MartyPC
Reply 480 of 606, by keenmaster486
GloriousCow wrote on 2025-05-22, 16:11:
I will say that I love the language, I love coding in it. I feel more productive in Rust that I ever was in C. The main advanta […]
I will say that I love the language, I love coding in it. I feel more productive in Rust that I ever was in C. The main advantage is that I've kept up with it for three years now, unlike other projects I have attempted that usually sputter out after some months where I get frustrated or lose interest. I don't need to explain that to any programmer, we all have large directories full of half-completed projects.
That said, in terms of people being able to use my code, read it, fork it, port it, or attract collaborators, Rust has not been ideal. The 86Box project has wanted to adopt MartyPC's 8088 core emulation, but they have to laboriously translate Rust-isms with no direct equivalents in C.
If I was starting over today to make a high-performance cross platform emulator I almost certainly would choose C++. It's too late now, though, I'm kinda stuck with it unless I want to spend an entire year or more rewriting the whole thing.
I only hope that the rust ecosystem continues to grow in a healthy manner.
Makes sense. Is there a way you could turn that core emulation into a library?
ps: could you reply to that issue you opened?
Sorry about that! I've been very busy at work the last few days. Just responded to it.
World's foremost 486 enjoyer.
Reply 481 of 606, by VileR
jal wrote on 2025-05-22, 14:55:
SoftCat wrote on 2025-05-21, 10:25:
What are the maximum visible screen sizes in pixels possible on a real CGA monitor (with a pixel frequency of 14.318 MHz)?
Is it possible to increase the number of visible lines by reducing the frame rate to 50 Hz?
I don't have the details, but iirc the 5153 is pretty finicky about what frequencies it can run on, and can even break in case you drive it with the wrong ones. So I very much doubt it would accept 50Hz.
Yes, 50 Hz is way too far out of spec. If you feed a 5153 the wrong frequencies, it's much less likely to break than a 5151 is, but I still wouldn't try it because it's never going to sync anyway.
If you really want *a few* more scanlines... it's possible to increase the horizontal frequency a little, which the 5153 does accept. This shortens the duration of the scanlines, and brings them closer together vertically. That pushes vertical refresh above 60 Hz, so to bring it back down to the tolerance range, you then increase the *total* scanline count. (This also modifies the pixel aspect ratio, and also makes the picture darker for some reason, but you win some you lose some.)
I was able to do 16.57 KHz (H) / 60.93 Hz (V), which got me 222 visible lines without changing the V-SIZE control (see here for details)... That's still faster than 60 Hz, which means you can likely add even more scanlines and make it a bit slower. And of course if you do change V-SIZE you could fit even more visible lines within the frame.
Reply 482 of 606, by GloriousCow
keenmaster486 wrote on 2025-05-22, 17:23:
Not easily, no. At least, not as a clean "drop-in" CPU with a C FFI. There are a bit too many internal integrations between the CPU and peripherals, maybe I could factor those out, but there's still an inversion of ownership due to Rust's ownership model and borrow checker - you might logically structure an emulator in C++ to have a Bus upon which lives a Cpu along with Memory and any peripherals. It was easier to make Rust happy by putting everything into the CPU, so the heirarchy is not what you'd expect.
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 483 of 606, by jal
I don't know what you're talking about. 😁
JAL
Reply 484 of 606, by jal
VileR wrote on 2025-05-22, 17:37:
Thanks, that was in interesting read! Now I'm tempted to adjust the horizontal displayed for my Rick Dangerous 2 CGA rewrite (as RD2, like RD1, has a 256-pixel-wide visible area) 😁. Btw, the link to "North Star Advantage" is broken, as the content of old-computers.com seems taken down. There are some other links you could use, e.g. this one.
JAL
Reply 485 of 606, by SoftCat
Thank you for the information!
Here in Trixter's video, starting from 2:51, the 90x30 character mode (720x240 pixels) is set. The line frequency remains the same 14318/912 ~ 15700 Hz, but an additional 4 lines are added to the total number of frame lines.
https://archive.org/details/CGACompatibilityReferenceVideo
Reply 486 of 606, by DaveDDS
I did some very basic speed tests:
I've found that BIOS 55ms tick isn't always accurate on some emulators, but
time of day clock is much more so. The test program basically "counts" during
each second (with a bit of overhead, it did have to read the time-of-day clock
etc. between each count)... It did display the times as the second changed,
and it did seem pretty accurate over the 10 seconds that the test ran. I've
edited those time displays out of the output as they give no useful info.
