Reply 51540 of 59740, by Shadzilla
- Member
eesz34 wrote on 2024-01-23, 14:07:I did phone tech support for those around the time this one was manufactured. I can't remember if it was that case, but some designs had a problem where the power button didn't correctly push on the actual switch underneath.
Nice! I can well believe that, the mechanism is a bit rubbish. Appears ok on this one though, not tested yet mind you.
No Banshee sadly, it has an onboard 'AGP' Riva 128 chipset with 8MB, and onboard Creative ES1373 Soundblaster-ish sound. A distinctly mid-range system. This is the board - https://theretroweb.com/motherboards/s/intel- … ster,-micro-atx - part 4000431 which through some serious archive.org digging and research here I've managed to find the latest Gateway BIOS image in case it needs an update. Next job is to open up the PSU for a clean and inspection, test that, then see if it fires up. Last used about 18 years ago the owner told me.
