AMD K6 3DMARK, aiming for stars.
Reply 540 of 694, by Necrodude
Has anyone tried the BIOS patcher on the ASUS P5A motherboard? If so, any benefits?
Reply 541 of 694, by Trashbytes
I recently bought this board a Epox MVP3G5 with 2Mb L2 so when it arrives Ill be testing it out with both a K62 550 @ 600 and a K63+ 570 @ 600, so I may step into this thread with some results and benchmarks of how the board performs, I have a spare Ti500 that I will be using along with a Voodoo5.
The attachment Epox EP-MVP3G5.jpg is no longer available
Been a long while since I last overclocked on a Super 7 so I doubt I will hit some of the amazing scores here but this board should post some terrific scores without any crazy tweaking.
Reply 543 of 694, by NostalgicAslinger
Trashbytes wrote on 2024-03-29, 09:00:
Now all we need is for some lucky person to walk in with a K5 PR200.
My K5 PR166 runs completely stable (Prime 95 and DOS/Windows Games) with 133MHz (PR200), also with only 3.3V, instead of the stock 3.5V.
Reply 544 of 694, by Sphere478
I have a 166 I may play with but my fast ss7 setup is being a pain in the butt right now. Not surewhy but 3d won’t work on it
Sphere's PCB projects.
Reply 545 of 694, by Skalabala
Trashbytes wrote on 2024-03-29, 08:58:
Just go for 112*5.5 The CPU should be stable not sure if the motherboard will.
I am hoping you can get into club 5000 with that board! 😀
Reply 546 of 694, by Trashbytes
Skalabala wrote on 2024-03-30, 02:52:
I'm curious to see if the K63 or K62 will pull ahead, the chips can be a bit funny with some L2 cache, I've also read that this board performs best when limited so 384Mb of ram using single rank SD-133 sticks and can pull some crazy cache speeds with that config. Its no slouch with 768Mb either but no crazy cache speed shenanigans.
Board is reported to be exceptionally stable at a range of bus speeds and was built for overclocking so the bios has a silly amount of settings including a clamp for AGP bus speeds to lock it to 66Mhz if needed.
The more I read about the board the more excited I am to get my hands on it.
Reply 547 of 694, by Sphere478
Trashbytes wrote on 2024-03-30, 03:05:
I'm curious to see if the K63 or K62 will pull ahead, the chips can be a bit funny with some L2 cache, I've also read that this […]
Yes, I can confirm that mvp3 seems to really like single sided 128mb sticks. Though with a performance hit you can sometimes push that to dual sided. (Will be slower)
Reply 548 of 694, by frankmonk
Unfortunately the mvp3g5 does disable the onboard cache when running FSBs above 100.
There is no way around it even with softfsb or CPU cool. But I managed to run my CPU at 4x133 with onboard cache disabled. Performance wasn't as good as with the ALI Chipsets
Reply 549 of 694, by Trashbytes
frankmonk wrote on 2024-03-30, 09:04:
hmm which means the K6-3+ should pull ahead above 100 FSB due to its on die L2 cache.
I also wonder if its the BIOS disabling the cache or the chipset, if its the bios then possibly there is a modded bios or a way to mod it, I would think with 4ns chips that the cache would handle FSB above 100 quite well.
Reply 550 of 694, by Skalabala
I know there is something weird with those boards and overclocking with cache on. They wont even run at 105MHz.
My MVP3GM has two 512kb 4ns chips and it can run 112MHz stable and not 124Mhz
You might need to modify the motherboard
Don't be discouraged, make it work and teach us 😀
Socket 7 has came a looong way since I have started this thread 😀 And there are still things to figure out!
Reply 551 of 694, by Skalabala
Necrodude wrote on 2024-03-29, 08:06:
I have not, I do not see any benefits though. If I want to mess with BIOS I use TWK153
Reply 552 of 694, by meljor
Have not been in this thread for a long while, did anyone beat the scores of Asus P5A boards?
They are still my favorite boards and years ago i had many ss7 boards of different brands and Asus boards were faster. Mvp3 didn't come close and while gigabyte (ali V) did clock higher they didn't score better.
Never recapped and still running great i kept the Asus boards and the gigabyte's. Maybe still have 1 mvp3, the rest is sold. One day i will find the time and patience again to try and beat the score.
I was so close years ago, and yet so very far away! 😀
Reply 553 of 694, by Skalabala
meljor wrote on 2024-03-31, 09:52:
Have not been in this thread for a long while, did anyone beat the scores of Asus P5A boards? […]
Welcome back! No one close to my score yet 🙁 I am hoping for someone to beat it so that we can learn more about SS7! 😁
Reply 554 of 694, by Sphere478
Skalabala wrote on 2024-04-02, 00:05:
Can you write a guide for that setup?
Reply 555 of 694, by Skalabala
[/quote]
[/quote]
I cant remember 🤣 but there is some info on my youtube video of the run.
https://www.youtube.com/watch?v=pwG7RtFFXgo
Reply 556 of 694, by SWZSSR
Just had my FIC PA-2013 fully recapped. I luckily have the revision without the weak agp power controller chip that burns out.
Will do some benching in the next few weeks once I found a case for it and… time.
LS486/5x86@180/Banshee/SoundscapeElite/DOS6.22
5TH/Dual233MMX/MGA2164W/Voodoo2/AWE64Gold/NT4.0&W9X
P5A(1.6)/K6-3+550/Ti500/EWS64XL/W9X
CUV266D/Dual1.4TUAL/HD4670AGP/XONAR/XP
780iFTW/QX9650/3x8800U/VISTAx64
Z87/4790K/TITANX/AuzBravura/XPx86
Reply 557 of 694, by Skalabala
SWZSSR wrote on 2024-05-12, 01:20:
Is that a 2Mb board?
Reply 558 of 694, by magicmanred
Figure I join the fun...
I have a couple boards at my disposal.
GA-5AX 5.2 (Chipset "E")
P5A 1.06 modded 1kohm (Chipset "G")
Both 512k Cache.
Reply 559 of 694, by Skalabala
That is a good CPU score for 633MHz
