MartyPC
Reply 460 of 611, by GloriousCow
DaveDDS wrote on 2025-05-21, 13:06:
I'm not certain that's entirely correct - I fired up one of my Win10 systems, run martypc.exe - and get: […]
(X) The code execution cannot proceed because
VCRUNTIME140.dll was not found. Reinstalling the program
may fix this problem.
Well, it was certainly supposed to be. I'll check my flags.
btw - my little 15k DVM.EXE (also statically linked and really needs no
extras) runs fine, even on a fresh Windows install.
I'd love it if MartyPC was smaller. I watch its increasing bloat every time I add a new dependency with trepidation.
The gamepad mapping file that is loaded to support USB controllers is larger than your entire DVM.EXE.
The MartyPC logo PNG used in the About window is twice as large as your DVM.EXE.
It's a good thing my goal is to write to best emulator I can, not the smallest one. If you are going to judge my worth as a programmer based on the size of my binary then I suppose I measure up quite poorly.
oh - and also btw/fyi - trying to look at README.md brings up a prompt to look in Microsoft store to find an application. […]
I can mostly read it if I select wordpad, however formatting information for whatever program you used to create it soils the look
a bit - it looks like simple text (perhaps some of the visible garbage is to set font sizes, fonts etc.) - why not just give it
out as a .TXT - every system back to DOS can read that!
It's markdown format. https://en.wikipedia.org/wiki/Markdown
It is the same file that gets rendered on my Github project's main page:
https://github.com/dbalsom/martypc
So you can see what it is supposed to look like. There are a number of ways to view markdown on Windows. I agree it is a bit inconvenient that the average Windows user is going to try to double-click it and get some useless suggestion from Microsoft on what to open it with.
If you really want to "fancy it up", why not use WordPad --every recent release of Winblows has that!
They actually removed Wordpad from Windows 11.
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 461 of 611, by GloriousCow
DaveDDS wrote on 2025-05-21, 13:36:
I think full .IMD support is probably overkill for a PC emulator ... I designed the format to be able to represent any disk format the Nec765
(original PC FDC) could read - specifically pre-standard and oddball formats used on some classic systems (of which the more off
ones weren't PC compatible at all)
ImageDisk was an excellent tool and IMD was a good format for its time. IMD as a disk image format today is obsolete, or more charitably, "historical", and I only support it so that people can load images that they might have in IMD format from old collections that were never re-imaged.
There is a lengthy list of copy protection schemes that IMD has no hope of representing. Contemporary efforts to archive disks have mostly agreed to concentrate on the capture of flux images, and emulator support of at least bitstream level images.
For example, IMD supports single density, oddball sector sizes or other things I've never seen done on a PC. It also does
things like preserving the sector ordering within differing tracks, so it can recreate as close to "exactly" the original disk.
Oddball sector sizes are actually quite common - something that requires the extension you mention in your format documentation.
IMD can't:
  • reasonably represent sectors nested in other sectors, such as Superlok,
  • provide the bitcell position of sectors and time-to-read, so that time-sensitive copy protections such as Rob Norten's Copylock can work
  • indicate that a sector IDAM has a bad address crc, as in some versions of Formaster CopyLock
  • handle weak/fuzzy bit regions, seen in several different copy protection schemes
  • represent disk surface damage / holes, such as in Vault Prolok
  • encode data between sectors that may be read via a Read Track command with sector-size override
Implementing .IMD seems like a lot of unnecessary work, although at least for reading, you don't have to regenerate the image - […]
the image - writing however... IMD "compresses" all-same sectors (very common in unwritten portions of formatted
disks) by setting a flag to indicate this is the case, and then supplying only the single byte value. So you would have to
regenerate the image to enlarge formerly compressed sectors that get written...
IMD is actually one of the simpler disk image formats I support.
Last fall I spent four months writing FluxFox, a disk image library I intended to use for MartyPC.
https://github.com/dbalsom/fluxfox/
It supports everything from IMD to Kryoflux raw flux stream captures.
