Reply 420 of 467, by FreddyV
digger wrote on 2026-09-07, 17:20:
Hi @FreddyV. Got it. IRQ3 only. […]
FreddyV wrote on 2026-09-07, 16:09:
Hi @digger
For tandy 1000 EX, you should keep only the IRQ3 wired. Only 2,3,4
Picomem 2 multiplexed irq is still only on IRQ7
What exactly do you mean with "Only 2,3,4"? Those can't be IRQs. Do you mean "remove jumpers 2, 3 and 4", since I should only have jumper 1 in place for IRQ 3?
I'm going to try it tonight and share my findings here.
Thanks!
Only 2,3,4 exist on the header, so only 3 is usable
Reply 421 of 467, by FreddyV
Hi,
It detect IRQ5 as the tandy 1000 video use it...
So the picomem see it fired, but it is an error.
It will then try to use irq5 as picomem irq, but picomem 2 irq is hardcoded to irq5.
So, I have to mofify the firmwareto correct those things.
Once done, I should allow the emulated DMA to work at the same time as real dma.
Then, SB can work as well.
Picomem 1 has virtual dma working on the ex/hx.
You can also use mod master XT to use GUS. No need of dma/irq
Reply 422 of 467, by digger
FreddyV wrote on 2026-09-08, 14:54:
Hi, It detect IRQ5 as the tandy 1000 video use it... So the picomem see it fired, but it is an error. It will then try to use ir […]
Hi,
That might explain the instabilities I was experiencing, especially when trying to use the PicoMEM 2 to increase the RAM on the machine. The test results of PICOMEM.EXE would sometimes fail, sometimes not, at some point I got random ASCII art filling the screen, sometimes I would have random lock-ups on the DOS prompt, and Monkey Island (the 16-color version) would always start up with a garbled screen and then quit with a heap corruption error. I would also get the garbled screen when forcing the game to run in CGA mode, just with only 4 colors of random pixels instead of 16.
Graphical applications that would work with 256KB or less ran fine, even with the PicoMEM 2 installed: Alley Cat with the Tandy patch and os8088.
Using only the PSRAM (and not the Pico's faster zero-waitstate RAM) for emulating all the RAM did appear to make the RAM tests of PICOMEM.EXE pass, but Monkey Island sill wouldn't run.
I also noticed the memory configuration in the PicoMEM 2 setup resetting or changing sometimes after a restart or power cycle.
That would be pretty cool! Sound Blaster support on that machine would merely be a nice-to-have to me, since the on-board 3-voice synthesizer is the machine's charm, but it's still fun to play with.
I made some screenshots of the various PICOMEM.EXE test runs. Let me know if those are useful to share. Maybe I can have those results written to log files instead. Does PICOMEM.EXE have an option for that? Or maybe I can just redirect the output.
I'm currently running it with DR-DOS (SvarDOS), in case that matters.
Would it be possible to add Disney Sound Source (DSS) emulation to the PicoMEM 2, in addition to just Covox Speech Thing emulation? The Sound Source would be a period-correct sound device for this machine, which would compliment the 3-voice synthesizer well with buffered PCM output and some support in games that can run on PC/XT systems. And it requires neither IRQ nor DMA. You might be able to port the DSS emulation code from the Picovox firmware, which is based on the same microcontroller as the PicoMEM 2.
Happy to help with troubleshooting/debugging with any of this.
Thanks!
Reply 423 of 467, by digger
Hi,
I got Monkey Island to run by adding a config.sys file to the root directory of the SD card with the following contents:
IRQ 3
TANDY 256
Gameplay seems fine, although the mouse doesn't work, even when I have PMMOUSE loaded. During boot, the PicoMEM2 does detect the Logitech mouse that I have plugged into its USB port.
I will try some other games or applications with mouse support, to see if that's just with this game.
Also, when I quit the game, it hangs in text mode with a blinking cursor, and sometimes the background weirdly starts changing colors. But gameplay itself seems fine, at least with the aforementioned configuration on the SD card.
