Reply 460 of 487, by keropi
Shponglefan wrote on 2026-04-17, 17:19:
I would assume with the feature connector, using something like a CRT Terminator could be an option for getting digital out?
this is the reason we put the feature connector
I have a crt terminator , never used it though
I will update and test eventually 😁
Reply 461 of 487, by BaronSFel001
Is the PCMIDI addition still an option? It's just a thought for now, but that thought is consideration of turning my Roland LAPC-I into cash if I can get all its capability bases covered with other devices while remaining in the black.
System 20: PIII 600, LAPC-I, MK1869 Xtreme, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 462 of 487, by aitotat
That SonicVision PRO looks amazing all-in-one card!
Any available card with CL-GD5434 is already wonderful but I really like the idea of a quality late Opti-based sound card implementation. Those otherwise nice sound chips too often appeared only on cheapest cards.
My youtube channel
Reply 463 of 487, by keropi
BaronSFel001 wrote on 2026-04-30, 16:24:
it sure is, we still have some extras
aitotat wrote on 2026-05-01, 07:35:
thanks!
I also like the 930 - I find it a very compatible chip that will just work with everything sb-related
Reply 464 of 487, by igna78
@Keropi
I think it's time to start a trend with SonicVision PRO, what do you think?
But most importantly, when do you think we'll be able to have it in our retro PCs? 😁
Reply 465 of 487, by keropi
igna78 wrote on 2026-05-01, 09:33:
@Keropi
soon and somewhat soon 😁
Reply 466 of 487, by igna78
keropi wrote on 2026-05-01, 09:36:
@Keropi
Wonderfull 🤗
Reply 468 of 487, by appiah4
Ugh.. I completely missed out on this.. *facepalm*
Reply 469 of 487, by crusher
Excuse me, but I have a dumb question.
Is the MK1869 SB Pro 2.0 compatible or "just" SB Pro?
Reply 470 of 487, by Kahenraz
It's the other way around. Even Creative never claimed its cards were backwards compatible with the original Pro version, because of the dual OPL2 chips. Whenever someone claims "Sound Blaster Pro" compatibility, it's pretty much always shorthand for 2.0.
The original Pro used two Yamaha YM3812 (OPL2) chips, dedicating one to each stereo channel. The Pro 2 upgraded to a single Yamaha YMF262 (OPL3) chip.
Reply 471 of 487, by akimmet
I had a chance to try out my MK1869 XTREME this weekend. Both the ESS and Interwave sound great. Much less noisy than other ISA sound cards.
I was more surprised by the low frequency response for both Sound Blaster and GUS output. Very noticeable with the main menu music for Epic Pinball.
Reply 472 of 487, by keropi
akimmet wrote on 2026-05-26, 17:05:
glad you are enjoying the card 😁
thanks for the support!
Reply 473 of 487, by Damiano.78
Hello, I know this might not be the right place, but I haven't seen a thread about the Sonic Vision PRO yet, and I have a question for Keropi: I might be interested in purchasing this fantastic all-in-one ISA card as soon as it's available, and I'd like to plug it into a GA-6BXC rev2.0 motherboard in one of my Via C3 builds. In this build, I'll be using my GeForce3 Ti200 in the AGP slot. Since my motherboard (like many i440BX Slot1 motherboards) has the option in its BIOS to select the primary video card between AGP and PCI, and considering that I've read in general (and also here on Vogons) that ISA VGA cards always have priority in the case of the co-presence of an additional VGA card on the PCI bus, my question is this: have you tested whether it is possible, by selecting the primary VGA PCI card in the BIOS of an i440BX motherboard with an AGP slot (and which offers this option in its BIOS to select the primary video card) if, by selecting PCI (and having no other VGA PCI card inserted, but only the VGA AGP card) the VGA ISA card can start and therefore, in your Sonic Vision PRO, the Cirrus Logic CL-GD5434 chip loads its BIOS in the high mapping dedicated to video cards in DOS?
I'd love to be able to run an AGP graphics card alongside the Cirrus Logic graphics card in your Sonic Vision PRO, and be able to manage this from my motherboard's BIOS just as if it were the classic AGP or PCI priority VGA graphics card at boot time.
My goal would be to use the Cirrus Logic graphics card in the Sonic Vision PRO to achieve register compatibility with the older CGA, EGA, and Hercules graphics modes, which the GeForce obviously doesn't support natively.
Reply 474 of 487, by Damiano.78
So let me explain in a much more concise way.
In the Init Display First menu in the BIOS of my GA-6BXC rev2.0:
I select AGP: my AGP VGA card starts (GeForce3 Ti200 in my case).
I select PCI: the ISA VGA card starts since I don't have a PCI VGA card (in the case of the Sonic Vision PRO, the Cirrus Logic CL-GD5434 will start).
Keropi, can you please do or have you already done a test like this?
Reply 475 of 487, by Shponglefan
Damiano.78 wrote on 2026-07-06, 09:45:
I've tested ISA/PCI/AGP video combos on a Pentium 4 setup. In my experience, the ISA VGA card will take override priority regardless of whether the motherboard is set to AGP or PCI. The only way to disable the ISA VGA video is if it can be done on the card directly.
I asked earlier if it would be possible to have an option to disable the VGA portion of the Sonic Vision Pro and it was mentioned they may add a jumper for this.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 476 of 487, by keropi
no such tests are made - tbh because even if this works on paper one cannot know what each motherboard will do
this is not even the target platform of the card , if it works then good but we cannot guarantee that a pentium2 and upwards will cooperate as expected with the svpro
but we we have already added a jumper that disables the 5434 bios - not tested yet though as it's an upcoming proto feature
Reply 477 of 487, by Damiano.78
Thank you! Great for the jumper that lets us disable the CL-GD5434 VGA BIOS of the Sonic Vision PRO video card! This way, even if the ISA card always has priority in loading its BIOS at startup over the AGP and/or PCI VGA card, we can effectively make it secondary/completely excluded!
Reply 478 of 487, by appiah4
Damiano.78 wrote on 2026-07-07, 09:11:
I believe keropi made it very obvious that there is no guarantee that the jumper will actually do what you think it will, depending on the board and BIOS. You may disable it, but it may still get detected and the board may refuse to initialize a PCI/AGP adapter after that. You will have to try that on a case by case basis.
Reply 479 of 487, by BaronSFel001
Correct, but it will be interesting to see if it is possible because if so then it could have other applications for those of us with multiple video cards in our retro setups.
EDIT: Someone noted in an older topic that the Number Nine Imagine 128 came with this very capability. Since putting this particular combination of video/audio/ethernet into a single ISA card is uncharted territory anyway, it makes experimentation along the way that much more worthwhile.
