Battle of the platforms: socket 754!
Reply 440 of 860, by nd22
B. KU8
1600*1200
2025-10-31 06:23:42 - hl2
Frames: 3925 - Time: 60000ms - Avg: 65.417 - Min: 17 - Max: 91
1280*1024
2025-10-31 06:26:28 - hl2
Frames: 4227 - Time: 60000ms - Avg: 70.450 - Min: 54 - Max: 109
1024*768
2025-10-31 06:25:07 - hl2
Frames: 4236 - Time: 60000ms - Avg: 70.600 - Min: 57 - Max: 99
Reply 441 of 860, by nd22
C. KV8
1600*1200
2024-12-26 09:00:15 - hl2
Frames: 3969 - Time: 60000ms - Avg: 66.150 - Min: 51 - Max: 89
1280*1024
2024-12-26 09:03:13 - hl2
Frames: 4238 - Time: 60000ms - Avg: 70.633 - Min: 17 - Max: 116
1024*768
2024-12-26 09:04:50 - hl2
Frames: 4711 - Time: 60000ms - Avg: 78.517 - Min: 57 - Max: 99
Reply 442 of 860, by nd22
Again ULI takes a severe hit because of AC97 codec poor implementation. Either Abit deliberately cheaped out or engineers made a few errors. I am inclined to believe the first as - contrary to NF8 and KV8 - KU8 has only 3 audio jacks so they cut corners everywhere!
Reply 443 of 860, by nd22
46. Doom 3 is the first opengl game to be tested and, because of performance issues I chose to test with AA disabled but at ultra quality and all advanced settings ON. Again the in game test does NOT use sound.
1024*768
A. NF8
B. KU8
C. KV8
Reply 444 of 860, by nd22
47. We are already below 60 FPS average so taking Doom to the next resolution will make the framerate even lower:
A. NF8
B. KU8
C. KV8
Reply 445 of 860, by nd22
48. At 1600*1200 we are completely GPU limited and during actual gameplay it will drop to the low 30's - still playable but only just!
A. NF8
B. KU8
C. KV8
Reply 446 of 860, by nd22
49 & 50 & 51. The second opengl game is Quake 4. Extremely demanding, I used hardwareOC quake 4 bench tool for testing which is a blessing - during actual gameplay you will run out of memory and out of FPS with the poor 7800gs!
A. NF8
B. KU8
C. KV8
Reply 447 of 860, by nd22
There is nothing to see as the game is actually unplayable - you need more RAM and a much more powerful video card!
Reply 448 of 860, by nd22
52. The last game to be tested is the 2005 system killer FEAR. For ease of use and ease of comparison the first screenshots at 1024*768 have maximum selected for both computer and graphic card. However when you select both AA and soft shadows (SS) simultaneously SS will actually be disabled. You have to select sequentially - AA first and exit to main option menu and SS second in order to have them both enabled. SS would annihilate the geforce 7800gs so it is far better to leave it off for any directx9 GPU!
1024*768
A. NF8
B. KU8
C. KV8
Reply 449 of 860, by nd22
When you start with a 42 average FPS you know things are bad!
53. 1280*1024
A. NF8
B. KU8
C. KV8
Reply 450 of 860, by nd22
Things are looking really bad at 1280*1024!
54. However at 1600*1200 are looking horrible!
A. NF8
B. KU8
C. KV8
Reply 451 of 860, by nd22
FEAR is not playable on such a system regardless of the resolution! You need a geforce 8800 GTX at a minimum to actually be able to enjoy the game and even with that card you will be limited to 1024*768!
Reply 452 of 860, by AlexZ
So 3400+ 2.4Ghz is a good alternative. There is a very small performance penalty in games due to smaller cache, but at ~60 fps it is only about 1-2 fps thus ok. It is slightly better in synthetic benchmarks at the same time so the PR rating seems fair. Clawhammer has larger L2 cache but this cache has terrible latency.
Now the question is why should one buy s754 Athlon 64 with AGP instead of s462 Athlon XP. What does one gain in practice. What is the difference in performance between nForce2 and s754 boards.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 453 of 860, by nd22
All I can say at this point is: Wait for part 2 😀 !!
Reply 454 of 860, by nd22
55. Game testing is finished, we are now testing a non-3D benchmark: super pi!
Reply 455 of 860, by nd22
Nothing to see here, moving right along to the second to last test:
56. Cinebench 2003 - This is the oldest version I could find when i started testing 7 years ago. Meanwhile, a Youtuber, known as Fully Buffered, managed to found an even older version as seen in this video:
https://www.youtube.com/watch?v=bPBLHSZd6Hg
Because changing version would brake accuracy and backwards compatibility of results I sticked to the version I have been using since 2018 which by the way is single threaded!
Reply 456 of 860, by nd22
The integrated memory controller is doing the job it is supposed to do: all platforms perform within 2% of each other!
Reply 457 of 860, by nd22
57. And we reached the final test: Tom2D. Until now there was no great difference between the 3 platforms; only in 3dmark 2001 did VIA got a lead and in PCMARK nforce3 fell behind the other 2 in the graphics and storage tests. There was no benchmark with huge discrepancies! However...
A. NF8
B. KU8
C. KV8
Reply 458 of 860, by nd22
VIA takes no prisoners and kills again both NVIDIA and ULI in the final benchmark!
Reply 459 of 860, by AlexZ
The results of VIA use picture with 2.2Ghz CPU, not 2.4Ghz.
