How about a MR-BIOS ROM file repository?
Reply 420 of 537, by Pino
I have this board, let me know if there is interest in the Mr. BIOS from it and I can dump and upload:
Reply 421 of 537, by keropi
Pino wrote on 2025-06-26, 20:40:
yes please dump it - if possible with a programmer 😀
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 422 of 537, by jheronimus
Oh, please do. We don't have this version currently, it's a pretty common chipset and it's a pretty recent version.
MR BIOS catalog
Unicore catalog
Reply 423 of 537, by Pino
keropi wrote on 2025-06-26, 20:59:
Unfortunately I don't have a programmer, what is the next safest way to dump it in DOS?
Reply 424 of 537, by douglar
This should work--
DEBUG.EXE
N MRBIOS.BIN
R BX
1
R CX
0
W F000:0
Q
should look like this when you run it:
DEBUG.EXE
-N MRBIOS.BIN
-R BX
BX 0000 :1
-R CX
CX 0000 :0
-W F000:0
Writing 10000 bytes
Q
fyi: 10000 bytes = 64KB
Reply 425 of 537, by Pino
Thanks!
Here it goes, I made 2 copies one using your DEBUG instructions and one with the NSSI software mentioned on the first page of this thread.
Hopefully it works.
Ps.: Amazing that this old 486 VLB board with this BIOS booted DOS from my 32GB SD card.
Reply 426 of 537, by maxtherabbit
both of those binary files in the archive are identical
fyi you can use the DOS command FC /B to do a binary compare
Reply 427 of 537, by jheronimus
Pino wrote on 2025-06-27, 01:54:
Thanks! […]
Thanks!
Hopefully it works.
Thank you so much!
I quickly tested it in 86box, seems to work just fine, will be testing on real hardware eventually.
MR BIOS catalog
Unicore catalog
Reply 428 of 537, by CharlieFoxtrot
Anonymous Coward wrote on 2020-05-02, 13:45:
I tried SiS Rabbit, C&T Peak/DM and Topcat MR-BIOS. None of them can enable the cache on the boards. It's kind of disappointing because these are all high performance chipsets that could have really benefited from MR-BIOS tweaks. Only the Topcat chipset can be excused, because this chipset doesn't natively support cache...that comes from a 3rd party controller.
Question to rather old post, but here it goes.
I recently obtained Octek Jaguar 386 motherboard. It is the first Jaguar released around 1990, so not later Jaguar II or Jaguar V. It is equipped with Rabbit chipset and 64k cache on the mobo. I burned the MR BIOS Rabbit BIOS for the chipset and to me it seems to work just fine. However, if I use something like NSSI, it claims that there is no cache even though cache is enabled on the bios, but CACHECHK utility shows the cache just fine. Performance is also right about there where I expect a 33MHz DX to be that is installed on the board.
So what did you use to verify that cache is not enabled on boards with MR BIOS?
Reply 429 of 537, by Anonymous Coward
I observed the speedsys memory graph and benchmarked with 3dbench. The cache was definitely not working.
Reply 430 of 537, by CharlieFoxtrot
Anonymous Coward wrote on 2025-07-23, 23:34:
Yeah. Maybe my chipset is then after all some later revision then. It would be interesting to know why it works with some Rabbit boards, but not with others.
Do you know how the turbo is handled with your mobos, because that is one thing that could be different I suppose. My mobo has both the physical and software turbo with keyboard and you can set the turbo in MR BIOS for default system setting. The turbo in my board just disables or enables the cache. In other words, when the system is se to high speed in MR BIOS, cache is enabled and vice versa. If your mobos have different type of scheme, the turbo setting in bios may affect to cache operation. MR BIOS seems to have few different BIOS versions for different turbo schemes, but you probably tested them all.
Reply 431 of 537, by Anonymous Coward
I’m pretty sure the turbo on my board also toggles the cache. It’s something I could look into again, but this board isn’t high priority for me at the moment as it fails to POST when DLC/SXL cpus are installed. It’s odd as my board supports hidden refresh.
Reply 432 of 537, by douglar
Anyone notice those new old stock Seanix ASI 9000 486 computers getting sold on ebay canada?
They have MR BIOS 1.60 OPTI4A7. That’s one that’s not on the lists.
The attachment IMG_2855.jpeg is no longer available
Reply 433 of 537, by theelf
hi, someone have the Sarc RC2016 ?
Reply 434 of 537, by ASTSix-Pack
Here is one from a Jamicon board with an OPTi
82C481/482/206 chipset. BIOS is ver 1.0C from 1990
Reply 435 of 537, by douglar
Wow! I don't think I've ever seen older than 1.45.
Reply 436 of 537, by analog_programmer
I can't find any "V064B3*" folders and files for mobos based on SARC RC2016Ax chipsets inside the archive downloaded from this link. Where I can find them?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 437 of 537, by jheronimus
analog_programmer wrote on 2025-08-21, 04:46:
They are mentioned in the Microid docs and elsewhere, but to my knowledge, were never actually found (that's why there's nothing in the "versions found" column)
MR BIOS catalog
Unicore catalog
Reply 438 of 537, by analog_programmer
jheronimus wrote on 2025-08-21, 07:50:
So, in order to know if the BIOS dump-file is available in the archive collection, we've to look at "versons found" column, when using "MR BIOS archive v2" document, and the rest is just "possibly released MR BIOSes", right?
Reply 439 of 537, by jheronimus
analog_programmer wrote on 2025-08-21, 11:12:
Yes
MR BIOS catalog
Unicore catalog
