Reply 49780 of 60056, by appiah4
- l33t++
HanSolo wrote on 2023-07-13, 10:34:BitWrangler wrote on 2023-07-13, 01:17:Check for hollow space under the sofa, put it up on risers 🤣
Maybe some hollow space IN the sofa. Even if the manual says it's the shortest 22" flatscreen in the world with a depth of only 47.6 cm/18.7", that cube is slightly too big to fit under my sofa 😀
It's supposed to be capable of showing 1920x1440 @ 85Hz. That's better than many monitors today.
I ran a 107P Brilliance as my main monitor until I 'upgraded' to a 20" LCD eventually and honestly that monitor was way better than the LCD I got. The 17" model also did 1920x1440@85 IIRC and it did some amazingly high refresh rates at lower resolutions. I used to run the 17" at 1600x1200 daily and had no issue seeing things, it was crystal clear. Phillips Brilliance are an amazing line of monitors.
