Reply 460 of 609, by RudimentalRealms
I recorded myself playing through the first two Clan Wolf missions with a cellphone (as its hard to record it with any software) as you can see even in 1080p Glide it's running close to flawlessly with no memory leaks. CD Audio is disabled on purpose as i like to listen to podcasts while playing.
https://www.youtube.com/watch?v=dc6H4rGERHU
Reply 461 of 609, by myne
With zero changes to the installer, and only the 3 dxwnd files Been posted, Mercs got through the mission that previously leaked to hell.
I guess it's up to others to test now.
Scratch that. Clearly I need more settings.
I built:
Reply 462 of 609, by myne
Added admiralsenn's ini.
Lasted 20+ minutes in a mission that consistently glitched - and was using around 100mb of ram.
I think this one's probably a winner.
I built:
Reply 463 of 609, by RudimentalRealms
myne wrote on 2025-05-05, 00:56:
Yes, i originally tried just adding the 3 files from dxwnd but the problem persisted, only once i loaded admiralsenn's ini file directly the memory leak was fixed. I've now played through the entire Jade Falcon and Wolf campaign without a single crash, only some minor annoying bugs that were present from release.
Reply 464 of 609, by ChronoReaperX
Ok thanks Myne, Been and Admiralsenn.... will try to test it.
Reply 465 of 609, by myne
Challenge for anyone bored enough:
Figure out how to get BOTH the 'windows' resolution AND the game resolution to 4:3.
I can get one or the other, but never both.
It doesn't really bug me personally too much with the mild stretch, but y'know... for 'perfection's' sake.
When dxwnd works, dgvoodoo spazzes out.
When dgvoodoo works, dxwnd doesn't.
I built:
Reply 466 of 609, by BEEN_Nath_58
myne wrote on 2025-05-06, 07:37:
Challenge for anyone bored enough: Figure out how to get BOTH the 'windows' resolution AND the game resolution to 4:3. I can ge […]
Which game edition and expansion pack/orig?
Reply 467 of 609, by myne
"MechWarrior 2 - Mercenaries (USA) (Titanium)"
TITAN_MERCS-TITMERW95-Mercenaries Titanium Edition
I built:
Reply 468 of 609, by BEEN_Nath_58
myne wrote on 2025-05-06, 09:10:
Other than your installer edit, you are using an older version of the changes. I added BP support and desktop scaling in my prev version. I will update that
Reply 469 of 609, by BEEN_Nath_58
This should be enough:
Reply 470 of 609, by myne
Not seeing any changes.
Where/what did you change?
I built:
Reply 471 of 609, by ChronoReaperX
ChronoReaperX wrote on 2025-05-05, 13:42:
Ok so far the installer eliminate the memory leak on MechWarrior 2 Mercenaries Titanium and Ghost Bear's Legacy Titanium as I was experiencing before.
BTW I'm playing those games on my old laptop:
-Windows 8.1
-Intel Celeron N2840 (2.1Ghz up to 2.58Ghz)
-Intel HD Graphics
-8GB DDR3 RAM
Smooth framerate.... sometimes minimal & brief FPS drop, usually during close range explosion + missile smoke trails.
Reply 472 of 609, by BEEN_Nath_58
myne wrote on 2025-05-06, 12:10:
Other than a few text changes, no longer forcing Desktop level scaling, not forcing the aspect ration, not forcing 32 bit initial colours, etc at the least
Reply 473 of 609, by myne
So... How does that achieve 4:3?
I built:
Reply 474 of 609, by BEEN_Nath_58
ChronoReaperX wrote on 2025-05-06, 13:02:
BTW I'm playing those games on my old laptop: -Windows 8.1 -Intel Celeron N2840 (2.1Ghz up to 2.58Ghz) -Intel HD Graphics -8GB D […]
-Windows 8.1
-Intel HD Graphics
-8GB DDR3 RAM
It is possible the frame rate can be slightly improved, but DxWnd frame limiter works on WaitForFrequency tactic which isn't as steady as WaitForVerticalBlank. However I haven't played MW2 on a similarly fast computer so I can't answer these claims
myne wrote on 2025-05-06, 14:58:
Game is 4:3 by default
Colour emulation=whatever game asks for an aspect ratio/resolution
Desktop (previous)=forces the game to stretch to match the Desktop
Reply 475 of 609, by myne
Again. How does that achieve 4:3?
That's what I was asking about and you responded to.
I built:
Reply 476 of 609, by BEEN_Nath_58
myne wrote on 2025-05-06, 15:26:
Colour emulation setting allows the game to set the resolution and aspect ratio it asks for. The game asks for 4:3.
Reply 477 of 609, by BEEN_Nath_58
Also to add colour emulation is a form of fake fullscreen. So the game can be set up for recording.
Reply 478 of 609, by ChronoReaperX
For the soundtrack of each game (Mech 2, GBL and Merc) in Titanium Trilogy, I ripped those BGM from their respective previous non-Titanium version. So I have the original, full and complete soundtrack of each game (in ogg format).
Reply 479 of 609, by BEEN_Nath_58
ChronoReaperX wrote on 2025-05-07, 06:40:
Yes that even works, I prefer using those audio as well since it gets the best out of two games
