 0 0 0
DisableDHCP=0
DriverName=TCPIP$
BINDINGS=MS$ELNK3
LANABASE=0
[protman]
DriverName=PROTMAN$
PRIORITY=MS$NDISHLP
[MS$ELNK3]
DriverName=ELNK3$
and it works fine:
The attachment 1.png is no longer available
Reply 49 of 99, by Grzyb
Now, after WfW 3.1 installation:
FILES=20
DOS=HIGH
LASTDRIVE=Z
device=C:\WINDOWS\protman.dos /i:C:\WINDOWS
device=C:\WINDOWS\workgrp.sys
device=C:\WINDOWS\elnk3.dos
STACKS=9,256
set path=C:\WINDOWS;C:\NET;c:\dos;c:\bin;c:\vc;c:\mtcp
set tmp=c:\tmp
set temp=c:\tmp
C:\NET\umb.com
C:\NET\tcptsr.exe
C:\NET\tinyrfc.exe
C:\NET\nmtsr.exe
C:\NET\emsbfr.exe
C:\WINDOWS\net start
C:\NET\PROTOCOL.INI hasn't changed, of course - this is C:\WINDOWS\PROTOCOL.INI :
[network.setup]
version=0x3100
transport=ms$netbeui,MS$NETBEUI
lana0=ms$elnk3,1,ms$netbeui
[protman]
DriverName=PROTMAN$
PRIORITY=MS$NETBEUI
[MS$ELNK3]
DriverName=ELNK3$
IOADDRESS=0x300
MAXTRANSMITS=6
[MS$NETBEUI]
DriverName=netbeui$
SESSIONS=10
NCBS=32
BINDINGS=MS$ELNK3
LANABASE=0
The broken DOS Client:
The attachment 2.png is no longer available
Reply 50 of 99, by Grzyb
And yes, I can see that "C:\NET\netbind.com" got removed...
after adding it back, it does load, but it doesn't really help - the following still fail to load:
C:\NET\tcptsr.exe
C:\NET\tinyrfc.exe
C:\NET\nmtsr.exe
Reply 51 of 99, by Grzyb
Normally, it's "C:\NET\net initialize" where this stuff is loaded:
The attachment 3.png is no longer available
after "device=C:\WINDOWS\protman.dos /i:C:\WINDOWS", however, it doesn't load anything:
The attachment 4.png is no longer available
Reply 52 of 99, by doshea
Jo22 wrote on 2024-12-02, 12:17:
Windows for Workgroups 3.10 was very rare, that being said.
We have a localized copy at home from back of the day, but I've never seen one for sale on eBay.
I suppose that might be because Windows for Workgroups 3.1 just added the networking features on top of Windows 3.1, so you only bought it if you wanted those features, but Windows for Workgroups 3.11 added non-networking features on top of Windows 3.11 including performance enhancements, so there were more reasons for home users to buy it.
Reply 53 of 99, by Jo22
doshea wrote on 2024-12-10, 07:34:
That's a good point, yes.
Way back in the 90s and early 2000s when I bought vintage PCs or found some vintage PCs on road side,
I often found WfW 3.11 to be pre-installed.
This really confused me at the time, because I grew up with plain Windows 3.1 on a 286.
Whereas my father had used Windows 95 RTM on a 386.
At the time, Windows for Workgroups 3.10 was what we had known but not used anymore.
It felt like an odball system, just like Windows/386, Windows 3.0 MME or "OS/2 for Windows".
Later I've found out that there had been lots of MS-DOS 6.22+WFWG3.11 shrink-wrapped bundles being sold (they're still on eBay).:
Users who had bought their PCs in 1994 must have gotten this combo instead of separate copies of MS-DOS 5/6/6.20 and Windows 3.1x.
Probably because Novell DOS 7 had Personal NetWare included (with Windows 3.1 utilities).
So Microsoft probably saw no use in selling both vanilla Windows 3.1x and WfW 3.11 anymore.
That's just a thought, of course.
PS: On a second thought, it might also have been a turning point of some kind.
By the time Windows for Workgroups came out, there was a transitional point between 16-Bit and 32-Bit.
By shipping WfW 3.11, Microsoft had the chance to abandon 16-Bit support.
There nolonger was a need to support 286 users, for example.
With WfW 3.11, Windows 3.x now ran in 32-Bit Protected-Mode all the time and Microsoft could focus on things like WinG, Win32s and development of Windows 95.
Microsoft could now assume a 386 processor being minimum, at least.
So device drivers, applications and DLLs could simply require those instructions without issues.
