Reply 460 of 59302, by Robin4
- l33t
wrote:Can you post a picture please? I have pics and discussion of my Acer Magic S20 here Opti 82C929A - DOS driver anyone please?
I had trouble getting drivers to work with it, the ones I ended up using are in that thread. Also I never got sound in Doom engined games working, for some odd reason.
I have bought the one with the cd~rom interface. It would always be handy if having the cd~rom interface..
I dont have the card yet, but have to wait till it arrives here..
I found the orignal drivers here=
http://download.driverguide.com/driver/Acer+M … er/d890383.html
The only con is that you need to pay about 2 a 3 dollars for downloading it. So i think that are the orginal ones, otherwise they wouldnt protect it that hard from dowloading it.. If the card arrives i will test it. (AZTECH CARDS SUCKS, CANT FIND WORKING DRIVER FOR IT)
about the Acer Magic S20 drivers:
The Readme.txt says:
AcerMagic S20 LATEST INFORMATION
2.1A Release
(Non CD-ROM)
7/20/94
1. SOFTWARE PACKAGE CONTENTS
The AcerMagic S20 software package contains 2 pieces of 3.5"
1.44M diskette. These are the DOS plus Windows installation
diskette.
2. INSTALLATION/UNINSTALLATION PROCESS
The hard disk installation program, SETUP.EXE, will copy the
necessary files from AcerMagic S20 Setup disk into your hard
disk. Or, you can choose to uninstall them if you have the
AcerMagic S20 software installed but want to remove them.
Follow the following procedure to install or uninstall the
software:
(Assuming you are using floppy drive A:, and you wish to install
the software to C:\MAGICS20)
1. Place the disk labeled "AcerMagic S20 Setup Disk 1" in Drive A.
2. Type "a:" and press ENTER to change to Drive A.
3. Type "setup" and press ENTER.
4. Choose either "Installation" or "Uninstallation" item to
start corresponding process.
The installation process of SETUP.EXE will do the followings for
you:
a.) Create the directory \MAGICS20 in your hard disk drive.
b.) Prompt you for sound card options so that after you have
finished the installation and have rebooted your machine, you
will be ready to use the sound card.
c.) Copy the files in your floppy disk to the \MAGICS20 directory
and Windows directory respectively.
d.) Update your CONFIG.SYS, AUTOEXEC.BAT and SYSTEM.INI files.
In CONFIG.SYS, the following will be added:
DEVICE=C:\MAGICS20\CDIFINIT.SYS /T:X
In AUTOEXEC.BAT:
SET SOUND16=C:\MSGICS20
C:\MAGICS20\SNDINIT /B
SET BLASTER=A220 I5 D1 T4
PATH=%PATH%;C:\MAGICS20
In SYSTEM.INI:
[boot]
DRIVERS=... MSMIXMGR.DLL (appended)
[drivers]
WAVE=CS31BA11.DRV
AUX=CS31BA11.DRV
MIXER=CS31BA11.DRV
MIDI=OPL3.DRV
MIDI1=MPU401P.DRV
[386Enh]
DEVICE=VS20INIT.386
DEVICE=VSNDSYS.386
[SNDSYS.DRV] (newly created)
The uninstallation process of SETUP.EXE will remove the above
configurations.
3. VOLUME CONTROL TSR PROGRAM
The volume control memory resident program, VOLTSR.EXE, allows
you to change volume using hot keys while you are in a DOS
application. The hot keys are:
Ctrl-Alt-U Raises the volume
Ctrl-Alt-D Lowers the volume
Ctrl-Alt-M Mute/Unmute
For example, pressing the CTRL, ALT, and U keys will raise the
volume.
You need to load the TSR before you can use it. To load the TSR,
type VOLTSR at the DOS prompt.
4. KARAOKE PROGRAM
The KARAOKE.EXE program allows user to control the input volume
of the microphone on the fly with "HOT KEYS." Before using Karaoke,
the VOLTSR.EXE program must be successfully loaded and running.
To enable Karaoke Mode, type: "KARAOKE ON" at the DOS prompt.
To increase MIC input, use: Ctrl-Alt-PageUp
To decrease MIC input, use: Ctrl-Alt-PageDown
To disable Karaoke Mode, type: "KARAOKE OFF" at the DOS prompt.
5. AUDIO CD PLAYER: PLAYCD.EXE
The audio CD player program allows user to play audio CD in the DOS
environment. You can use mouse or keyboard to operate this program
just as your CD player at home. You can play audio CD, stop, skip
track, forward or rewind within track, and can select the specified
track directly.
You can also play the audio CD in random sequence(shuffle) or
arrange your favoriate play sequence by programming.
To run this program, type "PLAYCD" under the DOS prompt
6. CD-ROM INTERFACE INITIALIZATION DEVICE DRIVER
The CD-ROM Interface Initialzation Device Driver is called
CDIFINIT.SYS. This driver initiates the CD-ROM interface of the
sound card. To use the driver, insert the following line to your
CONFIG.SYS file BEFORE the CD-ROM device driver line that you are
using:
DEVICE=[drive:]\[directory]\CDIFINIT.SYS /T:[M/S/P/I/X]
/P:[address]
/I:[IRQ]
/D:[DMA]
[drive] = drive where you have the driver installed
[directory] = directory where the driver is located
[M/S/P/I/X] = M stands for Mitsumi
S stands for Sony
P stands for Panasonic
I stands for Mitsumi IDE
X stands for disabled
[address] = Port address for CD-ROM (320, 330, 340, 360)
[IRQ] = Interrupt number (5,7,9,10,11)
[DMA] = DMA channel (0, 1, 3)
For example, the following line sets up the interface for a
Mitsumi CD-ROM:
DEVICE=C:\MAGICS20\CDIFINIT.SYS /T:M /P:340 /I:10
If you did not specify the /I or /D options, CDIFINIT will
automatically choose the default setting for the CD-ROM type
you have specified.
- For Mitsumi, the IRQ is 10 and DMA is disabled.
- For Sony, they are both disabled.
- For Panasonic, they are both disabled.
For IDE drive, you need to just specify the /T:I option.
Specifying any other option in addition to this will be ignored.
The I/O Port and Interrupt for IDE is located at 170H and Int 15.
The driver site says:
Versions
2.1a
Supported Operating Systems
Windows 3.1, DOS
Uploader Notes
This is the driver for the old Acer Magic S20 Sound Card. This is an old ISA sound card with the Crystal CS4231 chip.
This driver is for Windows 3.x and DOS only.
This will NOT work in Win95 or above.
This is only for systems running DOS and Windows 3.1/3.11
This driver is impossible to find for old systems. A newer driver for Win95 is available on this site.
This driver came off the original Acer System CD, works great.
This will not work for new versions of Windows, or and Windows 9x... Only Windows 3.1/3.11 and DOS.
The file includes 2 disks. Unzip each of the zip files inside onto a seperate 1.44 MB floppy disk.
Good Luck. (So its only dos and windows 3.11 drivers, windows 95 can found separately)
