Reply 40 of 42, by Nemo1985
RetroPCCupboard wrote on 2025-01-21, 08:06:On the subject of feedback, if a seller sells a non-functional item as "used" rather than "for parts or not working" but the description simply says "untested". What would you say if they refused to refund you, because they say that the description didn't say its works? The definition of "used" on ebay, means that it should be fully functional right? The fact they didn't test it before shipping is irrelevant?
I would avoid buying from this seller but yes, according to ebay if it's used it means it works. Other than that always treat untested stuff as non working.
If you open a claim ebay will probably refund.
