Reply 54520 of 58960, by PcBytes
Nothing interesting today... ECS KT600-A w/ a Sempron 2600+ and two RAM sticks.
Reply 54521 of 58960, by momaka
I missed the flea market last weekend and also couldn't go yesterday due to stomach problems. So I went today... but rain interrupted it and it all ended early.
Nevertheless, this is what I got:
- a Seagate U10 (ST310212A) 10 GB 3.5" IDE HDD - untested, as usual. Just shy of $2, so still worth the gamble. I finally managed to test some of the IDE HDDs I've been getting from this flea market, and so far had good luck. Granted all of the working ones have a few bad sectors on them. But they do work fine, so they'll be OK to use on a retro rig (especially one that doesn't see daily use.)
- Gigabyte GA-M61pme-s2 socket AM2 mATX motherboard. Untested, sold as scrap PCB. Probably should have looked a little closer at it, since the back is pretty scratched up and some traces look torn / broken. But it was starting to rain pretty hard and I just didn't care. Neither did the seller - he reduced the price down to 50 cents. I gave him $1 simply because I didn't feel like looking for change... and because it was raining and getting cold. 🤣 With any luck, if the GeForce 6150 chipset in that thing is still OK, I should be able to take care of the broken traces and most other stuff (if any.) Caps look OK and are OK series, AFAIK. I don't really have a build in mind for this board nor any spare parts for it. Only got it, thinking that if/when the ECS MCP61PM-AM mobo in my Gateway GT-5656 completely dies, I can put this on in it's place with the original Athlon X2 6000+ and pretty much keep the PC the way it was. The mobo in the GT-5656 is already on its way out.... though it's been that way for ~5 years now. Every now and then I have to flex the motherboard and put huge pressure on the chipset to get it going. Then it works fine for a while. Then it doesn't. Wash, rinse, repeat... and here I am still tolerating it. It's a beater retro gaming PC, so I have absolutely zero care for it... yet I do care for it, because I don't want it to die, because it has a good deal of the retro games I like to fire up once in a while. Anyways, we'll see when I get to the Gigabyte mobo above. I'm quite backed up with projects lately and piling up even more.
- Deepcool socket 775 (or perhaps it's a 115x) cooler. Nothing too special - extruded aluminum and 92 mm fan. Looks very much like a stock "full height" Intel cooler, except it uses a proper screw tension mechanism with a metal backplate for the mobo, rather than stupid push pin design. Fan is a 3-pin type, though, so I'll probably have to replace that, which is no biggie (I have a huge box of these.) I do like the black anodized look on the heatsink, though. For $1, it was a no-brainer.
- large-ish socket 370/462 cooler with a 70 mm fan. Heatsink isn't that big, so probably won't be any good for any of the more power-hungry Athlon/XP's. But probably will be fine for my Duron 750 or 1400 Applebred... or just as an over-sized Pentium III cooler with the fan running at 5V only. In fact, that last idea was what I had in mind when I went back to the seller to buy it. At that point, it was just starting to rain and she reduced all the small items to 50 cents. So I got it and the item below for $1.
- 3.5" 1.44 MB standard floppy drive. Alps-branded. No idea if it works. Has a piece of paper and other garbage inside. Probably some kid stuffed it who knows when way back.
And that's all my retro purchases for this and last week.
I also found a pair of Philips over-the-ear headphones that were abandoned, along with a wireless mouse of some sort (with the receiver missing.) The mouse will go towards my scrap/parts pile, but the headphones look OK, minus a damaged jack and being a bit dirty.
BitWrangler wrote on 2024-09-28, 21:43:
better start planning to live another 2 decades 'coz I'm slow as shit.
Ooooff, that statement hits really hard at home for me too.
More like, I need an extra century to finish all of the projects I have started.
Yeah, I work slow as molasses too. The good thing is, when I do finish something, usually I've put so much thought into it that it then works flawlessly and reliably... well, usually. 🤣
Shadzilla wrote on 2024-09-25, 07:53:
Interesting information, thank you! I've had that thought in the back of my mind - even if it's been unused the components may have started to degrade inside - so I've considered having it checked out, maybe I'll need to prioritise that just in case.
