Reply 53580 of 60068, by Kahenraz
I was going to suggest they you had too much memory installed, but I only see one stick. Try loosening the timings or giving it slightly more voltage, is my best best guess.
Maybe there is some other fault in the board. The capacitors look okay from here. I have had instability from memory caused by aging capacitors before. If you downclock the memory significantly and the problem goes away, this might be another indicator.
Repair shops hate me. I fixed defective memory on my video card with this one neat trick.
Reply 53581 of 60068, by AGP4LIfe?
giantenemycat wrote on 2024-07-11, 18:12:
P4 2.6GHz/400MHz SL6PP
That should be a good cpu, its on the support list. This board is extremely picky about everything. It can't handle a lot of power to the cpu either because no P4 power connector. I have the exact same board but the ECS P4VMM2 version.
I would recommend reducing the cas latency to 2 in the bios. Mine always had trouble at the 2.5. I used DDR400 Memory, running at 266. (533FSB CPU Here) Also disable any fast write settings.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 53582 of 60068, by Wes1262
Reunited with my own ti4800 after gifting it to a friend 14 years ago. I asked it back. Lmao. I am hopeful it still works and that is not actually a SE.
Yes, the heatsinks are horrendous. I was a dumb kid. I will remove them and restore the original look.
Please send advice on how to remove "Arctic Silver™ Thermal Adhesive". Will isoprop soften it?
EDIT: The sticker says clearly ti4800 but it also says A2, presumably NV28GL A2, the variant of the chip that was only used (at least according to techpowerup) on the Quadro.
Reply 53583 of 60068, by AGP4LIfe?
Wes1262 wrote on 2024-07-11, 20:07:
Reunited with my own ti4800 after gifting to a friend 14 years ago. I asked it back. Lmao. I am hopeful it still works and that […]
Reunited with my own ti4800 after gifting to a friend 14 years ago. I asked it back. Lmao. I am hopeful it still works and that is not actually a SE.
I bet its a Full Ti-4800, I hope it still works for ya! they are rare 😁. There are A2's in the standard Geforce line.
Reply 53584 of 60068, by chrismeyer6
Just curious why you want to remove the ram heat sinks? I'd keep them on to allow cooler operation and a longer life span.
Reply 53585 of 60068, by Wes1262
I might have left them they were a little more plain. They are copper and the card bends under its own weight. I don't like that at all.
Reply 53586 of 60068, by Wes1262
I also got this. A way less desirable but still pretty cool Hercules Geforce 2 Ti
Reply 53587 of 60068, by verysaving
AGP4LIfe? wrote on 2024-07-11, 17:58:
giantenemycat wrote on 2024-07-11, 17:54:
I got this "Spacewalker" Shuttle MV43PN, which is a PCChips clone. I was specifically looking for a quirky 478 board and it fit the bill with its blue PCB, VIA chipset and options for either DDR or SDRAM.
But I think I have to give up on it. With SDRAM installed it will just freeze once it gets to the OS, if not immediately then within minutes. With DDR it doesn't freeze but executables will often halt stating some kind of "corruption", and when doing something moderately intensive it sometimes suddenly hard resets out of the blue. Looks like I got more than I bargained for.
What Cpu do you have in it?
I had a similar board and if I remember correctly,
the row of jumpers at the left of the memory slots
select the kind of ram to be used, another jumper
select the correct voltage.
Check a manual, according to this,
https://theretroweb.com/motherboard/manual/p4 … 9b114618907.pdf
in page 14 you have the jumpers configuration for
the memory.
Don't know if it's the exact board though.
Reply 53588 of 60068, by giantenemycat
verysaving wrote on 2024-07-11, 22:51:
I had a similar board and if I remember correctly, […]
the memory.
I don't have the big jumper, but I'm not sure what it's supposed to do exactly - it seems to just set which type of RAM is being used (SDR=off/DDR=on), but DDR still "works" without it. I can set the correct config of small jumper(3v)=on/big jumper=off for SDRAM, but that obviously still has issues, so I don't think it's related to jumpers. I've tried pretty much every config of 2 sticks, 1 stick in each slot, lower CAS, lower freq, SPD timings. No dice.
