Reply 55080 of 60088, by Horun
pete8475 wrote on 2024-11-10, 04:28:
Ordered a couple of things on ebay today. Sellers pics.
PCPartner BXBS3-C930 (AT 440ZX socket 370)
Pentium 3 1GHZ (100MHZ FSB)
Nice looking board (other than the dual PSU thing <has always disturbed me when an AT board has a ATX PSU connector.. just not right 🤣>) .
Hope you have good luck with it !
Reply 55081 of 60088, by PC@LIVE
Got a batch of old motherboards today, there's also a power supply included, but I think it's a poor quality one, there's also a CD player, all stuff that might not work, but looking at the motherboards, it shouldn't be difficult to fix them, in one you can see some swollen electrolytic capacitors, a sign that if they are not broken we are very close.
Two are for S.462, ABIT and Gigabyte, the other is a PCChips the model should be i810 and something, I have a similar or the same one, I'll try to get them both.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 55082 of 60088, by AGP4LIfe?
My latest pickup! It's not particularly extraordinary, but for one reason or another I couldn't ever seem to get my hands on one for a decent price.
A GeForce 2 Ti 64MB, with 4ns ram.
I specifically targeted 64MB and 4ns. ram. that way it's basically guaranteed to run at or above a GF2 Ultra. Since the core is die shrunk, compared to the ultra. It lowers heat/power and increases core overclock ability.
Excited to have it in the collection!
The attachment PXL_20241110_172316053~3.jpg is no longer available
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 55083 of 60088, by CMB75
Yesterday I went through a system I bought a while ago to take a closer look at what’s inside. I bought it for the case so probably nothing special.
Soltek SL-54U5 mainboard
AMD K6-2 500 CPU
128MB RAM
ATI Rage 128 AGP
Noname Voodoo 1 PCI
Noname Sound ISA
as expected - but until you open it you always have high hopes for a gem 😉
Reply 55084 of 60088, by Wes1262
AGP4LIfe? wrote on 2024-11-10, 21:12:
Love the GF2Ti! A lot of GF2Ti have 4ns ram I believe, very dumb that they made it slower than the Ultra, since it can clearly be faster.
Reply 55085 of 60088, by mockingbird
Those QFP RAM chips are notoriously unreliable. The SOP versions are much more reliable.
(Decommissioned:)
Reply 55086 of 60088, by zuldan
Wes1262 wrote on 2024-11-12, 03:16:
How do you check for the 4ns ram? I have a few GFS2Ti's I'd like to check.
Reply 55087 of 60088, by AGP4LIfe?
mockingbird wrote on 2024-11-12, 03:24:
Unreliable in what way, like bad overclocks? Or artifacting?
It works great "currently" I pushed them all they way up to 255Mhz (510) before I ran into any problems. Which is above rated speed although barely, and 25Mhz above the ultra stock mem clocks. 😎
Reply 55088 of 60088, by AGP4LIfe?
zuldan wrote on 2024-11-12, 03:35:
Just look at the last number on the last row of your ram chips. Usually that number indicates your ns speed.
In this case it's 40 or 4.0ns. might also be T-5 or G-6 or similar, which corresponds to 5ns and 6ns ect.. ect..
The attachment PXL_20241110_172316053~5.jpg is no longer available
Reply 55089 of 60088, by CMB75
Isn’t it ironic? Sometimes you get rid of stuff selling it off because you think you don’t need it anymore and a couple of years later you feel the urgent need to have exactly that item and of course you’ve got to pay up.
Another returnee, a Diamond Stealth S3 Trio64V+ … according to the seller tested, working, NOS and it comes with 4MB (I didn’t know that existed) … according to the pictures four chips KM416C254BJ-5, EDO DRAM, 256KX16, 50ns which should be .5MB times four equals 2MB if I’m not mistaken. But of course it was tested.
Anyhow, I just hope it works if it arrives.
The attachment Diamond Stealth S3 Trio64V+, Rev.P.jpg is no longer available
Reply 55090 of 60088, by mockingbird
AGP4LIfe? wrote on 2024-11-12, 04:24:
They just die... I think I have only one card out with them that still works.