Well, just crack it open and see for yourself. Nothing dangerous with these, especially if it's been unplugged for a long time. AFAIK, there's only 4 screws that hold the back cover on. Need to flip the CRT so that it's screen down facing the ground before you do that, though (and don't forget to put the screen on a clean towel or something similar, to prevent scratching it.)
The tube is supposed to be a Diamondtron, which I thought was a Mitsubishi thing? Unless that's more of a generic term and it was made by other manufacturers as well?
I would be surprised if the same model uses a completely different tube.
Diamondtron (and Trinitron) tubes use aperture grille, which is a completely different animal from shadow mask tubes (Hitachi, Samsung, ChungHwa, just to name a few.) Thus, specs would have to be different for the same model of CRT, which doesn't make sense. So probably yours is the same as mine (or at least a shadow mask tube from another manufacturer.)
Of course, you'll know when you fire it up. 😉
Diamondtron and Trinitron tubes have two very faint dark horizontal lines (the tension wires for the aperture grille) that will be visible at approx. 1/3 and 2/3 down the screen.
Shadow mask don't have this.
Wes1262 wrote on 2024-09-29, 04:48:
It has a very fixed artifact like a large stripe in the middle of the screen. Probably memory?
Memory rarely goes bad in these old GPUs. Usually it's the memory-to-GPU connection that gets faulty on the GPU chip (die to substrate connection issues - i.e. bumpgate issue.)
The problem is that these (and really most high-end) cards run too hot and cook themselves.
Give it a reflow or three and it might come back. No need to reach full solder-melting temps. Even a lower-heat reflow can get the GPU working again... though don't expect it to be a long term fix, especially if nothing is done to keep the load temperatures in check. For ATI/AMD stuff, I think 55-56C is as high as anyone should go, at least if you want a longer-lasting GPU.
fosterwj03 wrote on 2024-09-29, 13:33:
I feel the same way. The GTX 480 I mentioned earlier in the thread posted fine on the first boot. It shorted out as soon as Windows began to load with pre-installed drivers. A single test in Windows 7 would have found the fault before listing the item for sale (of course, this fault might have damaged the seller's equipment like it did mine).
If the card really shorted out (and now can no longer power up at all), then that's just down to poor luck on your end. There's no way anyone can know when that will happen. I had the same happen on a Pentium III motherboard I got for cheap in a junk PC. Initially, it worked OK and powered into BIOS. Then I turned it off, attached some HDDs and an ODD for a test, and the clockgen chip decided to go bye-bye on me - overheated and died a silent death.
Repo Man11 wrote on 2024-09-26, 14:03:
Has this happened to you? You spot a beige rectangular something somewhere and immediately think "Is that an abandoned computer?" only to get a good look and realize it's actually an abandoned microwave...
Nope. 😁
As an oldie trash picker, I can spot the MW from pretty far away... and I do usually pick them up. Sometimes they do confuse me as a small CRT TV from very far away. But those I sometimes pickup too. So I always get closet to see.
I think the worst are white rectangular cardboard boxes. Those are by far the ones that confuse me the most when I see them from far away and get my hopes up that it's an old beige PC.
And speaking of that, it has occurred to me that this hobby of playing with/working on old computer hardware probably seems as strange to many outsiders as collecting old toasters or microwave ovens would.
Well, the people who collect old toasters, microwaves, and other similar stuff don't really do it for the purpose of collecting as a hobby. Typically, it's scrappers. MW ovens and CRT TVs are particularly valuable, because they have lots of copper inside (for MW, it's the large HV transformer, and for CRT TVs and monitors, it's the yoke windings.) Sad part is, these two are never spared, even if they are decent high-end models - especially the TVs and monitors. With MW, at least sometimes someone might pick it up to use as a "beater" MW in the garage or similar (provided it works.) I actually collected several in the last few years. One worked, so I donated it after I cleaned it. The other two were dead and not worth restoring/fixing (one had a badly bent door, and the other was too old and beaten on the outside.) So I took them apart for their parts.
Reply 54522 of 58960, by TheMobRules
Ages waiting for an MT-32 (old version, without the phones jack) to pop up at a reasonable price, and I managed to get one in the original (but beaten-up) box via proxy from a Japan auction. Yay.
Once it arrived, I tested it and everything was good. Until I opened it for cleaning as it was a bit dusty, and inside I find a sticker indicating it was serviced in 1990 by Roland... the "repair" apparently consisted on replacing the entire mainboard with the new version, only the phones jack was de-soldered so it would fit in the old-type case.