That also was good for performance reasons.
Many Super VGA drivers did require 386 Enhanced Mode, already, because VXDs made life easier.
The 32-Bit File Access (32BDFA, HDD cache) did also reduce need for running SmartDrive, which was a DOS/Real-Mode thing.
Reply 54 of 99, by maxtherabbit
Grzyb wrote on 2024-12-10, 06:47:
Normally, it's "C:\NET\net initialize" where this stuff is loaded: […]
Correct, so let's replace it with loading the requisite drivers manually. This is done in your CONFIG.SYS:
FILES=20
DOS=HIGH
LASTDRIVE=Z
DEVICE=C:\NET\NEMM.DOS
DEVICE=C:\NET\TCPDRV.DOS
DEVICE=C:\NET\DIS_PKT.DOS <---optional if you want a packet driver shim for mTCP
STACKS=9,256
You were already on the right track with adding back netbind.com in the autoexec.bat, so let's keep that there.
Now let's edit your windows PROTOCOL.INI to look more like it did with the DOS client:
[network.setup]
version=0x3100
[protman]
DriverName=PROTMAN$
PRIORITY=MS$NDISHLP
[MS$ELNK3]
DriverName=ELNK3$
IOADDRESS=0x300
MAXTRANSMITS=6
[TCPIP]
NBSessions=6
IPAddress0=0 0 0 0
DisableDHCP=0
DriverName=TCPIP$
BINDINGS=MS$ELNK3
LANABASE=0
If this works and you want to add the packet driver shim, you can optionally add this section to PROTOCOL.INI:
[pktdrv]
DriverName=PKTDRV$
BINDINGS=MS$ELNK3
INTVEC=0x60
CHAINVEC=0x68
Reply 55 of 99, by maxtherabbit
ok I setup a sandbox in 86box and did get it to work, but I'm still ironing out a couple issues - standby
the instructions I posted earlier will not produce a working system, but I was very close
Reply 56 of 99, by maxtherabbit
Configuration Guide For MS TCP/IP and WfW 3.1
Introduction
As most of you know, WfW version 3.1 was the last version of Windows to ship with a working "standard" mode (16-bit protected), so it is of special interest to 286 enthusiasts like myself. As such, all my testing was done on an emulated 286 system as well as real hardware. Some of the documentation I used as references included information about enhanced mode, and I will include it where applicable, but consider it untested. IMO if you want enhanced mode WfW3.11 with the 32-bit TCP addon is greatly preferable.
BLUF: The easiest way to get windows for workgroups 3.1 in standard mode running over TCP/IP is to simply get a working install of the MS DOS Client 3.0 first and then install WfW 3.1 on top WITHOUT letting it make any changes to the CONFIG.SYS or AUTOEXEC.BAT. You MUST use the FULL re-director supplied with the Net Client 3.0
If you want WfW3.1 to work in enhanced mode, you must load WORKGRP.SYS which is shipped with WfW3.1. You may also need to use the re-director included with WfW3.1 - more on that later.
Compared to a regular install of win3.1 + the Net Client 3.0 what does WfW 3.1 bring to the table? You get the nicer fileman UX which you will recognize from WfW3.11 as well as the NetDDE apps (winchat and clipbook). Please note that the option for enabling file sharing in WfW3.1 was ALWAYS greyed out for me during this testing process, even when doing a bone-stock install of WfW3.1 (no DOS net client other than the stuff included with WfW3.1) running NetBEUI. I assume this is attributable to me running it in Standard Mode and that Enhanced mode is required for file sharing.
Reply 57 of 99, by maxtherabbit
Manual Configuration Guide and Details
In order to get a working DOS client (or win16 since it just uses that same framework) let's take a look at an example CONFIG.SYS and AUTOEXEC.BAT file first.
Certain "shortcuts" are taken both by the Net Client 3.0 as well as WfW3.1 in their default installs which need to be broken down into their constituents to make full manual configuration possible.
CONFIG.SYS Example
      device=c:\dos\setver.exe
device=c:\windows\himem.sys
device=c:\windows\emm386.exe noems x=b800-c800
dos=high,umb
files=30
buffers=10
lastdrive=z
device=c:\NET\protman.dos /i:c:\NET
device=c:\NET\nemm.dos
device=c:\NET\tcpdrv.dos /i:c:\NET
device=c:\windows\workgrp.sys
device=c:\NET\elnk3.dos
stacks=9,256
Let's look at each DEVICE statement and explain their purpose. The more "normal" stuff you would see in a CONFIG.SYS file is also included for reference, but EMM386 is NOT required.
