Reply 500 of 1275, by ViTi95
We'll I guess iD Software didn't care to port it to Amiga / Atari ST not only because of the planar video layout, but also because the 68030 wasn't fast enough compared to the 486. Those system's didn't have any kind of cache, which it's basic for Doom to perform well (I know the 68030 has 0.5Kb total cache, which it's ridiculous compared to the 8Kb of the 486). Only the Commodore A4000 had the more powerful 68040 along with multiple Macintosh, that's why I think only Macintosh got a port of Doom.
Maybe I'll have to port FastDoom to the 68k 😏
https://www.youtube.com/@viti95
Reply 501 of 1275, by Tronix
Today i tried adding CMS / Game Blaster music support to fastdoom:
https://youtu.be/3HsqiehKW3s
Unfortunately, music cannot work with PWM sound effects at the same time, so you have to choose only one - either CMS music or sfx
So, not great not terrible =\
https://github.com/Tronix286/
Reply 502 of 1275, by rasteri
Tronix wrote on 2022-10-17, 11:32:
Cool!
What is it using as the source of the notes? MIDI or Adlib?
Reply 503 of 1275, by ViTi95
Uhhh really interesting!! With two SAA1099 chips available maybe it's possible to use one for sound effects (mono) and the other for music although with only 6 channels available. The mono CMS PCM is already available since I programmed it first, and then added stereo support.
Reply 504 of 1275, by appiah4
FastDoom works so beautifully well on my U5S-33 PC..
Reply 505 of 1275, by Tronix
ViTi95 wrote on 2022-10-17, 12:17:
Hmmm, i have the same idea - use only 6 channels for music (one saa1099 chip) and second saa1099 for PWM sfx (mono). But this breaks the existing code for the stereo output of sound effects...
Or maybe if MusicDevice != CMS then SFX=stereo else SFX=mono. And if SndDevice != CMS then music_channels = 12 else music_channels = 6. But this will require serious editing of the existing code.
While I created a pull request for the current implementation https://github.com/viti95/FastDoom/pull/112
Reply 506 of 1275, by rasteri
you could make .mod versions of all the doom tracks and output everything over PCM. 🤣
Reply 507 of 1275, by ViTi95
At somepoint I'll have to add some kind of soft synthesizer for music on devices that only can play PCM audio.
Reply 508 of 1275, by 7F20
I saw on your youtube channel you're working on a way to output to a second monitor MDA automapping. I'm wondering if it could be done through DOSBox? I've never tried to run a second monitor in DOSBox, I suppose it's unlikely.
Reply 509 of 1275, by ViTi95
Automapping on a second monitor requires an Hercules card, which is a combination not supported on DOSBox. But you can try with 86box 3.7 upwards, it supports pretty well this configuration.
Reply 510 of 1275, by matze79
Would it possible to implent miles sound system for music playback ?
This would allow to play music on tandy, pcspeaker, covox, mos6581 (ssi2001) etc.
http://www.ke5fx.com/
Reply 511 of 1275, by 7F20
ViTi95 wrote on 2022-10-18, 07:17:
I tried so hard to get an 86box machine going, but can't seem to get it to recognize a VHD I create in Windows. There doesn't seem to be any guides to this stuff and their documentation absolutely sucks. Any idea where I can get help with it?
Reply 512 of 1275, by ViTi95
matze79 wrote on 2022-10-18, 14:28:
That would require insane amounts of work, right now the Apogee Sound System is directly integrated and optimized onto FastDoom codebase, but could be a good inspiration for adding support for new music devices. I've seen that it uses *.ADV files for the device drivers, but they seem to be compiled and the source code not included, is this true?
7F20 wrote on 2022-10-19, 03:36:
I think it's easier to create a new machine with an HDD inside 86box, and do all the process of installing DOS like in the old days. I'm pretty sure there are tutorials on YouTube explaining this process.