I don't think it is at all unreasonable to tell people that if they want to use (especially write) .IMDs in an
emulation, they should use IMDU to convert it to a simple raw binary image containing sequential sectors
first - almost all emulators support that.
My goal was to make users not have to care about converting things. They should be able to drop a disk image of any format and have it "just work". They may not be able to save a disk image in the format they opened it in, but that's fine. In most cases MartyPC will "upgrade" the imported image to a modern format such as 86F or PRI.
Reply 462 of 611, by DaveDDS
GloriousCow wrote on 2025-05-21, 13:54:
I'd love it if MartyPC was smaller. I watch its increasing bloat every time I add a new dependency with trepidation ... If you […]
add a new dependency with trepidation ... If you are going to judge my worth
quite poorly.
Oh don't get me wrong, I don't equate "big" with "bad"... I admit I care about
code size more than most ... as a creator of development tools, some of which
were targeted at processors with <4k (or even <1k) of code space, you do care
about the size of the code you are generating ... now that 4G is a "tiny"
system, it has little relevance (I still worry sometimes about all the extra
libs etc. that get linked in by some tools) - but mainly reference to tiny
code nowadays is kinda my own form of "bad joke" (something that I seem to be
exceptionally good at 😀
Why am I not surprised? I tend to make my "readme"s simple .TXT files
(does Win11 still know how to display those?)
It may not be "fancy", but very readable and almost universally supported...
FWIW few things annoy me about someone elses software more than having to
"install" something else to read "how to get started"!
re: .IMD format
I agree completely, and it's nice that you support .IMD ... but given IMDs
targeted users, and I document the format enough that some who wanted to
could recover data from a .IMD -- I always kinda figured users would know
what it is and how to convert to more common/useful formats (like binary
sectors) - of course I never expected it to become as well known as it has, and
you don't know how .IMDs are going to "get around"!
I also agree that recording the flux transitions along with the index
signal timing is by far the best way to archive any disk... (although it is
harder to "get the data" from such an archive)
IMD was created so that people with "classic" computers but didn't have a
flux based hardware copier - had a much better chance of being able to
backup/archive those systems diskettes than typical disk copy/imaging programs
... it is therefor limited by what the PC FDC (Nec 765) can do, and it was
NEVER intended as a way to circumvent copy protection! (The best of which
use techniques the PC FDC can detect/identify, but not write)
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 463 of 611, by VileR
I wouldn't call the .IMD format historical or obsolete, and I'm not saying that just because Dave is in this thread. 😉 Obviously flux images can do everything non-flux formats can do and more, but for one, they can only be created using specialized hardware. Most people who have access to an old machine with old diskettes likely don't have a Kryoflux or similar, and realistically we can't expect every one of them to get one. As long as the need exists, we're likely going to continue seeing .IMD dumps cropping up as the only available format for certain software, e.g. on bitsavers and similar, where in most cases they do just fine for their intended purpose.
Copy protected, professionally duplicated software is not everything. If that's the type of artifact you need to preserve, then sure, a flux image is really the only acceptable option. But if you're just dealing with system or utilities disks for some oddball CP/M-86 machine or whatever, or someone's homebrew programs and text files, or really any other scenario where only the data itself is important, there's no advantage to the flux format - if you get a kfx just to do that, you're only wasting your money and the bandwidth/storage for the images.
Thankfully it's a moot point, since MartyPC supports both .imd and flux streams, but both have their place.
Reply 464 of 611, by superfury
IMD is the closest thing my emulator supports to actual flux, so I'm sure glad it exists.
The only alternative is DSK, but my implementation just supports normal reads/writes, and only formatting it if the format is exactly the same.
On IMD, all commands are supported (except for flux-specific stuff, like weak bits, nested sectors etc., which aren't supported on IMD images anyway). It's the only format my emulator can properly format with any different sectors on. I don't cache it in memory for small memory device purposes, instead perform formatting and compression using two temporary file caches instead (one for previous tracks buffer and one for the next tracks). The same applies to it's automatic single-byte sector compression: it will save the sectors before and after into two files (cache them on disk), write the sectors before (reading back from the first FIFO cache), then the compressed data, then reading the second FIFO cache for the next sectors' data. So if you write a different single-byte sectors (fill operation) it will simply replace the fill byte without buffers, but if the single byte fill status changes (from non-fill to fill or vise versa), it will compress or uncompress (to full sector) the data using the two on-disk cache FIFO files.
