Netburst: Aiming for the Stars
Reply 400 of 535, by paradigital
supercordo wrote on 2023-12-12, 21:37:
paradigital wrote on 2023-12-12, 15:42:
And yet again I find stuff that I forgot I had. This is the reason I now maintain an asset tracking system.
Asus P5N-D, BIOS modified for LGA-771, and a load of 775/771 CPUs. No 771 Netburst Xeons though 🙁
I was running my 660 on an Asus P5N-D.
Did you ever try your Xeon 5080?
I couldn’t get my Pentium D 945 to strap to 1066FSB, so I’m looking at options for native 1066.
Reply 401 of 535, by supercordo
paradigital wrote on 2023-12-12, 22:11:
Just got my 771 to 775 stickers in today. Ill play with it this weekend.
Reply 402 of 535, by paradigital
supercordo wrote on 2023-12-12, 22:14:
All I can say is careful with the scalpel/xacto when cutting the lugs off the socket!
Reply 403 of 535, by supercordo
I plan on trimming the notches into the cpu like Phil did in his video.
Reply 404 of 535, by wirerogue
i think this will be my last socket 775 entry.
same 780i board and pentium 4 650, now at 4.2ghz and ocz nvidia/sli memory at 1167 and i'm using a gtx280 instead of a gtx285.
23,129
The attachment 3dmark2000.4.2.gtx.280.png is no longer available
The attachment 3dmark.2000.4.2.gtx280.pdf is no longer available
now onto socket 478.
Reply 405 of 535, by Meatball
The screenshot total MHz is incorrect - CPU-Z is not calculating correctly. The multiplier is correct, though. Actual MHz and FSB is below.
3DMark 2000: 29936
CPU: Presler Pentium D 945 3.40GHz@4688MHz/293MHz
RAM: 2048MB DDR2 1066 Dual Channel@1172MHz
GPU: GeForce7 7950 GT@600MHz/783MHz
Reply 406 of 535, by H3nrik V!
Meatball wrote on 2023-12-13, 05:21:
The screenshot total MHz is incorrect - CPU-Z is not calculating correctly. The multiplier is correct, though. Actual MHz and […]
3DMark 2000: 29936
I was using V 2.08 - maybe it gets it more correct?
Reply 407 of 535, by Meatball
H3nrik V! wrote on 2023-12-13, 05:33:
3DMark 2000: 29936
Thanks! I’ll try it tomorrow.
Reply 408 of 535, by supercordo
Scores updated. An * was added to Meatballs score. The score will have an * until CPU speed is displayed correctly by CPUz or verified by cpuz validator link.
Reply 409 of 535, by wirerogue
3DMark 2000: 29936
is that also stock voltage you are running on the cpu?
Reply 410 of 535, by Meatball
wirerogue wrote on 2023-12-13, 20:58:
3DMark 2000: 29936
1.400v
Reply 411 of 535, by Meatball
I found when C1 Halt State is disabled, the CPU is inventoried incorrectly no matter the utility or program in this setup. v1.89 of CPU-Z is the last version to work under 9x of which I am aware. However, when C1 is enabled, HWINFO can detail the FSB and CPU speed properly - I used the latest v7.66.
I ran the benchmarks several times each with C1 enabled and disabled; the results were within variance in both scenarios. Unsurprisingly, a nice boost is achieved with C1 disabled. The best of both runs are attached.
3DMark 2000: 30400
RAM: 2048MB PC2-8500 DDR2 Dual Channel@1172MHz
GPU: GeForce 7950 GT@600MHz/1584MHz
Reply 412 of 535, by Trashbytes
4.9Ghz, thats a very nice overclock for a Pentium D and very close to that magical number 😉 JUst noticed that first one is listed at 4.6 ...which one is the one we need to pay attention to ?
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 413 of 535, by Meatball
Trashbytes wrote on 2023-12-14, 05:03:
4.6 - it's not reporting the speed correctly when C1 enhanced halt state is disabled.
Reply 414 of 535, by Trashbytes
Meatball wrote on 2023-12-14, 05:32:
4.6 is still a damn fine overclock, 1.2Ghz above stock !
Reply 415 of 535, by Meatball
3DMark 2003: 71235
CPU: Presler Pentium D 945 3.40GHz@4656MHz/291MHz
RAM: 2048MB PC2-8500 DDR2 Dual Channel@1164MHz
GPU: GeForce GTX 980 Ti Classified
Reply 416 of 535, by H3nrik V!
That's an impressive clock speed!
Reply 417 of 535, by Meatball
3DMark 2001: 40256
GPU: GeForce 8800 GT@Core-653MHz/Shader-1783MHz/GDDR3-1768MHz
I'm taking the machine down (for) now. Thanks for all the fish!
Reply 418 of 535, by supercordo
Scores updated!
Reply 419 of 535, by supercordo
I present to you Cedar Mill at 5GHz. I believe i can tighten up the memory still. Ill leave that for another day.
