3dmark99 MegaThread
Reply 400 of 412, by pz76home@gmail.com
Here's another PCEMv17 result
Observations, slower than the K6-2 300. Though noticed that the Emulation speed seems to be more consistently around %100 with disabling the "External Cache" in the BIOS.
- Intel 11400F running 125W TDP, 32GB, WD NVME storage, Nvidia 4600 Ti
- PCem v17
- Intel P2 300Mhz emulated
- GA-686BX 512MB RAM emulated
- 3dfx Voodoo 3 16MB emulated (4 x threads)
- 800x600 16bit colour.
Reply 401 of 412, by pz76home@gmail.com
pz76home@gmail.com wrote on 2025-06-09, 12:38:
Here's another PCEMv17 result […]
- PCem v17
After real world testing, E.g. playing Quake 2 using 3DFX. It's better to leave the "External Cache" enabled in BIOS. I was noticing more Emulation speed dips in the Emulation speed graph.
Reply 402 of 412, by pz76home@gmail.com
I bought a HP compaq 6000 sff Pro for $50.
Intel Core Duo 2 - 3Ghz
4GB RAM (DDR2 I think)
***My addons
ASUS Nvidia GT 730 2GB DDR5
250GB Samsung EVO 840 SSD
It took a bit of work to get to a stable working system. Use the 340.52 drivers, not the latest 368.81 or the later icafe drivers.
Anyway, I this is not a bad score.
Reply 403 of 412, by pz76home@gmail.com
pz76home@gmail.com wrote on 2025-08-10, 02:46:
I bought a HP compaq 6000 sff Pro for $50. […]
***My addons
I forgot to mention the OS is Windows XP SP3 with SP4 unofficial fixes.
Reply 404 of 412, by xXmobiusXx1
Pentium III 800E
Asus P3B-F rev 1.4
2 x 128mb Pc133 ( set to PC100 cl2 T4)
Voodoo 3 3000 ( stock )
System Info:
The attachment aida64 info.png is no longer available
-------------------------800 x 600 benchmark:----------------------------
The attachment 800 x 600.png is no longer available
Test My Project
Rendering Platform Voodoo3 AGP
Resolution 800*600
Color Depth 16-bit Color
Frame Buffer Triple buffering
Refresh Rate 75 Hz
CPU Optimization Intel(r) Pentium(r) III
3DMark Result 6191.76 3DMarks
Synthetic CPU 3D Speed 12250.34 CPU 3DMarks
Rasterizer Score 2406.89 3DRasterMarks
Game 1 - Race 71.06 FPS
Game 2 - First Person 54.86 FPS
Fill Rate 157.39 MTexels/s
Fill Rate With Multi-Texturing 307.35 MTexels/s
2MB Texture Rendering Speed 257.27 FPS
4MB Texture Rendering Speed 248.22 FPS
8MB Texture Rendering Speed 202.93 FPS
16MB Texture Rendering Speed 11.68 FPS
32MB Texture Rendering Speed 5.78 FPS
Bump Mapping Emboss, 3-pass 135.39 FPS
Bump Mapping Emboss, 2-pass 176.27 FPS
Bump Mapping Emboss, 1-pass 0.00 FPS
Point Sample Texture Filtering Speed 102.47 %
Bilinear Texture Filtering Speed 100.00 %
Trilinear Texture Filtering Speed 56.52 %
Anisotropic Texture Filtering Speed 0.00 %
6 Pixel/individual 1462.63 KPolygons/s
6 Pixel/strips 2378.84 KPolygons/s
25 Pixel/individual 1478.47 KPolygons/s
25 Pixel/strips 2404.92 KPolygons/s
50 Pixel/individual 1439.07 KPolygons/s
50 Pixel/strips 2123.75 KPolygons/s
250 Pixel/individual 554.29 KPolygons/s
250 Pixel/strips 567.13 KPolygons/s
1000 Pixel/individual 151.18 KPolygons/s
1000 Pixel/strips 152.19 KPolygons/s
Processor Type Unknown
Processor Speed 800 MHz
L1 Cache size 32 KB
L2 Cache size None
Physical Memory 256 MB
-------------------------------1024 x 768 benchmark:-------------------------------
The attachment 1024 score.png is no longer available
Test My Project
Resolution 1024*768
Refresh Rate 76 Hz
3DMark Result 4753.93 3DMarks
Synthetic CPU 3D Speed 12126.52 CPU 3DMarks
Rasterizer Score 2317.71 3DRasterMarks
Game 1 - Race 51.00 FPS
Game 2 - First Person 44.52 FPS
Fill Rate 161.41 MTexels/s
Fill Rate With Multi-Texturing 314.77 MTexels/s
2MB Texture Rendering Speed 183.24 FPS
4MB Texture Rendering Speed 164.21 FPS
8MB Texture Rendering Speed 135.39 FPS
16MB Texture Rendering Speed 11.63 FPS
32MB Texture Rendering Speed 5.86 FPS
Bump Mapping Emboss, 3-pass 93.05 FPS
Bump Mapping Emboss, 2-pass 124.08 FPS
Point Sample Texture Filtering Speed 101.88 %
Trilinear Texture Filtering Speed 56.98 %
6 Pixel/individual 1462.62 KPolygons/s
6 Pixel/strips 2379.89 KPolygons/s
25 Pixel/individual 1446.89 KPolygons/s
25 Pixel/strips 2425.84 KPolygons/s
50 Pixel/individual 1422.48 KPolygons/s
50 Pixel/strips 2107.78 KPolygons/s
250 Pixel/individual 564.66 KPolygons/s
250 Pixel/strips 579.20 KPolygons/s
1000 Pixel/individual 152.86 KPolygons/s
1000 Pixel/strips 153.69 KPolygons/s
L1 Cache size 32 KB
L2 Cache size None
Reply 405 of 412, by iraklis777
good morning to all
yesterday i update my retro build . my setup is below:
abit is7-v2
northwood p4 3.0 ghz
512mb of memory
80gb ide disk
ide LG dvd/rw
ati 9600 xt -vio (abit branded)
i have problem running 99 max .