Reply 424 of 467, by digger
mbandalauk wrote on 2026-08-08, 13:47:
Hi, […]
Hi,
Has anyone tested the PicoMEM 2 with Sergey Kiselev's Micro 8088 computer? I am doing some testing with this setup, and almost everything works like a charm: Wi-Fi, HDD emulation, floppy emulation, sound, and RTC, except for the USB mouse. The PicoMEM 2 BIOS reports that a USB mouse device has been detected. Of course, I have played around quite a lot with the PM2 BIOS settings (USB Host: On, USB Joy: Off, etc.). My setup has no extra hardware, just the Micro 8088 (BIOS 1.02), Sergey's VGA card, and the PicoMEM 2. See the attached photo.
I have tried Freddy's own disk HDD images (D33_ENG.img and D622_500M.img). Both Microsoft's MOUSE.COM driver and CTMOUSE fail to detect the mouse. Oddly, PMMOUSE seems to detect and load a PS/2 mouse correctly, but unfortunately, the mouse itself does not work. I have also tested the bootable Svarog86 FreeDOS floppy image, but CTMOUSE fails to detect anything there too.
I have also tested older versions of the Micro 8088 BIOS, with the same result. I have tested several different mice as well. If you think I am missing something here, please let me know. Thanks!
Ah, so I'm not the only one who couldn't get PMMOUSE to work in a PC/XT class (8088 or V20) system. I did notice PMMOUSE printing a message on screen advising people with non-VGA systems to try another driver. But since @mbandalauk couldn't get it to work in a Micro 8088 with a VGA card either, that's not the problem,then. Did anybody else get a USB mouse to work on the PicoMEM 2 with PMMOUSE or any other mouse driver?
Reply 425 of 467, by Cloudschatze
digger wrote on 2026-09-09, 21:14:
IRQ 3
TANDY 256
While counterintuitive (given the IRQ 5 discrepancy), you'll need to remove that "IRQ 3" parameter in order for the mouse to work.
Reply 426 of 467, by FreddyV
Picomem.exe is an early test testing hardcoded address, it is not relevant.
Reply 427 of 467, by digger
Cloudschatze wrote on 2026-09-10, 01:30:
Thanks for that piece of advice! 😃 Indeed, that made the mouse work in my setup too. I've tested it with Monkey Island 1 (the 16-color version) and King's Quest IV (the SCI0 version).
Graphics, sound and mouse support was fine in both games, but the remaining issue is still that when I quit either game, the system hangs in text mode. Sometimes a blinking cursor on the upper left on the screen, sometimes a text-mode screen filled with random characters and CP437 glyphs with random foreground and background colors, some of them blinking. The system is then completely unresponsive. CTRL-ALT-DEL doesn't work at that point.
By the way @Cloudschatze, how did you mount your PicoMEM2 in your Tandy 1000 EX ? Did you use the same PLUS-to-ISA riser card from Tindie? Or did you find another solution? And how did you secure the card in the case?
Reply 428 of 467, by FreddyV
@Cloudschatze use the latest test firmware adding CD.
I work to improve the IRQ code now.
Reply 429 of 467, by Cloudschatze
digger wrote on 2026-09-10, 22:23:
I'm using two PLUS-to-ISA adapters, along with a repurposed backplate from an RS-232 PLUS board to give the VGA card/connector some support. Not the greatest to look at, but it's fairly secure.
Reply 430 of 467, by Electronizer
I have an IBM 5150 with floppy drive and CGA card that I’d like to get working. I don’t have any software, so it sounds like Picomem 2 is a great solution. I also don’t have a keyboard. I see a few posts that mention a USB mouse, but it sounds like USB keyboard support is still under development—is that correct?
Reply 431 of 467, by FreddyV
Hi,
New PicoMEM 2 is out with CR-ROM and ROM emulation.
CD-ROM and CD Audio are added, with CD BOOT support.
You can also add any option ROM, like GlaTick for full DOS Real time clock support.