Basically keeping the file optimized as possible for written sectors.
So for example, disk creation has just the tracks created. Formatting adds sectors with just fill bytes specified. Then, the file system being written will keep those 2-byte (compressed ID+fill byte) where possible, while non-fill sectors are expanded where needed (or compressed when possible).
Thus UniPCemu optimizes the disk image as sectors are written, keeping size minimal. It does need to check each sector written for fillability, which is relatively slow (memory scanning an entire sector), but not a problem due to being a slow emulated device anyways.
Most of the disk image is parsed using fseek and fread/fwrite anyways, skipping past sectors and tracks as needed.
Basically when formatting a track or compressing/expanding a sector the same thing is done: cache the data before into the first file, cache the data after into the second file, create a new file, empty the first cache into it, write the new (un)compressed sector, empty the second cache into it.
The two caches can run in two modes (determined at compile-time): either cache on disk (using a file) or cache into memory (on the heap). A simple compile-time define specifies which of the two is used. Right now it defaults to memory-based, except on Sony PSP, where it uses a disk-based strategy due to it not having much memory (only some 16MB after the executable is loaded. Much of that is lost to even a basic SoundFont (audio buffers and precalcs) and emulator structures and some basic RAM (even with 1MB emulated) and emulated VRAM.
I'm glad that UniPCemu can even still load on it (even the base executable is 4MB, due to the architecture (being a MIPS RS4000 CPU)!).
UniPCemu Git repository
Reply 465 of 611, by DaveDDS
VileR wrote on 2025-05-21, 17:32:
I wouldn't call the .IMD format historical or obsolete ...
Thanks! (I guess in "software terms" it coule be so considered because I
started IMD in 2005 ... how much softare still gets regularily used after
20 years?:-)
It has done what I set to accomplish, there are a lot more vintage system disk
images available now... and.. anyone can recreate them - you don't need special
hardware!
Like I said before, it was never my goal to "get around" copy-protection, yes,
some of the simpler types IMD can image... but that was never the goal (and
better types couldn't be rewritten on "stardard PC hardware" even if I had
wanted to) - fortunately the Nec765 based PC FDC can read/write a lot more
formats than IBM decided the PC should support.
Most ancient vendors didn't try to protect their system disks (they usually
wanted ou to make backkups so you wouldn't need their help if a diskette died).
ie: If you needed a new boot disk for you Lobo MAX-80, you could just make a
copy from another system - problem was, computers were not nearly as common or
consistant then ... you might not know another Lobo MAX-80 owner, and if you
did they might be 100s of miles from you. And lets not even think about trying
to restore an obsolete/ancient system that "nobody has".
One of the biggest advantages of IMD is that it lets you make and re-create
disk for "systemX" without having to actually have "systemX" ... this makes
it much easier to maintain and make use of repositories of obsolete disks.
... MartyPC supports both .imd and flux streams ...
Very cool .. I hadn't gotten far enough with it yet to get into such details,
it must have all the logic to completely replicate the bit-stream functions of
an FDC.
This whole thing has gotten me "back into it" enough that I actually got 86box
to boot up my OS images today! (yay)
Playing with it a bit bring up a question about MartyPC... 80box emulates a
network card, but as far as I can tell, it doesn't do so at the raw packet
level - it supports "Null driver" or "SliRP" (which I'm guessing is some sort
of network protocol - like DosBox supports IPX communication)
I like to use DDLINK to put stuff on/off DOS Instances over network. I use
DosBox which makes use of WINPCAP to allow raw ethernet packets to be sent &
received via a virtual NE2000.. I can literaly run DosBox on a host, and use
DDLINK to transfer files over the network to/from a real DOS system (with only
a packet driver needed) directly from that host - or "real DOS" booted under
another instance of DosBox (same machine or not).