IFSHLP.SYS: Installable file system helper. Required by the DOS re-director to map network drives.
PROTMAN.DOS: This is the protocol manager, the lynch pin of the whole operation. It must be loaded first and all the other components depend on it. It reads its configuration from PROTOCOL.INI, the location of which is specified by the /I(nformation) switch.
NEMM.DOS: Handles context switching of DOS expanded memory for TCP. NEMM.DOS is required by TCPDRV.DOS and must be loaded, with or without expanded memory.
TCPDRV.DOS: The actual DOS TCP driver. It doesn't do much by itself, but all the TCP TSR programs we will load later hook it, and depend on it. It depends on NEMM.DOS. It reads its configuration from TCPUTILS.INI, the location of which is specified by the /I(nformation) switch. If no information switch is provided in its device statement, it will use the location provided by the information switch on PROTMAN. In addition to TCPUTILS.INI, the following files must be located in this path: HOSTS, LMHOSTS, NETWORKS, PROTOCOL, SERVICES.
WORKGRP.SYS: Required for WfW3.1 to work in protected mode. Also required by the network re-director (NET.EXE) which comes with WfW3.1. NOT required by the NET.EXE included in the DOS Client 3.0 package.
ELNK3.DOS: The network card driver. Name will obviously vary with your network card.
AUTOEXEC.BAT Example (provided by grzyb)
set tmp=c:\tmp
set temp=c:\tmp
C:\NET\netbind.com
C:\NET\umb.com
C:\NET\tcptsr.exe
C:\NET\tinyrfc.exe
C:\NET\nmtsr.exe
C:\NET\emsbfr.exe
C:\NET\net start full
NET INITIALIZE: This command is a shortcut taken by the DOS Client 3.0. It is the equivalent of loading protman.dos, nemm.dos, tcpdrv.dos and your network card driver in CONFIG.SYS. Since we are going to load all of these manually, we should omit this command! This also allows the use of DEVICEHIGH to load all these drivers into UMB, which is fairly important considering the massive memory footprint of the DOS TCP stack.
NETBIND.COM: Binds all the drivers together. Reads configuration from the PROTOCOL.INI specified by PROTMAN. Nothing will work without binding, however certain versions of the network re-director (such as the one included with WfW3.1) can perform this step automatically with NET START. I still recommend performing this step manually, NETBIND is not a TSR and has no memory footprint. There is no downside to doing it separately.
UMB.COM: Allows the subsequent TCP TSR programs to load part of themselves into UMB automatically. Not required but highly recommended.
TCPTSR.EXE: Primary DOS TCP protocol module. REQUIRED. Can be loaded high with the help of UMB.COM and unloaded on demand by UNLOADT.EXE.
TINYRFC.EXE: REQUIRED. Can be loaded high with the help of UMB.COM and unloaded on demand by UNLOADT.EXE.
NMTSR.EXE: The network management module for DOS. Provides for network maintenance facility programs such as PING, ARP, and NETSTAT. NOT REQUIRED. Can be loaded high with the help of UMB.COM and unloaded on demand by UNLOADT.EXE.
EMSBFR.EXE: I'm not sure of its exact purpose but I think it is required if you have EMS memory. Run the command anyway, it won't stay resident if you don't need it.
NET START FULL: Starts the network re-director. The directive FULL specifies the full size re-director, which windows requires. You can omit the "FULL" if you are using the NET.EXE included with WfW3.1 or if you configure the DOS Client 3.0 to provide the full re-director by default in its SYSTEM.INI. (NET will look for a variety of parameters related to logon/logoff in a SYSTEM.INI file located in the same path as NET.EXE. You will notice that the DOS Net Client 3.0 ships with a SYSTEM.INI in its directory, and the windows re-director uses the same SYSTEM.INI as all of windows.)
Reply 58 of 99, by maxtherabbit
My Personal Configuration
Now that we've studied the examples, let's look at my exact personal configuration to use TCP with WfW3.1 on a 286 using a NE2000 compatible NIC.
