HiRes/Widescreen Patch for Mech Warrior 3
Reply 44 of 75, by gerwin
gerwin wrote:
Edit: Based on your patch v0.4, I made another patch that can add 1440x1080 (Attached).
Today I updated my personal 1440x1080 version of the MechWarrior 3 resolution patch a little
1) Replaced the original 1600x1200 resolution instead, which makes the HUD properly centered.
2) Hand picked all executable changes from the sources available.
Edit: 3) Now applies to the clean v1.2 executable.
Also attached my DxWnd configuration for this game. Using DxWnd with this configuration I can run MechWarrior 3 without issues on a Windows XP PC, even when using an AMD Radeon HD6670 GFX card. DxWnd takes care of all graphics and speed related issues AFAIK.
My default is 1440x1080 fullscreen, but that may require one to add this custom resolution in windows, as unfortunately it is not stock.
The only remaining thing that I can complain about, is that I cannot find how to force FSAA-2X this way.
The attachment DxWnd-screen.png is no longer available
Reply 45 of 75, by lowenz
Not patch 1.2 compliant?
Reply 46 of 75, by lowenz
With v5 of the Teleguy exe your patch can't mod the exe 😒
Reply 47 of 75, by gerwin
No, MechW3_1440x1080B requires either an original mech3.exe or a No-CD patched one, of version 1.2.22.0, being 2.384.384 Bytes. Why would you want to double patch with Teleguy's?, It will cause trouble.
Reply 48 of 75, by lowenz
Re-installed the patch and got "wrong size" message.
Reply 49 of 75, by gerwin
You need to add the 1440x1080 custom resolution to Windows or use DxWnd to run it in a window at that resolution.
Reply 50 of 75, by lowenz
"Wrong Size" of the exe in the patching process.
Reply 52 of 75, by teleguy
Doesn't work for me either. I even re-downloaded the 1.2 patch again from here http://www.moddb.com/games/mechwarrior-3/down … 2-english-patch to doublecheck.
(You can extract Mech3.exe with Universal Extract and this plugin ftp://ftp.elf.stuba.sk/pub/pc/pack/i5comp21.rar so you don't have to actually apply the entire patch.)
File version says 1.2.22.0 .
PS: Could you upload a screenshot that shows how the HUD looks with the 1600x1200 preset?
Reply 53 of 75, by gerwin
Yeah, I guess MechW3_1440x1080B insists on the No-CD patch being applied already, I will fix it...
Reply 54 of 75, by teleguy
I asked AncientxFreako if he could resize the HUD like he did for the other resolutions since he owns the necessary mod tools but he's currently too busy with his other projects so I made some adjustments via hex editing.
The attachment Mech3-1440-1080c_2018_03_07_16_57_20_182.jpg is no longer available
Reply 55 of 75, by gerwin
I investigated the matter a little:
What I had used as the reference mech3.exe, actually already was patched twice. Once with the Razor 1911 No-CD, once with a 1024x768 compatibilty patch of unknown origin.
The second patching I mentioned, I have difficulty tracing its origin, but it is somehow essential to running Mech3.exe on my system, because without it the game crashes immediately. This second patching also touches the exact same bytes that are involved with the right limitation of the target triangle.
Anyways, I updated my 1440x1080 patch above to apply to an actual original exe now. The screenhsot shows what I get with it.
Another thing though, earlier this evening the HUD was actually different and partly off the screen to the right, and I don't know what caused it and rectified it again. So I have to investigate that, and also investigate+document exactly what each small change in all these mech3.exe modifictions actually do, because it is getting rather complicated.
Reply 56 of 75, by teleguy
That's EOP's Res Fix.
This is what he told me via email about it:
It's been a while since I found the bug but if memory serves there's a rounding error in the line drawing code used for stuff like targeting boxes so if they get too close to the bottom (and possibly right) of the screen (like re targeting something close by) they try and draw outside the buffer and cause the process to crash. As the screen res increases the rounding error increases so it gets easier to cause the crash. It happened a lot at 1600x1200.
Unfortunately, according to one of his old forum posts, that patch only partially fixes the issue and also has to be tailor made for each separate resolution.
He made a more advanced version utilizing a launcher that takes into account the locations in the exe he missed the first time and would also fix every resolution simultaneously. I never found a working download link for the newer patch though.
This is also supposed to fix it.
https://mwomercs.com/forums/topic/238132-runn … r-3-with-dxwnd/
Reply 57 of 75, by teleguy
Curious. The HUD should either be too big or crash the game immediately.
Reply 58 of 75, by gerwin
Thanks alot teleguy for the background on EOP's Res Fix. So I was messing with EOP's changes there... Sorry to hear that EOP's later work is lost.
I updated my patch again, it is now revision E. Link
It does the following:
1) Removes CD Check (addresses: 175190, 1751E0, 1751F0, 1990B0)
2) Has EOP's changes around address 197E10 (5x). So the game does not crash my XP system immediately. I now left out the other changes from EOP.
3) In-Game-Menu crash fix as found in your resolution patches, at addresses 1593EO and 159500.
4) Replaced resolution 1600x1200 with 1440x1080 at addresses 00CD60 (3x) and 179710 (1x).
teleguy wrote:
Yes, I am already using DxWnd with success here, my DxWnd config is attached next to the patch.
Reply 59 of 75, by teleguy
gerwin wrote:
I meant the "Force clipper" and "Handle Exceptions" options mentioned in that topic, didn't realize they were already part of your config.
Reply 60 of 75, by gerwin
The "Force clipper" option is gone in the latest DxWnd version, but I have set Clipper to 'ON' in the DirectX(2) section. Hoping it is the same thing.
Attached the bit where I changed the width resolution of EOP's targetting modification. A005h is 1440 pixels there, it used to be 1024. Note that this section of EOP's modifications is no longer included in my patch version E, at all. So it does not apply to it.
Reply 61 of 75, by teleguy
Here's a reg file that disables the compatibility database that prevents alt tabbing out of the game.
If it has no effect rightclick on Mech3.exe, change any compatibility setting and click on OK. Then undo your changes and click on OK again.
Might in theory cause some instability.
Reply 62 of 75, by lowenz
Windows 10 Fall Creators + dgVoodoo2 2.55 (OR NOT, the issue remains with Windows stock ddraw) + your patch + 1440x1080 added to Windows (but not forced in dgVoodoo2):
Any idea? Other fullscreen resolutions work and 1440x1080 forced through dgVoodoo2 works !
In my system the "8" value for resolution is 1152x864, "9" is 1280x1024 and "A" (10) 1440x1080 (so I set A)
Reply 63 of 75, by teleguy
lowenz wrote:
Windows 10 Fall Creators + dgVoodoo2 2.55 (OR NOT, the issue remains with Windows stock ddraw) + your patch + 1440x1080 added to […]
With my patch it should be 8 not A IIRC