So, now I'm stuck with this thing that I have no use for (I already have another "new version" MT-32 and a CM-32L) and I need to go through the hassle of selling it. I think I'm done buying synths for a good while, maybe forever.
I already knew that some MT-32s without phone jacks could have the new version mainboard, but since it's so difficult to communicate with these Japanese sellers to tell them to open the unit or display the ROM version I figured "what are the chances of it being a serviced unit?". Well, looks like fate was against me on this one.
Reply 54523 of 58960, by BitWrangler
momaka wrote on 2024-09-30, 01:08:
I have a beater microwave in the basement that I picked up a decade and a half ago off the curb. It was only a little dented then. Was going to give it to someone who was moving in their own place, but it turned out they had a built in microwave above stove. So it went in the basement for spare, a couple of months later it was in our kitchen because our "good one" died, used it a few months, found a deal on a microwave, used that 18 months, that died, back to the beater, few months, wait again, microwave on sale... that one lasted 2.5 years.. beater in service again... got pissed off with these new ones dying so quick so we used beater about another 3 years but it was getting a bit nasty, rusting out around door and where the wheels roll for the turntable... finally bought another new one and touch wood that is lasting well so far... But yeah, that curb microwave has done about 7 years total service, longest since an old GE that my wife got in the 90s.... so still got it, rubbed the rust with cooking oil and got it on standby....
Reply 54524 of 58960, by BitWrangler
Shponglefan wrote on 2024-09-29, 00:19:
Nice find! I have that same monitor. […]
BitWrangler wrote on 2024-09-28, 23:58:
So this is what happened later. Marketplace deal for an EGA monitor. Packard Bell "Enhanced Color Graphic Display" PB1431EG. I w […]
So this is what happened later. Marketplace deal for an EGA monitor. Packard Bell "Enhanced Color Graphic Display" PB1431EG. I was expecting it to be a little smaller, since many CRT that got called 14" were more like 12 and change. It is nearly as large as my IBM P70 Trinitron, but not near as heavy.
The power cord is toast and I need to replace it. I am wondering about putting a "mickey mouse socket" in there. [o*o]
I cannot find many details about it online. I had seen one ad where they said it did both CGA and EGA, differentiating the EGA only by leaving the word color out of the name. But I don't know. This site says it does CGA too https://choiceprinters.com/video/TTL/PACKARD_ … L_PB1431EG.html and that I overpaid a little (Hey Ensign Nemo, read that page carefully)
Anyhoo, plan is for it to be a match to my PB 286/12 and also to get hooked up to other stuff to try, I have the badge brother of the VX88, also made by Samsung I think, which I will give it a whirl on when I am sufficiently assured CGA won't blow it up. Round the back it even has a text button which I guess turns output mono, though I don't know which color and don't know if that means it will take herc/mda too.
I can confirm it will do CGA, but not Hercules/MDA. The monochrome switch on the back just makes the output look monochrome green.
The attachment DFI ITOX G7S620-N testing CGA-Hercules adapter.jpg is no longer available
The attachment Packard Bell Monochrome Switch Testing.jpg is no longer available
Not that I didn't believe you, but in attempting to dig up a user manual or service manual for it, I did find some official specs in a brochure which I attached in the Packard Bell thread... Re: Post your Packard Bell computers here!
The TL;DR is Max Res: 640x350 Hsync: 15.75 or 22 khz ("or" specified not to) DotPitch: 0.31 Colors:16/64
Reply 54525 of 58960, by AGP4LIfe?
Just came here to say, don't bid on items when you are half asleep at 2:00AM.....
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 54526 of 58960, by pete8475
AGP4LIfe? wrote on 2024-09-30, 15:19:
I bought a baby AT socket 370 motherboard last night on ebay at about 3am.
aka pete4237.5
Reply 54527 of 58960, by ThinkpadIL
To do what? I already forgot what is it to buy anything on eBay. What costed only a year ago $50 now costs $500 and that's not including shipping costs which are also sky high today (and are expected to go even higher in the future).