CONFIG.SYS
DOS=HIGH,UMB
DOSDATA=UMB
DEVICE=C:\DRV\UMB_DRVR.SYS /C=05
DEVICE=C:\DOS\HIMEM.SYS
DEVICEHIGH C:\DRV\VIDE-CDD.SYS /D:CDEEZ1
DEVICEHIGH=C:\NET\IFSHLP.SYS
DEVICEHIGH=C:\NET\PROTMAN.DOS /I:C:\NET
DEVICEHIGH=C:\NET\NEMM.DOS
DEVICEHIGH=C:\NET\TCPDRV.DOS
DEVICEHIGH=C:\NET\NE2000.DOS
DEVICEHIGH=C:\NET\DIS_PKT.DOS
SHELL=C:\DOS\COMMAND.COM /E:512 /P /H
BUFFERS=30
FILES=40
LASTDRIVE=I
FCBS=1,0
STACKS=9,256
Only new thing you will notice here is the DIS_PKT.DOS, which is a shim to allow DOS apps which rely on a packet driver to work with the NDIS2 driver. You will also notice that I omitted the WORKGRP.SYS since I'm using the Net Client 3.0 re-director and running in standard mode.
AUTOEXEC.BAT
@ECHO OFF
PATH C:\DOS;C:\NET;C:\WINDOWS;C:\QEDIT;C:\DRV;C:\TRUMPET;C:\MTCP
NETBIND
LH MSCDEX /D:CDEEZ1 /E
LH SHARE
LH WINPKT 0x60
LH DOSKEY /INSERT
CTMOUSE
UMB
SET TEMP=C:\TEMP
SET BLASTER=A220 I5 D1 P330 T4
SET MTCPCFG=C:\MTCP\MTCP.CFG
SET TZ=EST5EDT
DHCP.EXE
Three things here. First you will see I'm loading WINPKT which is to allow the trumpet winsock suite to communicate using the DOS Packet Driver shim. Second, you see I'm not loading any of the TCP TSR programs or starting the network re-director. I do these in a separate batch file so I can load and unload TCP on demand. Finally, you see an example of using mTCP's DHCP.EXE which works via the packet driver to NDIS2 shim (DIS_PKT.DOS).
To start Windows
tcptsr
tinyrfc
rem nmtsr
emsbfr
c:\net\net.exe start full
win
To unload TCP when done with networking
net stop /yes
unloadt /notsr
For some reason, UNLOADT.EXE is not included with the Net Client 3.0. I obtained it from the LAN Manager installation package.
PROTOCOL.INI
[network.setup]
version=0x3110
netcard=ms$ne2clone,1,MS$NE2CLONE,1
lana0=ms$ne2clone,1,tcpip
[MS$NE2CLONE]
IOBASE=0x300
INTERRUPT=10
DriverName=MS2000$
[TCPIP]
NBSessions=6
IPAddress0=0 0 0 0
DisableDHCP=0
DriverName=TCPIP$
BINDINGS=MS$NE2CLONE
LANABASE=0
[protman]
DriverName=PROTMAN$
PRIORITY=MS$NDISHLP
[pktdrv]
DriverName=PKTDRV$
INTVEC=0x60
CHAINVEC=0x68
386 Enhanced Mode
If you have WfW3.1 on a 386 or better and wish to try enhanced mode, I recommend deviating from my personal configuration in two ways:
1) Load WORKGRP.SYS after PROTMAN.DOS. You can safely ignore the warning it prints about NetBEUI configuration.
2) Use WINDOWS\NET.EXE START instead of NET\NET.EXE START FULL. The WfW re-director is smaller than the full one included with DOS Client 3.0 and probably handles enhanced mode better.
I still recommend using the versions of PROTMAN.DOS and the NIC driver included with the NET Client 3.0 in either case, they are newer.
Reply 59 of 99, by maxtherabbit
The WfW 3.1 Network Control Panel
The settings contained in "logon, networks, password" as well as those on the main screen are read from/written to WINDOWS\SYSTEM.INI. These settings will have an effect if you are using WfW3.1's own NET.EXE and will not if you're using a different version of NET.EXE located outside the WINDOWS directory.
The settings under adapters are read from/written to WINDOWS\PROTOCOL.INI. Always in WINDOWS, it doesn't respect the information switch on PROTMAN. They will have an effect if your PROTMAN's information switch points at WINDOWS, otherwise no effect.
IMPORTANT NOTES: WfW3.1 seems to be unable to parse a PROTOCOL.INI which only includes TCP as the single protocol. If you use NetBUEI or IPX as a primary protocol this will not affect you. WfW3.1 will also balk at the version number written to the PROTOCOL.INI by the DOS Client 3.0 (0x3110). Unless you are using a legacy protocol in addition to TCP, I strongly urge you to point PROTMAN's information switch at a path other than WINDOWS, and allow WINDOWS\PROTOCOL.INI to serve as a dummy file in case someone messes around in the control panel.