### PM2-10-4-26: CD-ROM and ROM emulation
- + CD-ROM and CD Audio emulation added (MKE Interface)
- + ROM emulation added : ROM image is configured in the config.txt file
- + HDD and Floppy images can now be selected from USB
- + CD-ROM selection and CD player added to the PicoMEM Front Panel
- + Front panel can be controled by a USB Joystick (Home+Right button)
- + OLED display when a Joystick is plugged in
- + ADPCM added in the Sound Blaster emulation (Duke Nukem 2)
- + ArdSynth rendering added to the General MIDI mode. (https://github.com/DLehenbauer/arduino-midi-sound-module)
- + Multiple PicoMEM POST Code added
- ! SB DSP Does not answer init end directly
- ! IO ports emulation code called from a table
- ! PicoMEM interrupt can be defined to any IRQ (IRQ parameter in config.txt)
- ! Multiple bug fix in the RTC emulation for GlaTick support
- ! Now the PicoMEM written file has the correct date/time (PMDFS, Config)
- ! Multiple bug fix in the DFS code (USB/SD access)
- ! Sound Blaster IRQ/DMA config was not implemented (Was using default)
- ! Define Use PicoMEM Boot by default
https://github.com/FreddyVRetro/ISA-PicoMEM/t … rmware/PicoMEM2
Reply 432 of 467, by dreamblaster
wohooo !! amazing work !!
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 433 of 467, by Vivid Warthog
Hi!
Just wanted to share that I've made some work on the PicoMEM (2.0) FW fork that focuses heavily on Sound Blaster compatibility and audio quality, plus some QoL improvements (like full setup via config.txt, so no PMINIT call is needed or firmware update from SD and access to SD card with HTTP over WiFi - so no more need to unscrew the pc tower to update the card 😁)
There are also some bugs fixed, but all mentioned in CHANGES.md file.
So if you are using PicoMEM2 for SB/FM audio, you can check it out:
https://github.com/HitoriSensei/ISA-PicoMEM
Or just directly into releases page to get the FM/Drivers: https://github.com/HitoriSensei/ISA-PicoMEM/releases - but PLEASE read the readme, as there are two .uf2 files, and the partitions.uf2 is only needed to be flashed if you want to be able to later update the FW from the SD card (without physical access to BOOTSEL button)
Side note: The firmware is based on pre-cdrom source (the only available), so the new CDROM features from the above FreddyV's post are not part of this fork.
Reply 434 of 467, by megatog615
Vivid Warthog wrote on 2026-10-11, 11:20:
Hi! Just wanted to share that I've made some work on the PicoMEM (2.0) FW fork that focuses heavily on Sound Blaster compatibili […]
Hi!
That's a lot of documentation... did you use AI for this?
Your AI slop bores me.
Reply 435 of 467, by Vivid Warthog
Sure, AI was used to setup and execute the spectral analysis benchmark which results are in the "audio quality" doc and for adding details to the entries in readme and changes file.
Reply 436 of 467, by megatog615
Vivid Warthog wrote on 2026-10-12, 08:15:
Okay, just make sure you disclose that. It's in the forum rules.
Reply 437 of 467, by Vivid Warthog
Sure, sorry! Haven't read the rules since a very long time.
Also please excuse the rapidly written AI-helped readme and changes docs, I had just one last day of my vacation to gather all the notes and changes and document them and post the FW release before getting out of the basement 😅
Reply 438 of 467, by RetroBard
I’ve been struggling to get either PicoMem or PicoMem2 to work with my Schneider EuroPC1. I did some studying on the EuroPC memory map, and with CC00 as the start address, I finally got some signs of life out of either card.
PicoMem2:
IMG_1271.jpg?ex=6ace8dc5&is=6acd3c45&hm=933b3b5718ec5caebdeb2ecdf032609b5cd660c67db5423dbe5a20512459affa&
PicoMem1:
IMG_1272.jpg?ex=6ace8dc5&is=6acd3c45&hm=a33a3e856ef81650d63dc210bcd8f01197a1c4fde9278cc9365ba34c18b2d905&
This is the furthest I’ve gotten with the cards in the EuroPC so far. Nevertheless, I’m still quite not there yet as the PC crashes with these errors and I have to power cycle it.
I think it’s a matter of finding a suitable start address for the PicoMEM ROM. With D000, C800 and CA00, the cards aren’t detected. CE00 gives me a ROM checksum error, and CC00 behaves as described above. AI says that C000 is the option ROM start address for the EuroPC, but I haven’t yet tried that out, because the AI has made pretty interesting suggestions regarding this issue. Might as well give that a go too, though.
Reply 439 of 467, by megatog615
Vivid Warthog wrote on 2026-10-12, 10:54:
You have to disclose it in the post.