Last time I tried to negotiate a price for some item I wanted to buy, do you know what told me a seller while offering still a very high price even after a discount? "I will make only $40 on it (only $40!!!) and if you can't afford it, don't buy it". It seems that those eBay sellers think that they are car dealers that selling modern sportscars instead of old computer crap. The whole world went nuts. 🤪
Reply 54528 of 58960, by PC@LIVE
A batch of RAMs arrived today, the batch was only for the 72 PIN RAMs, I received the others as gifts from the seller.
The 72 PIN ones are six of 8MB and two of 16MB, I already have some similar RAM, but I have some motherboards to try, and having others is convenient for me, rather than being left without, or with those of only 4MB each.
The free RAMs include a single 30-PIN 1MB bench, unfortunately in the absence of the second module, the use that can be made of them is only for some sound cards.
There are a couple of 30 PIN SIPs, 256KB each, I don't think I have a PC to install them on, many 286s would be suitable, however I will keep them for collection.
Finally the SDRAM, a pair of 512MB PC133, and a pair of 128MB PC100, these are very useful for me, given that I will soon be working on a pair of Slot1 with Intel BX chipset.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 54529 of 58960, by BitWrangler
The 512s might only work on Athlon or P4 SDRAM boards.
Reply 54530 of 58960, by PcBytes
The 512s will work on 694x boards as well. I know this as I have successfully ran 3x512MB on a LuckyStar 6VA694. They also work on dual-CPU 694X/694XDP boards too, since XDP is just standard 694X used on dual-CPU boards.
Anyways, just wanted to chime in to say that one of the two Athlon XPs I got in the mobo haul in my earlier posts is suprisingly fake, being a rebadged XP-M.
Reply 54531 of 58960, by Wes1262
what did you buy? 😁
Reply 54532 of 58960, by eesz34
The last microwave I threw out was from 2007 and had aluminum windings. So much for that.
Reply 54533 of 58960, by Starlance
Was gifted a Gigabyte LGA775 MB with a Q6600, might turn it into a nice XP system and see what I can OC too.
Reply 54534 of 58960, by AGP4LIfe?
Picked up this very nice boxed FX5500 in pristine condition from Ebay for 35$ + shipping.
Looks almost like new!
The attachment PXL_20241001_000934799.jpg is no longer available
The attachment PXL_20241001_000957156.jpg is no longer available
Except.... It's not a FX5500 inside 🤣...!
The attachment PXL_20241001_001403950.jpg is no longer available
It's a full 64MB GeForce 256 DDR with DVI! 🤣 Wow!
I think someone upgraded their dell and put the old GeForce 256 card back in the FX box. New seller had no idea and sold it off for 35$! Works perfectly and looks almost new . A steal of a deal!
Reply 54535 of 58960, by appiah4
I see 486, I can't help myself..
The attachment ASUS VLI-486SV2GX4.jpg is no longer available
The attachment DataExpert EXP-8046.jpg is no longer available
The attachment PCPartner C0064-10 (B).jpg is no longer available
The attachment Gainward GW201A.jpg is no longer available
The attachment Cyrix 5x86-100GP.jpg is no longer available
Reply 54536 of 58960, by acl
AGP4LIfe? wrote on 2024-10-01, 03:18:
Picked up this very nice boxed FX5500 in pristine condition from Ebay for 35$ + shipping. Looks almost like new! […]
The attachment PXL_20241001_024922870.jpg is no longer available
I've seen the other way more often 🤣
Box for a desirable part... with crap board inside.
I witnessed this last week when a Boxed Voodoo banshee popped locally. Sold instantly to some impulse buyer. But when i watched the other pictures, it was in fact a Trident card inside.
And then, a few hours later, the ad re-appeared as "Voodoo banshee box only"...
I would have been happy to see this impulse buyer being taught a lesson about carefully watching before buying and receiving a Trident instead of its voodoo... but it appears that he was able to cancel the order... At least i hope he heavily sweated when he saw what he bought.
Reply 54537 of 58960, by PD2JK
appiah4 wrote on 2024-10-01, 09:06:
[attachment=3]DataExpert EXP-8046.jpg[/]
That's an awesome board. PCI/VLB/ISA yeah...
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 54538 of 58960, by Wes1262
I am so jelly for the GF256 😁
Reply 54539 of 58960, by myne
PD2JK wrote on 2024-10-01, 11:42:
Isn't it just. Didn't realise anyone ever mixed vlb and pci
I built:
