Reply 52920 of 58882, by Ozzuneoj
cyclone3d wrote on 2024-05-15, 05:17:
Ozzuneoj wrote on 2024-05-15, 05:11:
cyclone3d wrote on 2024-05-15, 04:39:
Been looking for one of these for a few years. Nope, I'm not going to show what all is in the box. A separate thread will be mad […]
A separate thread will be made about it once I get the time to dig into it.
Does the name on the box have anything to do with the contents?
I am... intrigued. 😁
Yes, the contents are in the original box.
Interesting! I think I found it. I don't really know what it could be used for these days, but I am curious how it fits into the scope of VOGONS. Very curious indeed. 😁
EDIT: The more I look, the more I find and the more interesting it sounds... and yet I still have no idea how you'd use it. 😁
Reply 52921 of 58882, by BetaC
Today I picked up some oddities. And a failing SS7 board that fried the K6 attached to it, but I'll pretend that didn't happen.
The attachment IMG_3433.jpg is no longer available
First are the golden MII-333 by Cryix and a proper intel 740. Neither is particularly great, but hey, they're there.
And lastly is this strange guy.
The attachment IMG_3437.jpg is no longer available
The attachment IMG_3434.jpg is no longer available
Yeah, a NetVision 2200i that can apparently also be used in a Mac? Looking it up online makes it seem like it's hot trash for mos people's uses, but at least it looks interesting.
Reply 52922 of 58882, by appiah4
Anyone know what PC this motherboard has come out of? I can't seem to find it on Theretroweb. It does not look like standard AT or ATX, so I doubt it can be put in anything except maybe a custom made case? So I guess it's from some kind of OEM? Compaq or HP maybe? Doesn't look like IBM to me..
Reply 52923 of 58882, by acl
PD2JK wrote on 2024-05-13, 10:49:
weedeewee wrote on 2024-05-07, 14:59:
PD2JK wrote on 2024-05-07, 14:12:
Well it's hardware for retro hardware. […]
A proper diagnostics card. Needless to say, more chips = better. 😉
The cheapest card (top) works fine in a PCI slot, but in an ISA slot, not so much.
or at least cut the ISA part off.
Consider it done. 😁
No idea about what the buttons and the buzzer are intented for. Never heard a sound out of my card and the buttons (at least some of them) seems to do nothing
Reply 52924 of 58882, by PD2JK
acl wrote on 2024-05-15, 08:25:
speaker and buttons
A two-lead cable wasn't supplied with this card, and the J2 header isn't soldered on, so they just could have left that buzzer off as well...
With the buttons you can go back and forth through the generated POST codes.
But again, for future readers, don't buy this card. The ISA part is useless and can harm your mainboard.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 52925 of 58882, by oh2ftu
oh2ftu wrote on 2024-05-12, 10:08:
Two eBay-purchases of late; Abit BX6r2 and a computer with Asus P2B. The latter has not shipped yet - so still waiting for both.
The BX6r2 had broken PS2-ports. I did know this at purchase.
Had a real hard time getting it to post, but it's was all about a dirty slotket, dirty and loose Slot-1 (missing supports).
Fixing the PS2-ports was easy. A 0-ohm resistor (marked as fuse) just next to a screw-hole was missing (sheared off). Replacing it fixed PS2.
Finding a BE6-II is quite hard, so this will have to do for my path down memory lane.
Reply 52926 of 58882, by Ozzuneoj
BetaC wrote on 2024-05-15, 07:53:
And lastly is this strange guy. IMG_3437.jpg IMG_3434.jpg Yeah, a NetVision 2200i that can apparently also be used in a Mac? Loo […]
Oh, nice! I'm not sure whether that particular model is Mac or PC compatible, but under that label is an Artist Graphics 3GA, which is a very early graphics accelerator that was sort of advertised as having 3D acceleration support but it doesn't appear it was ever implemented in the drivers.
The Saga of the Artist Graphics 2000i PCI
3GA cards are fairly rare these days, and I think that's one of the last models that used it. I have a couple of older 3GA cards myself.
