Reply 5240 of 5241, by H3nrik V!
- l33t
RetroPCCupboard wrote on Yesterday, 18:17:Nexxen wrote on Yesterday, 16:57:Is the Pentium a socket 4?
Full tower has P-II and P-III stickers, it was upgraded. My guess is 500MHz.Looks to be socket 7, but with a Pentium Overdrive in it? Not heard of that. I thought Pentium overdrives were for upgrading 486s. Could that be an MMX CPU in a socket that doesn't have dual voltage support?
Well, Pentium Overdrive came in different flavours. All had the purpose of making an upgrade "plug and play" and not having the user to set any jumpers or anything (except maybe for the 486->Pentium version).
It looks like here the laser etched marking in the top left cornor of the image says "200" so it's probably a PODPMT66X200 which is an MMX 200 MHz, with its own on-board regulator, making it highly plausible that it was use because of the board's inability to supply dual voltages.
I did, however believe that socket 7 was always dual voltage? Or was the only difference from socket 5 the extra available multipliers? Anyways, it isn't all unheard of that the physical socket is a socket 7 even the board is only socket 5 specs - it's been a question of avaliability probably.