Reply 513 of 1275, by BitWrangler
Off topic meandering old man story about hard files
Back in the day, not that one, the other one, I had this demo of a PC/XT emulator for Win95 I think. It was restricted to floppy images, said full version came with tool to make HDD images... Now I had my Amiga 1200 networked to the W95 box with a parallel port PLIP cable and was using a util that made a hardfile which would support an amiga filesystem on a PC FAT disk, so basically one big file, that the Amiga put an Amiga filesystem on. Now, an amiga filesystem is a plug in, there's a default one, but you can install others such as CrossDOS which, you guessed it, is an MSDOS compatible filesystem. Can't remember how I discovered this, maybe I first managed to mount one of the floppy images on the disk of the PC over the parallel cable, on the Amiga. So I made a new hardfile on the PC from the Amiga, and I formatted it with the CrossDOS filetype, and copied some DOS files onto it, maybe had to use PCEM on the Amiga to make it a system disk, foggy on detail. Anyway, upshot was, that I managed to make a hardfile that the emulator under Win95 could boot off. Still had a 30 min time limit or something though. I almost have a point too.... there's gotta be a limited number of logical ways to do a hardfile so at least in lowest common denominator form, like under 500MB FAT16, maybe files created with one thing will work with another, when formatted and set up.
Reply 514 of 1275, by Alex_C
Thanks very much for this, especially the continued optimisation of Hercules. I now get a frantic 2.1fps on my 386sx/25 compared to around 1.7fps with one of the previous versions! Might finally upgrade this system to a DX/40 and see if I can hit 5fps.
Reply 515 of 1275, by leileilol
At this rate Fastdoom's supporting as many video modes as CompuShow 2000 😀
What's left? EGA 640x350x4 / VGA 640x480x4 dithered?
long live PCem
Debian's fucked
Reply 516 of 1275, by ViTi95
Alex_C wrote on 2022-10-20, 14:58:
Well those modes are more for 486 processors, since it's rendering at 320x200 (aka High Detail) and require additional cpu cycles to convert the backbuffer (in glorious 256 color) to any other mode. The only thing you can do to speed up is downsize the game screen, and hope for improvement 😅
leileilol wrote on 2022-10-20, 18:23:
Rare cards with rare and cool modes. For example I want to add IBMs PGC, 8514 and XGA support, but the main issue is that I don't own that hardware. XGA MCA support is partially done, but without hardware to test it's basically impossible to continue developing it.
And I'm pretty sure I'm not going to add VGA 640x480x4 support since the original mode is much better, and doesn't have to deal with planar layout. And the same for EGA 640x350x4, the 8-bit EGA ISA cards have so limited bandwidth (~500kb/s) that it's impossible to update the whole screen at more than 5 fps. Also there is the aspect ratio issue, I really hate when non-integer scaling is required.
What I really wan't to do is kinda unify some executables and cleanup the source code, it has become a complete mess. And somehow try to reduce the memory footprint by not loading all the sound card support at the same time, just the required "drivers".
BTW! I've made a video with the C/MS card playing Doom music ingame, @Tronix has fixed some issues and it's sounds incredibly good right now (even on my very noisy MUS-1099)
https://www.youtube.com/watch?v=XyhTluOBVbA
Reply 518 of 1275, by ViTi95
rasteri wrote on 2022-10-21, 11:07:
ANSI from hell 😁
I think I've found a way to use this technique on FastDoom, if I use a precalculated LUT (128Kb) I can bump the CGA resolution to 320x100 16-color with little CPU usage (although will require lot's of RAM bandwidth). Will not be 100% perfect, as some combinations won't be 100% close match and it will suffer from color clashing.
Reply 519 of 1275, by rasteri
ViTi95 wrote on 2022-10-21, 13:19:
If you didn't care about CPU usage you could do some fancy pattern-matching code and go the full 640x200. I bet that would struggle to run on contemporary processors never mind ones from DOS times, though...