Reply 53589 of 60068, by cyclone3d
Wes1262 wrote on 2024-07-11, 20:50:
Leave them on. You have a very good chance of ripping off a RAM chip when trying to remove since they are epoxied on there.
You can always add a support bar for the card if needed. You can even buy pre-made adjustable bars now instead of having to come up with something yourself.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 53590 of 60068, by zwrr
The low price got the Creative Sound Blaster 16 CT2230 & CT2290. 😀
The attachment CT2230&CT2290-1_mini.jpg is no longer available
The attachment CT2230&CT2290-2_mini.jpg is no longer available
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 53591 of 60068, by Ozzuneoj
cyclone3d wrote on 2024-07-12, 01:18:
I was going to say exactly this. It isn't worth the risk of damaging anything trying to take those off, especially since this was his personal card and he did the mods himself. If it was going to be sold as a 100% original collector's item it'd be almost justifiable, but even that isn't really worth it in my opinion.
Honestly, I'd consider it a huge PLUS that this has an NV Silencer and RAM heatsinks installed. I would expect this card to outlast a lot of stock Geforce4 Ti cards since the cooling on them was only barely adequate.
Reply 53592 of 60068, by myne
AGP4LIfe? wrote on 2024-07-11, 19:04:
I'd be replacing the caps. Does it get unusually warm around the vrms?
I built:
Reply 53593 of 60068, by CrFr
Bought a Panasonic TC-15M2RC 15" CRT TV for use with older game consoles and home computers. I found the boxy shape with that weird speaker "hat" oddly appealing. This thing has excellent selection of inputs: RGB, composite, S-video and of course analog TV tuner. Picture is still bright and vivid, and the built-in speaker is also quite decent for unit of this size.
The attachment IMGP2376_.jpg is no longer available
Reply 53594 of 60068, by Kahenraz
I love that you called it a "hat".
Reply 53595 of 60068, by appiah4
Wes1262 wrote on 2024-07-11, 20:52:
That card AFAIC is 10x more desirable than a Ti-4800 😁
Reply 53596 of 60068, by Wes1262
appiah4 wrote on 2024-07-12, 08:34:
How so? It's not the Ultra. The timeline is this:
- June 2000: Geforce 2 Ultra, GTS, Pro are released
- Feb 2001: Geforce 3 is released
- Oct 2001: Geforce 3 Ti 200, Geforce 3 Ti 500, and Geforce 2 Ti are released
Basically it is the entry level card to the Geforce 3 Ti line. Nvidia had a lot of leftover NV15s, and they rebranded the card for the new entry level line.
Don't get me wrong, it is a nice card, I love it. I prefer it to the Ultra because I don't have to worry about breaking it heh.
If you overclock it, it's identical to the Ultra. Like, +/-5 3DMark 2001 points.
I have a Chaintech GF2 Ti that is called "Geforce Titanium Ultra" because it has stock frequencies that are the same of the Ultra, but uses the new Geforce 2 Ti layout.
I consider it equivalent to the Ultra (can be overclocked much more than Ultra frequencies), but it's not the actual original Ultra nevertheless.
The Hercules however looks particularly cool, because of its distinctive look. I am happy that I have it, but I don't think it's more desirable/rare than a agp8x ti4600/ti4800 😜
In the pics:
Chaintech 2 Ti Ultra (with the ram heatsinks and Ultra frequencies),
and Chaintech 2 Ti (with Nvidia's recommended frequencies).
Reply 53597 of 60068, by Wes1262
AGP4LIfe? wrote on 2024-07-11, 20:39:
Thanks, it is indeed a full ti4800. And it works. Ran 3dmark 2001 for a while. No issue. Scored around 10k (cpu isn't great).
Reply 53598 of 60068, by appiah4
Wes1262 wrote on 2024-07-12, 09:58:
How so? It's not the Ultra. The timeline is this: […]
In the pics:
All of that is true. Which still makes it more desirable to me than a GeForce 4 card.
Reply 53599 of 60068, by Wes1262
Geforce 2 Tis go for 50eur on ebay. The Hercules a little more. I've seen them pop up more than the other Geforce 2s. They must be pretty common.