Very nice find! 😀
Reply 52927 of 58882, by JvV
Bought myself a 'mystery box' locally for cheap with some gems in it:
Matrox M3D NEC Power VR PCX2 PCI 3D accelerator card:
The attachment IMG_6431.jpg is no longer available
Tseng Labs ET4000AX ISA videocard:
The attachment IMG_6432.jpg is no longer available
Soundblaster CT1350B ISA Soundcard with CMS expansion:
The attachment IMG_6433.jpg is no longer available
AM486 DX4-120 processor:
The attachment IMG_6434.jpg is no longer available
Diamond Stealth 64 PCI videocard:
The attachment IMG_6435.jpg is no longer available
Next to a bunch of Pentium CPU's / Memory / and other ISA/PCI/AGP various cards.
Reply 52928 of 58882, by zuldan
JvV wrote on 2024-05-15, 12:27:
Bought myself a 'mystery box' locally for cheap with some gems in it: […]
Very nice mystery box! Great gems
Reply 52929 of 58882, by BetaC
Ozzuneoj wrote on 2024-05-15, 11:34:
Oh, nice! I'm not sure whether that particular model is Mac or PC compatible, but under that label is an Artist Graphics 3GA, wh […]
Very nice find! 😀
I mentioned mac compatible because there is a jumper on it that mentions one setting for Mac, one setting for PC. I don't think there ever were mac drivers to begin with, if my google abilities aren't failing.
Reply 52930 of 58882, by eesz34
Don't need it, but I'm a sucker for hardware still in the box with everything originally included from this time period. And it's cool because it has VGA and digital output.
Reply 52931 of 58882, by JvV
zuldan wrote on 2024-05-15, 15:25:
Thanks, sometimes you get lucky 😀
Reply 52932 of 58882, by kingcake
Not hardware, but I found this sealed copy of QEMM8. Sticker on the shrink wrap says 7/30/96.
The attachment IMG_2150.jpg is no longer available
The attachment IMG_2152.jpg is no longer available
Protip: If your BIOS won't let you shadow XT-IDE, you can tell QEMM to do it and it boosts your IDE speed quite a bit.
Reply 52933 of 58882, by demiurge
Today I picked up some oddities. And a failing SS7 board that fried the K6 attached to it, but I'll pretend that didn't happen. […]
Yeah we are missing the Artists 3GA from VGAmuseum so I am a bit jelly. The funny thing is that the mac option would be on a PC monitor since the macs of the era had a different physical connector. There were cards with both connectors made but this isn't one of them.
Reply 52934 of 58882, by BetaC
demiurge wrote on 2024-05-15, 22:55:
As someone with too many classic macs, I'm well aware 🤣. I purposefully use G3 era Rage128s or the odd Twin Turbo M8 whenever I have PCI available so that I don't need to worry about DB-15 adapters.
Reply 52935 of 58882, by BitWrangler
eesz34 wrote on 2024-05-15, 19:31:
Cool to get boxed. That chipset I have had on other cards, seemed very "middle" speedwise of everything on ISA that will put out VGA in DOS, and maybe a bit lower in windows. So likely fine in 1x bus 486 and below, though might be middle of 386s where you don't see any difference at all between that and a GL5434 or something.
Reply 52936 of 58882, by myne
appiah4 wrote on 2024-05-15, 08:14:
Gut sets Compaq. Posting it or reading the bios chip might be the only definitive ways to be sure.
I built:
Reply 52937 of 58882, by ODwilly
No idea, but for a case idea find a basic ATX "workbench" (like the slide out trays of server/early ATX/AT that unscrew from the case). An ATX one is still usable, granted you can drill some holes and measure for standoffs that may not exist. Build a custom case around it. If you can rig it up enough to get it to boot and a bios string out of it, and can figure out the psu you will be good to go
Reply 52938 of 58882, by bjwil1991
Bought yet another CRT TV from a thrift store for $5 this time (was $10, red tag was 50% off that day).
A White-Westinghouse WTV1332, which is similar to the Daewoo DTQ-13P2FC I had when I was a kid until I was 18 or 19 (the RF jack broke off and that was the only jack on the set).
Sadly, it's RF only, but, my plan is to add composite and RGB to this thing in the future since I have the service manual that has the optional section for the AV ports and I need to do more digging to see if I need an EEPROM file from a set that has the AV ports to see if I need that before I do the mod.
Pics:
The attachment 20240513_134348.jpg is no longer available
The attachment 20240514_025135.jpg is no longer available
Reply 52939 of 58882, by PD2JK
Not entirely sure, but this MB-1333 board could be NOS, or used only for a short period.
First things first, apply some vinegar on that place where the battery once was.
The attachment DSC_9029.JPG is no longer available
Never seen Intel SIMMs before. 😁
