Reply 540 of 1968, by MBH
crazii wrote on 2023-04-23, 10:37:MBH wrote on 2023-04-23, 10:16:Maybe I used the wrong word. It just freeze with playing the last sound. There is no error message and Ctrl+Alt+Del is not worki […]
crazii wrote on 2023-04-23, 07:55:BTW what's the crash message?
Maybe I used the wrong word. It just freeze with playing the last sound. There is no error message and Ctrl+Alt+Del is not working. I have to switch off the IGEL, because it lacks a reset Button. The time or situation when this happens is different each time. Sometimes it freeze in intro of Duke3d, sometimes I can play several minutes. Same happens with Quake. Without SBEMU, and because of that without sound, I can play for hours.
Thanks for testing again on your machine.
Edit: I don't know if it's helpful. But I "think" the voice of Duke is a little slow. Maybe 20%. But I can't tell for sure.
The duke voice is playing good here... I'm afraid that I need a real machine to debug it. that might help, or not. but it always involves another debug machine. 🤣
As I already told you, I want to buy this machine for you. I always have a really bad feeling, if someone has to spend money just for helping me! My machine is "IGEL 4210 LX", and it's all VIA inside.
Edit:
https://www.parkytowers.me.uk/thin/Igel/4210/
The Mainboard is WinNET P680, which is also used in
https://www.parkytowers.me.uk/thin/neoware/CA22/
Edit2: Wait! I think I found the (my) problem. As I'm using a notebook for DOS too, and they share the same config, I've copied the "problem" from one to another. On the notebook I'm using power.exe to stop the fan from spinning all the time. That's causing the problem on the IGEL with SBEMU. Without SBEMU (and without hdpmi32i of course), power.exe makes no problem. But with, it will freeze after some time. Played the first level of Duke3d without any crash/freeze. Will do some more tests, but it looks like that's the problem. For the duke voice, maybe I just can't remember it right. Probably it's right how it is.
