Reply 480 of 571, by schlang
BEEN_Nath_58 wrote on 2025-04-23, 03:56:
The behaviour is weird. As to how you described, the game is running in an inverse behaviour where it plays sound where it shouldn't (menu) and doesn't play when it should.
Enable the game in windowed mode. Check "Run in Window" in main tab, and check the CD player monitor when running the game:
can you please share your dxwnd profiles? <3
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 481 of 571, by BEEN_Nath_58
schlang wrote on 2025-05-07, 16:47:
The profile is located in this installer in the dxwnd.ini file:
Reply 482 of 571, by myne
I can't remember exactly but I'm pretty sure I haven't bought a mech yet.
Just finished the Solaris games.
Salvage is what makes mercs more fun 😉
I built:
Reply 483 of 571, by myne
This ini mostly seems to work at 4:3 if anyone wants to try it.
It does glitch sometimes which I'd ideally like to fix, but maybe someone else is better with the tricks
I built:
Reply 484 of 571, by BEEN_Nath_58
myne wrote on 2025-05-10, 02:51:
I am still not getting what type of4:3 you are trying to achieve...
Reply 485 of 571, by myne
1920x1440 in my case
but historically: 640x480, 800x600,1024x768
I built:
Reply 486 of 571, by BEEN_Nath_58
myne wrote on 2025-05-10, 08:34:
Titanium doesn't support non 640x480 as per my knowledge. Also I can't see a place to select a non 640 x 480 res
Also why use the older config with unrequired addon modules?
Reply 487 of 571, by myne
When forced into dgvoodoo, the engine, except the HUD runs at whatever res you tell it.
Older config? It's admiralsenn's ini with the 4:3 changes.
I built:
Reply 488 of 571, by BEEN_Nath_58
myne wrote on 2025-05-10, 21:38:
Technically older since I made a lot of other changes, you didn't follow my prev posts.
Can you post screenshots of how the 4:3 changes, and without changes the game looks. I can't see it.
Reply 489 of 571, by myne
https://www.youtube.com/watch?v=i768M029FV0
ignore the accident
with your ini screen recorder records a 640x480 window in the top left and the rest (2k res) black.
I built:
Reply 490 of 571, by BEEN_Nath_58
myne wrote on 2025-05-11, 00:34:
ignore the accident
That's correct. That's how the recorder is supposed to record. The game is locked to 640x480.
dgVoodoo2 is configured to be used only in Glide, yet configured 640x480, I think. I reverted it back from Desktop since the higher resolution caused minor glitches at the window edge + had hooking issues forcing to windowed mode.
Your method works since DxWnd is set to Desktop resolution instead of X, Y coordinates. Once you enable XY coordinates, the setting you changed shouldn't work. XY coord is the default setting in the installer as well.
Personally I thrown in DxWnd Desktop resolution when recording as well.
Reply 491 of 571, by myne
I should have added this too.
Dgvoodoo allows the engine to run at much higher than 640 if you set it correctly.
You should see black bars on a 2k display.
I built:
Reply 492 of 571, by BEEN_Nath_58
myne wrote on 2025-05-11, 02:10:
dgVoodoo2 isn't increasing the game engine limit. Its a fullscreen exclusive game so there's no limitation (except memory) of how much it can be scaled. The game just gets stretched with bilinear filtering.
Internally only Mw2 D3D and Positional Sound allows changing resolution: the engine limit is somewhere around 720p.
I am using a lower quality monitor so I can see some very small amount of incorrect colouration on the edges, but in a better monitor it's invisible.
Reply 493 of 571, by myne
From everything I've read historically, the engine itself doesn't have a resolution limit - it was purely hardware limitations.
The dos version ran anywhere up to 1600x1200 iirc - if not that, then 1280x1024.
I built:
Reply 494 of 571, by myne
Finished again.
Won't say it's perfect, but pretty good.
Can anyone beat 186mil?
I built:
Reply 495 of 571, by BEEN_Nath_58
myne wrote on 2025-05-11, 07:43:
The dos version is the Pentium Edition equivalent, Titanium is different.
Although it should be possible to change resolution inside as well. One game allows it, it is possible it's just one file that needs a change
Reply 496 of 571, by myne
tried that.
Has several res' but still maxes at 640
I built:
Reply 497 of 571, by BEEN_Nath_58
Salvaged yet another Mechwarrior2: MechWarrior 2 Softkey. This one doesn't seem to have CDaudio, otherwise equal to the Win95 game
Reply 498 of 571, by UCyborg
Wow, this thread is already 25 pages and PCGW mentions a bunch of different editions. I wonder if Windows versions also have the bug like Interstate '76 (uses newer iteration of the same engine) where pointer to process heap is overwritten by pointer to another heap. That oughtta cause strange anomalies or crashes.
Does this game have only one glitch related to high frame rates (jump jets not recharging)? Interstate '76 is bugged all over the place in that regard. As for MW2, only DOS version was patched, otherwise you need to run at 45 FPS? Or do official Pentium / Titanium editions have this patched?
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 499 of 571, by BEEN_Nath_58
UCyborg wrote on 2025-05-13, 11:40:
DxWnd did something regarding how the game heap works, but I don't have any solid answer on what fixed it. A combination of EmulateHeap + SafeHeap in DxWnd produced the best results. This result was working for me in 2021, then I decided to abandon it, yet some people need it now too so that's that.
Every Windows version has this issue.