Does MartyPC support raw packet access to host network over a virtual network
card?
Reply 466 of 611, by DaveDDS
superfury wrote on 2025-05-21, 21:08:
... UniPCemu ...
Another one I should check out ... where's the best place to get a "ready to go" one?
I see (and can download) the repository at the link in your sig... but I didn't see any executables and I don't
want delve into "building it" - just want to "check out" a recent win version.
Reply 467 of 611, by superfury
DaveDDS wrote on 2025-05-21, 21:31:
Another one I should check out ... where's the best place to get a "ready to go" one? […]
... UniPCemu ...
The last release I made was a bit over a year ago. It's found on it's itch.io page.
It doesn't have the latest bells and whistles (as I'm right now figuring out some remaining CPU bugs before releasing a new build), but it runs pretty well without many errors in that older build. Getting roughly 20% speed at 3MIPS configured speed in realtime back with that build (i7-4790K@4GHz). Right now dropped a bit with the latest additions (mainly CPU changes and slightly heavier and more accurate hardware emulation), despite some slightly improved RAM caching of translation tables. Don't get me started on the PSP, where it's so slow it might as well stand still (over 5 minutes to get a basic XT POST screen 😖 ). Don't know why exactly the PSP is that slow though, maybe the CPU is a bit too weak to handle the more accurate emulation somehow? Mobile (Android) seems comparable to the i7, albeit slightly slower, assuming you keep the video graphical settings low enough (below 4K resolution). Jazz Jackrabbit for example runs fine, but a bit choppy and like in slow-motion. Audio pretty choppy though, but that's mainly due to the slow emulation speed. The main bottleneck seems to be the RAM/ROM mapping at the byte level. The translation caches help a bit, but it's still the main bottleneck, due to the x86 CPU producing too random access patterns for the simple 1-entry TLB (kept per read/write/code fetch). DMA and hardware don't seem to affect it too much: 20% on video card emulation, 30-40% at least on the CPU emulation (which is mainly emulated RAM reads) and the remainder is other hardware and connecting logic to keep it in sync.
The downloads are at the bottom of the itch.io page.
Reply 468 of 611, by GloriousCow
DaveDDS wrote on 2025-05-21, 21:18:
card?
No. one of those "Someday would be nice" features. I don't even have a finished VGA, or sound blaster, or any number of things that I'd probably want to tackle before a network card.
Reply 469 of 611, by DaveDDS
GloriousCow wrote on 2025-05-21, 22:12:
card?
Fair enough - as long as it's in the back of you mine for "someday"... I've got enough to work for me for now - thanks!
Reply 470 of 611, by superfury
Did a quick build of the current version (although I'm still working on 8080 emulation support and the 0F prefixed opcodes on the NEC V20/V30 aren't implemented yet).
The attachment UniPCemu_20250522_0258_win64.zip is no longer available
Stuff like ROMs etc. you'll need to supply yourself of course. There is an internal BIOS available for 80(1)86 CPUs (based on Dosbox's interrupts for the video interrupt partly), which might still be able to boot floppies. Otherwise, use a normal BIOS ROM and video BIOS ROM (required for EGA and higher).
I'm also still searching for some weird CPU bugs (if they are bugs) occurring in some specific software (like test-sbp.exe crashing to a reboot during sampled audio playback), although Windows versions I've tested (up to NT 4.0 workstation and Windows 98) seem to boot just fine. Windows 2000 and higher fail to boot due to not finding the hard disk correctly for some reason, maybe some obscure CPU bug in configuration of the drivers? Debugging the machine over (COM0COM with UniPCemu server's virtual connection) serial seems fine though (assuming the server and COM0COM are properly configured). Used Windows XP home's WinDBG for that (itself running on Windows 10).
Reply 471 of 611, by DaveDDS
This emulation talk reminds me of something...
Playing with these emulators, I'm kinda surprised how slow they are...
Although it's entirely understandable -- I'm sure these are portable, and written in a "high level language",
which means the CPU flags aren't directly accessible, hence you would have to do a lot of work after
any instruction setting flag (which is most) to work out what those flags should be.
