Reply 500 of 694, by supercordo
Mentat-vvo wrote on 2023-12-31, 02:52:Skalabala wrote on 2023-12-30, 21:51:I did not know there is an MVP3 board that goes up to 150fsb, thought its only ASUS that can do that.
Cache not working at 133fsb?The data sheet says the clock synthesizer can go up to 150 MHz . But, I can’t set 140 and above. I can only set what is below bios settings and back . Bios can select up to 133 . The cache module was replaced from 512k to 1M, but I can’t figure out how to make it work. It detects 1024 but can’t go further than a summary screen with cache on at any frequency. I think I have enough skill to add 140 and 150 MHz options in bios. They go through I2C bus.
You can try lowering the timings on the cache. I was only able to get my 4ns 2Mb cache on my freeway board to run around 124fsb
