EAX appreciation thread
Reply 441 of 1234, by UCyborg
UCyborg wrote on 2025-05-26, 17:29:
These Audigy drivers remind me of old ATI drivers. Several days ago I was testing something on Win11, the OS just blue screened when I disabled sound card in Device Manager.
Though to be fair, ATI liked to crap out during actual gaming, not testing odd scenarios.
I was playing a bit of Drakan, EAX effects are so subtle that they might as well not be there. On Audigy RX at least. I've read anecdotes X-Fi's EAX sounds different. In Drakan, with software based EAX, I could at least tell reverb was there. Then go and figure how it was intended...what a mess!
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 442 of 1234, by Joseph_Joestar
UCyborg wrote on 2025-06-08, 08:38:
I can't speak for Drakan, as I haven't tested its EAX implementation extensively. However, there are other games from that era (late 90s, very early 2000s) where EAX only sounds correct if you play them under Windows 9x using VxD drivers for the sound card.
Notable examples include Baldur's Gate 2 and Need for Speed 4: High Stakes. Phil showcases the latter in this video around the 7:21 mark.
My retro stuff
Reply 443 of 1234, by UCyborg
Never mind, I'm misremembering...brain playing tricks on me again...
Joseph_Joestar wrote on 2025-06-08, 09:04:
Weren't those just the problems of the era? Plenty of shit was bugged back then.
Reply 444 of 1234, by Joseph_Joestar
UCyborg wrote on 2025-06-08, 11:24:
A few games made before 2001 seemingly expect VxD drivers for EAX functionality, as that was the norm back then. At least that's what tests conducted on period-correct hardware infer.
You could say it was a developer oversight to focus on VxD so much, but WDM drivers were still relatively "new" at that time, and people mostly used them for professional tasks (e.g. music production) and not for gaming. Thing is, WinXP can't use VxD drivers at all, meaning you're stuck with WDM. So those few games will never sound 100% correct when using EAX under WinXP and up. And no, Creative's ALchemy doesn't solve this.
My retro stuff
Reply 445 of 1234, by auron
sharangad wrote on 2025-05-31, 04:34:
And here's doom 3 on the Audigy RX. It's a bit long, a playthrough of the first two levels:
https://youtu.be/kzOWqKrP8y8
might be totally wrong here but i remember the reverb effects being much stronger on a 2zs. that has the visual twitch bug unless (possibly) using old XP beta drivers though. all the "fixes" that i've seen out there use openal soft only so not relevant for trying to use actual audigy cards.
Reply 446 of 1234, by sharangad
auron wrote on 2025-06-08, 11:56:
I remember it being stronger, but at that time I had an x-fi extreme music.
https://patreon.com/Rready
Reply 447 of 1234, by KainXVIII
I haven't heard any special effects in Drakan on X-fi (+win10) until i realized that EAX effects were disabled in my Creative audio control panel (in game mode) for some reason 🤣. After turning it back on (you can also increase effect amount with +1 or more dB) i can definitely hear reverb in the first cave under the tavern.
Reply 448 of 1234, by UCyborg
Is that how it's supposed to work on X-Fi? The only EAX settings Audigy has apply system wide, so chosen preset is applied to any sound that is played by any program, which is not something you normally want (probably). Also, EAX doesn't work in Drakan if disabled in Riot Engine Options dialog or if you load a saved game made while EAX was disabled.
I also noticed in Half-Life 1.1.1.0, current EAX effect is apparently not stored in the save file, so if you load a save made while effect was active where you were standing, it won't be heard after load until you pass another trigger in the environment activating it. Like I said, old shit's bugged!
Reply 449 of 1234, by auron
UCyborg wrote on 2025-06-08, 17:00:
can confirm that, but that game to me is otherwise still a solid implementation, especially for an "early" title.
Reply 450 of 1234, by KainXVIII
Seems so.
The attachment Снимок экрана 2025-06-08 212746.png is no longer available
Reply 451 of 1234, by UCyborg
I see, does this dialog update in real time when you're playing EAX enabled title, seeing it has Active Preset box? Or maybe that applies if you've set global EAX effect in another place?
Reply 452 of 1234, by sharangad
UCyborg wrote on 2025-06-08, 19:23:
It did on an X-fi back in the day.
On the Audigy RX it's already at max:
Has anyone got Alchemy working on Win11? I can't get a single game working with it.
Reply 453 of 1234, by shevalier
sharangad wrote on 2025-06-09, 02:26:
Why use this program at all?
Copy dsound.dll to the folder with the game executable file.
That's it.
Read the dsoundlog.txt file that appears after launching the game
If there is an inscription "Using Native OpenAL Renderer" then everything worked.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 454 of 1234, by Joseph_Joestar
I don't have Win11, but ALchemy works fine on Win10 LTSC.
One thing to note, ALchemy targets retail games, and uses their registry entries for detection. For that reason, GOG/Steam versions of games might not be automatically detected. You can try adding them manually though.
My retro stuff
Reply 455 of 1234, by sharangad
shevalier wrote on 2025-06-09, 05:00:
Why use this program at all? Copy dsound.dll to the folder with the game executable file. That's it. Read the dsoundlog.txt file […]
That's it.
Doesn't work, the log file either says using openal or some error. In both cases the games don't detect eax support.
Nfs hot pursuit [2s]3[/s] and thief deadly shadows demos don't detect it. I don't know whether it's because they're demos. But I remember the Nfs hp2 demo did support it way back then.
Also I've applied the reg key tweak to load dsound.dll from the local folder instead of from system32 (something win11 does to known dlls).
Reply 456 of 1234, by sharangad
Joseph_Joestar wrote on 2025-06-09, 05:07:
I added the games manually based on the folders and used manual settings for buffers. Nfs for instance doesn't start up unless I know the number of voices down to 32. Maybe my settings are wrong.
For thief, I added the game and its system folder.
Reply 457 of 1234, by sharangad
I no longer have disc based versions of these.
Reply 458 of 1234, by sharangad
The GOG version has EAX patched out somehow, I remember someone complaining about it somewhere.
Reply 459 of 1234, by Joseph_Joestar
sharangad wrote on 2025-06-09, 05:37:
Yeah, I've seen this in a few of their releases, including Splinter Cell.
At least for that one, there's an Xdelta patch which restores it.
My retro stuff