Back in the day, I wrote several emulators under 16-bit DOS - These include (at least) my Altair (8080),
Heathkit H8 (8080), Vector 1+ (8080), North Star Horizon (Z80), D6809 (6809) and MIL MOD-8 (8008)
These were all written for DOS using my own C compiler... but I implemented the CPU cores
in assembly language, for the most part I could just save the PSW after instructions setting flags,
and refer to that saved value later to see what the flags should be (with a little bit of adjustment in
some cases depending on the processor being emulated)
And the given how much faster the "modern" CPU was, the resulting emulated processors were FAST,
so fast I had the artificially slow them down!
At one point I did a test running a BASIC interpreter I had written in the 70s for the Altair through
four processors (ie: 3 levels of emulation) - X86-64 -> X86-16 -> 6809 -> 8080
and it STILL runs faster than it does on the actual Altair with native 8080!
I described it in more detail here:
Re: How do todays CPUs compare over time, even back to the 1970s and 80s?
Really shows how much faster systems are now than they were at the beginning!
Reply 472 of 611, by GloriousCow
DaveDDS wrote on 2025-05-22, 03:58:
This emulation talk reminds me of something... […]
MartyPC is primarily slow because it does more work per CPU cycle than many emulators do for a single instruction. The 8088 bus interface unit runs independently of the execution unit and they must be updated in lockstep to replicate the 8088's behavior exactly. If I want to execute the MUL instruction, I can't just use Rust's multiplication operator or an assembler intrinsic then move the product into the destination registers, fix up the flags, then do 'cycles_spent + 68' - I have to execute the actual cordic multiplication algorithm, advancing the bus on each cycle so that while I am multiplying numbers the bus can go out and prefetch instructions on exactly the same cycles a real 8088 would. This happens everywhere. Even for all three cycles of a NOP, I have to tick the BIU.
The CGA card, which I can tick up to 14Mhz, is 7x faster than the CPU in the Altair and replicates the display field by emulating a Motorola 6845 CRTC at 1.7Mhz tick by tick. This allows you to watch the raster beam cross the screen as you step instructions. If you issue an OUT to change the background color of the display, it will take effect that pixel, as the OUT instruction fires off a state update of the CGA that advances it to match the exact clock in which the color was updated.
The 8253 timer is also cycle-precise at another 1.17Mhz. The sound you hear out of the PC speaker is not a calculated square wave from the values set in the Channel 2 reload register, you're hearing an actual downsampled 1.17Mhz signal of the timer's output.
The CPU can also be interrupted at any moment, mid-instruction, by DMA, which is also ticked at 4.77Mhz, so even per-cycle, we have to tick the DMA controller and emulate the motherboard's HOLDA/DMA logic circuitry.
Every single cycle can also be logged and annotated with comments during execution. It's also calculating pin states for the 8088 and the 8288 bus controller that can be used to export cycle-by-cycle execution in a format that a logic analyzer can read, so you can directly compare emulator execution against hardware bus traces. Many devices also keep track of updated states, keeping dirty flags when registers have been updated so that the GUI can show the user when values update. This is surprisingly expensive as well, but you can watch certain values glow blue in the UI when they change. Every IO operation involves polling the destination device to see if it holds the READY line down in order to calculate an appropriate number of wait states. There's more that I'm missing, I'm sure. It all adds up.
I realize I've left a lot of performance on the table, as it has to date been more important to be correct than to be fast. A cached decoder would help, a system scheduler that could tick devices only at the precision each requires would help.
Believe it or not, this is my first emulator and my first program in Rust. I'd say I did a pretty decent job for what is essentially a very large Hello World.