(Decommissioned:)
Reply 55091 of 60088, by nfraser01
RetroPCCupboard wrote on 2024-11-07, 22:33:
Took me a while to figure out which pins were bent and to straighten them enough to get the CPU in, as my eyesight is poor.
Some (can't recall who) mentioned the credit card trick: A standard credit/store card is exactly the correct width to go between the pins on most CPU's with pins. Just run it gently up each channel and then do the same for the 90 degree. Worked for me in the past...
Reply 55092 of 60088, by Kahenraz
CMB75 wrote on 2024-11-12, 05:54:
Isn’t it ironic? Sometimes you get rid of stuff selling it off because you think you don’t need it anymore and a couple of years […]
What is that extra port for that looks like an audio jack?
Reply 55093 of 60088, by Pino
My latest pickup! It's not particularly extraordinary, but for one reason or another I couldn't ever seem to get my hands on one […]
I have the PRO version of this card and this cooler sucks. The design makes no sense at all, not sure how they thought it was a good idea.
If you are thinking about overclocking you should try to replace it.
Reply 55094 of 60088, by CharlieFoxtrot
Just got these. The first is Epox 7KXA Slot A motherboard. It came with Athlon 650MHz. I already left the CPU to my workshop and naturally forgot check the actualy type, but I think it is Argon as it has silver heat plate under the heatsink. I think Pluto has black one, but I may be wrong. Neat thing is that it even has the IO plate. Seller has buttloads of retro computer stuff and he said that he at one point tested it and it worked, but it requires recapping. And indeed, two VRM caps are bulging and there is probably zero stability left, so I need to do this one before I seriously start tinkering with it. Bought the CPU and MB for 40€. These Slot A boards pop up very rarely locally nowadays, but I really wanted one and I find the platform really cool.
Rest of the stuff is from different places, a new unused Cooler Master SECC cooler specifically "aimed" for Slot A and 750MHz Pluto.
The attachment Epox7KXA.jpg is no longer available
Next is one of these cute tiny 386SX boards, specifically TMC/MyComp/MyNix/Megastar PAT3XAL (VER. 2.0) with 40MHz Am386SX-40. It came with an IO card and four sticks of RAM, my guess is that it is 2x1MB + 2x2MB sticks, but I didn't check them that closely. Gladly the Varta battery was removed early and it is very clean. There is tiny amount of corrosion on couple of jumper heads and some diode/resistor legs, but nothing big and all it should need is a bit more thorough clean and it is good to go. I paid 30€ for this lot. I originally bought this as a compact bench ISA test bed, but I'm currently waiting an AT desktop case to arrive and I may even throw this in it. It must look absolutely hilarious in a case that as far as I know should eat full AT size motherboards.
The attachment PAT3XAL.jpg is no longer available
I also got few CPUs and some misc cards, but I need to sort those out. Pics may or may not come next weekend or so.
Reply 55095 of 60088, by BitWrangler
CharlieFoxtrot wrote on 2024-11-12, 17:30:
I originally bought this as a compact bench ISA test bed, but I'm currently waiting an AT desktop case to arrive and I may even throw this in it. It must look absolutely hilarious in a case that for all I know should eat full AT size motherboards.
Heh, next time my full AT tower is de-encumbered I should stage my half baby AT board in it for the hilarity pics.
Reply 55096 of 60088, by Thermalwrong
Pino wrote on 2024-11-12, 16:40:
It's not a terrible design, just incomplete. Needs a shroud: Re: What retro activity did you get up to today?
Reply 55097 of 60088, by Wes1262
Leadtek heatsinks are just for show. Some look very kitsch too, with weird font choices. Never been a fan (badum tss). Also I think, should that fan fail, you cannot replace it with any other fan, because the header and the temperature sensor are proprietary.
Reply 55098 of 60088, by CMB75
Kahenraz wrote on 2024-11-12, 16:32:
That's indeed an audio jack for external MPEG audio out.
Reply 55099 of 60088, by Masterchief79
Quadro FX4400 (6800 Ultra 512MB) and Epox 9NPA+. Will be my new retro-LAN PC and the board got recapped already. Not my cheapest purchase for sure.
