Reply 500 of 583, by Lostdotfish
rasteri wrote on 2025-03-22, 18:01:Lostdotfish wrote on 2025-03-22, 17:29:With both cables connected - holding the HIDMan button does not result in the menu outputting in the text editor (which is no surprise as no keystrokes seem to make it to the PC with both cables installed)
Aha - I had a look at a photo of your motherboard and it does indeed ground the spare PS/2 pins.
Looks like I'll have to add an option to disable the auxilliary pins on hidman's end too.
Just need to hope I can get it into bootloader mode long enough to flash it 🤣