Reply 473 of 611, by superfury
Yeah, the same with UniPCemu. In my case, the BIU holds a basic counter that it ticks down, loaded by the EU, updating single cycles until it runs out, at which point the EU usually gets control back. Usually it's in single clock cycles, but sometimes it's longer (like with the long MUL/DIV instructions). The BIU thus simply runs in batches, saving the EU from having to time single cycles when it's already done(MUL and DIV calculate the amount or operations done, counting the cycles during it's calculation phase (the x*y or x/y operation part), stores the results and lets the BIU run for the known amount of EU cycles (optimizing the EU from needlessly handling NOP cycles it already calculated). The CPU has 2 kinds of options for cycle modes. The first one is simple: whenever the CPU executes a clock cycle at the set speed, the hardware does too (based on the time elapsed). DMA can interrupt the BIU when it's inactive only (the CPU has full control).
The other (IPS clocking mode) ticks hardware roughly the same, except the CPU keeps running for entire instructions (From fetch until EU phase finishes), after which the hardware is ticked by the time of a single CPU clock at the specified clocking speed. DMA is running at a specific rate in that mode, ignoring the CPU when it doesn't take the bus and simply running based on a reasonable timer like other hardware, based on the configured CPU speed divided by a small number (thus free-running like other hardware).
In IPS clocking mode, the hardware is basically driven by the 'instruction complete flag' instead of the cycle done flag. That's multiplied with the configured CPU cycle time to obtain the amount of nanoseconds (floating point) to update all hardware at (immediately subdivided into 14MHz ticks as well for hardware that uses it).
The hardware updating is relatively simple: it's keeping nanoseconds elapsed by the CPU clock only. Said nanoseconds are either directly fed to the timers of hardware (like audio cards and modern video cards with non-14MHz clock ratew) or given the elapsed time of the CPU cycle in nanoseconds.
The end effect is usually the same: all hardware either take the 14MHz clocks passed or nanoseconds passed, add it to their timing state, perform division and modulo to divide it (remainder kept for next cycles) and then tick their own clocks by the amount of cycles passed depending on their required hardware timing.
For example, Game Blaster ticks it's 8MHz clock together with a 44.1kHz clock, rendering sames with lowpass at a 8MHz rate, feeding into a free-running stereo output (two floating poin5 numbers). Then the other clock of 44.1kHz picks up the current stereo sample at that time and moves it to the audio output double buffer. Said double buffer is directly used by the audio channel callback (running realtime) which is then mixed by my homewritten mixer to the hardware audio stream, which is given to the SDL library in blocks of samples to render to the host operating system.
The Sound Blaster works much the same. It just uses a 1MHz sample output instead of 8MHz. But in direct mode, said output is updated when it receives the data. The 1MHz clock simply performs the same, except using DMA to time itself actually instead of direct writes (DMA writes and reads writing to the current sample or reading the current recording sample output), with the 1MHz clock deciding when to push the sample gotten from DMA to the free-running renderer.
The Covox Speech Thing / Disney Sound Source use such a free-running approach as well. Both output samples immediately (Covox) or timed (Disney), with the live output being recorded by the rendering at a normal 44kHz sample rate and sent through a double buffer to the mixer.
Reply 474 of 611, by jal
SoftCat wrote on 2025-05-21, 10:25:
What are the maximum visible screen sizes in pixels possible on a real CGA monitor (with a pixel frequency of 14.318 MHz)?
Is it possible to increase the number of visible lines by reducing the frame rate to 50 Hz?
I don't have the details, but iirc the 5153 is pretty finicky about what frequencies it can run on, and can even break in case you drive it with the wrong ones. So I very much doubt it would accept 50Hz.
JAL
Reply 475 of 611, by DaveDDS
GloriousCow wrote on 2025-05-22, 09:10:
MartyPC is primarily slow because...
Oh don't get me wrong, I wasn't complaining or suggesting bad design.
I just wanted to share a somewhat related memory, and touch on how much faster
modern machines are .vs. those fromn "back in the day".
I totally get that there are many factors which contribute to the amount
of emulator code and slowdown:
- Cycle accurate emulation
- Implementing the CPU flags (especially portably in a high-level language)
- Emulating an entire fairly complex system, with things that may be causing
interrupts etc.