(without a stop watch)
The only x86 emulators I have working so far are DosBox, VMwarePlayer and
86box - I could only get 86box to boot 360k images, and VMware to boot
1.44m - so I ended up using DOS 2.11 and 5.00:
DosBox direct (Cycles=max)
           0+      167871
167871+ 157711
325582+ 157894
483476+ 155856
639332+ 159895
799227+ 167897
967124+ 157027
1124151+ 159108
1283259+ 158569
1441828+ 158649
1600477/ 10= 160047
MS-DOS 2.11 booted under DosBox
           0+      127267
127267+ 126339
253606+ 129378
382984+ 128463
511447+ 129352
640799+ 128622
769421+ 127822
897243+ 135515
1032758+ 127404
1160162+ 128826
1288988/ 10= 128898
MS-DOS 2.11 booted under 86BOX (IBM AT 286)
           0+        3383
3383+ 3349
6732+ 3541
10273+ 3353
13626+ 3354
16980+ 2977
19957+ 3354
23311+ 3353
26664+ 3542
30206+ 3353
33559/ 10= 3355
MS-DOS 5.00 booted under DosBox
           0+       96752
96752+ 91501
188253+ 90086
278339+ 90514
368853+ 89763
458616+ 96621
555237+ 88096
643333+ 91144
734477+ 91197
825674+ 89693
915367/ 10= 91536
MS-DOS 5.00 booted under VMWARE Player 7
           0+      147794
147794+ 156330
304124+ 148641
452765+ 148625
601390+ 147869
749259+ 148511
897770+ 157437
1055207+ 148506
1203713+ 147451
1351164+ 148662
1499826/ 10= 149982
Can't say they are super-accurate (it was a very quick-and-dirty test), but clearly DosBox is *way* faster than 86box
(and it really feels it) - there may be more settings I can use to improve it - I'll have to keep playing.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 487 of 606, by DaveDDS
(Forgot one)
MS-DOS Player (i8086) for Win32 console
           0+     1652202
1652202+ 1653233
3305435+ 1635576
4941011+ 1652354
6593365+ 1650668
8244033+ 1646306
9890339+ 1653886
11544225+ 1663768
13207993+ 1655537
14863530+ 1654762
16518292/ 10= 1651829
Reply 489 of 606, by DaveDDS
GloriousCow wrote on 2025-05-23, 14:10:
Can you try the web version of MartyPC at least?
Sure: MSDOS 2.11 booted on MartyPC (WEB)
0+ 632
632+ 603
1235+ 603
1838+ 638
2476+ 603
3079+ 604
3683+ 603
4286+ 603
4889+ 638
5527+ 603
6130/ 10= 613
Seems pretty abysmal, but I don't know how indicative a "web" application
would be over the native MartyPC running on my machine.
Does the WEB version download some sort of actual (native host) executable,
is it in some sort of interpreted code?
Perhaps because the test pgm does call DOS to get the current time, on every
look, and actually prints that time when the second changes this may take
longer via the web. The times do seem to still be coming out at good 1second
intervals.
It does just buffer the loop-counts and perform the addition display and
average calculation after the test in finished.
Just for "fun" I'll run the test on my "real" DOS systems and see how it
compares.
Reply 490 of 606, by DaveDDS
And also "just for fun", here's the same program compiled for DVM
(not x86, but still an emulated processor)
           0+     1879953
1879953+ 1864407
3744360+ 1858804
5603164+ 1880892
7484056+ 1869355
9353411+ 1871804
11225215+ 1856847
13082062+ 1854945
14937007+ 1866856
16803863+ 1844644
18648507/ 10= 1864850
And YES .. all these tests were done on the same I7 machine running Win7Pro
Reply 491 of 606, by superfury
Does it use time from the PIT, from the CMOS or XT RTC(NC MM58167, can be used with TIMER/COM, also made a XT BIOS ROM supporting it: https://bitbucket.org/superfury/unipcemu_pcxtbios_at)?
UniPCemu has the option to sync the CMOS/XT RTC to the host time (updated at the client's bus speed). So every time it's client's time ticks 1/100th(1/10000 on XT) second, it polls and updates the CMOS time to either the host time or the emulated time (which is based on the cycles ticked by the emulated CPU). Of course, everything like interrupts (alarms etc.) is modified to behave like that as well, ticking at the same time, overflowing to IRQ as needed (detected using Unix timestamp difference with nanoseconds).
The BIOS option ROM basically hooks INT19(for setup), INT15(for memory storage, stealing a bit of RAM, which is mainly used for storing the INT15 handler as well as the hooked interrupt vectors inside itself, as well as installation detection) and INT1A, adding the RTC support (leaving the basic XT functionality to the motherboard BIOS).
UniPCemu Git repository
Reply 492 of 606, by GloriousCow
DaveDDS wrote on 2025-05-23, 16:31:
Considering I have no idea what the numbers you are dumping into this thread mean, I can't even agree or disagree with you.
, but I don't know how indicative a "web" application would be over the native MartyPC running on my machine. […]
It's WASM. It's technically interpreted, but it is extremely fast.
longer via the web.
The emulated machine on the web is just as cycle-accurate as it is natively. Delays experienced in "human time" are irrelevant to any output the emulator produces.
compares.
Provide the executable and I will tell you exactly what output it produces on an IBM 5150.
If the numbers are some sort of loop counter, you are comparing an unthrottled DosBox to an emulator specifically trying to be a 4.77Mhz 8088.