at second pass of bump mapping emboss benchmark , my pc freeze and crash
and restart needed.
the first pass is succesfull, always crashing at second pass , same exact moment.
do anyone having an idea how to solve the problem?
Reply 406 of 412, by junak
Change drivers GPU. Older sometimes works better.
RETRO Soyo SY-5XA + Pentium 166MMX + 32 MB RAM + S3 Trio 3D 4 MB VRAM + ESS AudioDrive ES 1869F
MODERN MSI MPG Z690 EDGE WIFI DDR4 + I7 12700K (stock UV) + 48 GB RAM 3600 MHz DDR4 + RTX 4070 Ti 12 GB VRAM
Reply 407 of 412, by ubertrout
Just for fun I ran 3Dmark 99 Pro Max on an "ultimate overkill" Windows XP system - it's also meant for running modern games on my CRT setup, so it isn't quite as stupid as it sounds.
System is:
i5-4690k (OC to 4.5 Ghz)
Asus Z87 Gryphon
32 GB of DDR3 2400 Mhz CL11
MSI Golden Gaming GTX 980 Ti
Got 86723 3DMarks and 161831 CPU 3D Marks.
Reply 408 of 412, by AntonPC
ubertrout wrote on 2026-01-03, 16:39:
Just for fun I ran 3Dmark 99 Pro Max on an "ultimate overkill" Windows XP system - it's also meant for running modern games on m […]
System is:
Asus Z87 Gryphon
Nice! Do you use it in a dual boot setup? If that's the case, which OSs?
Newest: Intel i5 10400F / Asus B460M-CSM / Intel ARC770 LE 16GB / 32GB DDR4 Kingston / Win 10 64
Oldish: Intel i7 3770 / Gigabyte GA-B75M-D3H / Quadro K620 2GB / 16GB DDR3 Kingston / Win 7 64
Older: loading... WinXP32?
Oldest: loading... Win98SE?
Reply 409 of 412, by ubertrout
AntonPC wrote on 2026-01-28, 20:04:
System is:
Asus Z87 Gryphon
XP, 7, & 11. Although to be honest I'm not using the 7 install much.
Reply 410 of 412, by BetaC
After getting everything up and going with my Pentium Pro build, I managed to get the bench running after remembering that a 4MB card can only do 640x480.
The attachment 3DMark.png is no longer available
It's a PPro 256k running at 233, with a Millennium/Voodoo1 combo and 128MB of FPM.
Reply 411 of 412, by Vandal
Hi all,
I've recently built a retro PC and have come across this site multiple times during the process, it's been a real help! 3dmark was one of my fav benchmark programs back in the day so I had to come here an post results from my new PC!
Spec
Asus P2B
Pentium II 350Mhz
320 MB RAM
Geforce 2 MX 400
Creative Sound Blaster Live
Seagate 7200.12 IDE 500 GB
Win98SE
2562 3DMarks
3366 CPU 3DMarks
Reply 412 of 412, by TheIpex
Intel i5 4690K @ 5GHz
Gigabyte Z97X-UD5H
G.Skill Ripjaws 2x2GB DDR3 @ 2400MHz 9-11-9-28
Gigabyte GTX 980 Ti XTREME
Windows XP SP3 32bit
3DMarks: 97402
CPU 3DMarks: 185305
The attachment 3DM99M.jpg is no longer available
Intel 486DX2 66MHz
Intel Pentium MMX 233MHz
Intel Pentium III-S 1400MHz