I've done several emulators for systems that I owned/used, and didn't really
care about "cycle accurate", and these were MUCH simpler systems to emulate
- All I wanted was to be able to run the software I'd previously written (in
.ASM for anothe processor) and have it basically "feel like" running my earlier
system.
To that end, at first I didn't worry about speed at all, but as my "current"
systems got faster and faster, I eventually added general (and optional)
calibration and slowdowm code to make it feel more like the older system.
My software tends to reflect "Everything should be as simple as possible"
(but not simpler) - and at the time it was fairly obvious to me that the
simplest way to implement an "forign" instruction set was in assembly language
where you have the closest and most accurate access to the features of the
host CPU that you would be relying on.
I wrote my first emulation in (according to a notice in the source code) 1983.
This was SIM80, an emulation of the Altair CPU (Intel 8080) on a homebuilt
system based in the Motorola 6809 (fairly different architecures)
This was a single 6809 .ASM file:
SIM80.ASM: Lines=1407 Comment=109 AsmDirective=10 Instruction=1288
Which produces a 2912 byte SIM80.EXE (yeah, my 6809 CUBIX OS uses .EXE
for an executable - this was before I'd seen DOS or a PC)
The simplest emulation I've ever done was for an "imagineary" processor I
called C-FLEA, this was designed to be both a fairly ideal target for my C
compiler, and VERY easy to port to different "host" architectures.
It had only 4 registers: A IDX PC SP
One of the main reasons it was very portable is that it has NO FLAGS!
(Like C - CMP produces 1 or 0 if the operands match or not - technically
there is one "invisible" flag which records if (arg1 < arg2) or if there
was a carry out of addition/subtraction).
It does have LT, GT, LE, GE, ULT, UGT, ULE, UGE instructions which adapt the
0/1 result of CMP to reflect eg: LessThan[orEqual]
eg: For the Intel 8051 family
VM51.ASM: Lines=693 Comment=74 AsmDirective=9 Instruction=608
This is what I based DVM on, which is why the CPU core code in DVM, and is
slightly less than 200 lines of C (which calls no libs)
There can be HUGE differences in emulations!
Reply 476 of 611, by keenmaster486
You did.
How do you feel about the choice to use Rust now that the project has reached multiple major versions? Was there a great advantage that you would have missed had you built it in C or C++, for example?
World's foremost 486 enjoyer.
Reply 477 of 611, by GloriousCow
keenmaster486 wrote on 2025-05-22, 15:59:
You did.
I will say that I love the language, I love coding in it. I feel more productive in Rust that I ever was in C. The main advantage is that I've kept up with it for three years now, unlike other projects I have attempted that usually sputter out after some months where I get frustrated or lose interest. I don't need to explain that to any programmer, we all have large directories full of half-completed projects.
That said, in terms of people being able to use my code, read it, fork it, port it, or attract collaborators, Rust has not been ideal. The 86Box project has wanted to adopt MartyPC's 8088 core emulation, but they have to laboriously translate Rust-isms with no direct equivalents in C.
If I was starting over today to make a high-performance cross platform emulator I almost certainly would choose C++. It's too late now, though, I'm kinda stuck with it unless I want to spend an entire year or more rewriting the whole thing.
I only hope that the rust ecosystem continues to grow in a healthy manner.
ps: could you reply to that issue you opened?
Reply 478 of 611, by UselessSoftware
I've yet to dip my toes into Rust and really don't know much about it. What about it made you more productive?
I've stuck with C because I can port whatever I write to anything from the latest i9 running Windows down to an 8086 or a microcontroller or an old PowerPC.
Reply 479 of 611, by GloriousCow
UselessSoftware wrote on 2025-05-22, 16:30:
Iterators are nice. Option types, Enumerations with struct and tuple variants. Traits. A powerful macro system, including derive macros for deriving said traits. A standard library with useful containers. Being able to return tuples.
Default immutability. Painless serialization and deserialization support. A non-frustrating build system, an excellent package management system and a centralized documention repository (docs.rs).
There's a long list of stuff. I've been doing C coding for my Arduino808x project (I've added 8086 and V30 support) and it just feels awkward and constraining to use C now.