Reply 493 of 606, by DaveDDS
Here are some "real" systems...
Pentium200MMX at 200mhz
           0+       89612
89612+ 94580
184192+ 89596
273788+ 89594
363382+ 89603
452985+ 89603
542588+ 94581
637169+ 89581
726750+ 89596
816346+ 89581
905927/ 10= 90592
Pentium3 at 733mhz
           0+      124099
124099+ 131068
255167+ 124069
379236+ 124170
503406+ 124077
627483+ 124170
751653+ 130989
882642+ 124162
1006804+ 124094
1130898+ 124145
1255043/ 10= 125504
Pentium4 at 200mhz
           0+      270716
270716+ 285750
556466+ 270712
827178+ 270710
1097888+ 270719
1368607+ 270712
1639319+ 285754
1925073+ 270717
2195790+ 270706
2466496+ 270718
2737214/ 10= 273721
VIA-C7 at 1.0ghz
           0+       95635
95635+ 95618
191253+ 95620
286873+ 100935
387808+ 95629
483437+ 95612
579049+ 95629
674678+ 95603
770281+ 100942
871223+ 95627
966850/ 10= 96685
PoQet PC 8088 at 2-7mhz (docs say 2-7mhz, I've not found a way to see/chg)
           0+        1154
1154+ 1061
2215+ 1074
3289+ 1073
4362+ 1072
5434+ 1134
6568+ 1073
7641+ 1072
8713+ 1072
9785+ 1073
10858/ 10= 1085
Btw, I'm not sure how indicative these tests are, because the call DOS to get
the time on every iteration of the loop (which might trigger access to RTC/IO)
and they print the time each time it changes (to help confirm that an
emulator has a good sense of "real time".
I've got some ideas which should help a lot with these and will add command
options to the test to allow me to set it up in different ways. Once I've
implemented them, I will re-run the tests on all the platforms I have and see
how much things change.
Reply 494 of 606, by DaveDDS
superfury wrote on 2025-05-23, 16:51:
Does it use time from the PIT, from the CMOS or XT RTC(NC MM58167 ...
No, I wanted to keep hardware dependencies out of it (and also didn't want to bother for a "just for fun" couple minite pgm)
I have found DOS clock to be fairly accurate in various emulators I've tried ... It's been so long since I dealt which this stuff
at low-level, I don't recall is DOS goes through BIOS somehow and reads the RTC or it it maintains it's
own local system time.
Reply 495 of 606, by GloriousCow
DaveDDS wrote on 2025-05-23, 18:55:
I've got some ideas which should help a lot with these and will add command options to the test to allow me to set it up in diff […]
These tests are interesting, but would you mind making a separate thread for them?
Reply 496 of 606, by DaveDDS
GloriousCow wrote on 2025-05-23, 18:39:
It's just a loop counter from one second to the next (with a lot of INT 21h AH=2Ch calls during that second.
No real meaning to the number other than comparing one system to another.
I'll attach TIMTST.ZIP which contains TI.COM as well as TI.C so you can see exactly what it does.
Please bear in mind that this was a couple min "quick and dirty - just for fun" program, no comments
and try not to laugh too hard at it!
Reply 497 of 606, by DaveDDS
GloriousCow wrote on 2025-05-23, 19:01:
I put it here because it was related to some of the discussion we've had...
But, sure - when I've added some options, made it more accurate (perhaps I will add direct access to the hardware RTC as SuperFury
suggested) and added some comments... If anyone wants to see it further, I would certainly create a dedicated thread!
Reply 498 of 606, by GloriousCow
Sure: MSDOS 2.11 booted on MartyPC (WEB) […]
0+ 632
632+ 603
1235+ 603
1838+ 638
2476+ 603
3079+ 604
3683+ 603
4286+ 603
4889+ 638
5527+ 603
6130/ 10= 613
Here are the results from a 4.77 MHZ 8088 in an IBM 5150, the same system that MartyPC emulates by default.
The attachment ti_results_5150.JPG is no longer available
I think there is a bit of a misunderstanding of what MartyPC's aims are. It is not attempting to be the fastest x86 emulator. It is trying to very accurately emulate an IBM 5150/5160.
In this case, I would argue these results are quite good.
Reply 499 of 606, by DaveDDS
GloriousCow wrote on 2025-05-23, 19:21:
To be honest, my "abysmal" comment was more in comparison to others, and I don't have any working
original 4.77mhz 8088 machines any more, and I'd forgotten how slow they are.
Looks like MartyPC is indeed more accurate.
Btw I think the 86box number is higher because I had to set to 386SX mainly because my boot disk used a RamDisk
in XMS... For MartyPC I had to ignore the error and figure out a way to get the output off other than redirecting to
a ramfile (which I then copied back to the FD and could extract)
(When I tried to redirect to A: in web version, it "worked" in that the file appeared,
but my image file that I had mounted was not updated)
Any chance MartyPC might support 286/386 someday?
