Reply 55160 of 60088, by pitchshifter
Horun wrote on 2024-11-17, 19:06:
pitchshifter wrote on 2024-11-17, 16:15:
Hi, got a Asus V3800 Ultra brand new.. Is working well on a my test rig Willamette board, 1.5 agp. The thing is i want to use it on my slot 1 rig 3.3 agp by the fan dont spin and gets quite Hot.. Any tips?
The fan should have a plug-in to the board. You can test wiring it direct to 12v off one of the molex HD connectors and see if it spins..
But she is working well on the test bench, again its agp 1.5 in the test bench and 3.3 agp in the slot 1. Could this be the issue?
Reply 55161 of 60088, by Horun
pitchshifter wrote on 2024-11-17, 19:10:
Pin 1 side A in the AGP slot is 12V no matter if 3.3 or 1.5 slot. Maybe the fan uses some other non main volt pin to get its volts (both AGP type have exact same pinout for the main +12 and +5 and +3.3 supply volts)
Reply 55162 of 60088, by zuldan
Grabbed this Chieftec Dragon (Antec). It has some scuff marks but what do you expect for an old case. It comes with a Gigabyte GA-M52S-S3P with a AMD Athlon 64 X2 6000+ in it but I'm going to swap it with a Asus Maximus II Formula with some OCZ Reaper HPC Edition DDR2 and running a Q9650.
The attachment 1.webp is no longer available
The attachment 2.webp is no longer available
Reply 55163 of 60088, by myne
bestemor wrote on 2024-11-15, 23:18:
Bought an MSI 694T Pro, paying a bit too much, but it was a locked package deal with a Pentium3 + full set of RAM. And it was s […]
And it was supposed to be my very first ever mobo combining socket 370/Tualatins natively with (one) ISA slot, so I went for it.
https://www.msi.com/Motherboard/694T_Pro/support
But... I am not able to get it to boot!
Now, this mobo has an interesting 'traffic light' system, using 4 diodes to code certain levels of progress at boot, quite visionary for such an old board.
The cpu itself seemed to be the first issue, as I could not get it past the first hurdle, the Power ON.
Swapped out the cpu, and voila, we got to level 3 in my picture, memory detection. Where it got stuck again, and is where I am now.
Even after trying several versions of random memory sticks I have, from 16Mb and up, moving it into all the 3 slots one by one, still the same result.
So, given that my RAM is fine, I am clueless of where to go next.
Now, have to mention, 1 single capacitor, the largest on the board, and number 2 down from the top (left side of CPU socket) has a visible bulge.
So that may or may not prevent booting. But I have booted boards with semi-bulged caps like this before, on board of the same era, so was hoping to at least get into the BIOS/see POST.
The rest of the board shows flat caps all over, not that it necessarily means they are fine, but... the seller tells me it booted/was working 1 month ago, so who knows.
Apart from swapping out the BIOS chip (have already reset it several times) or fixing that cap, I know of no further tricks to try.
-> If anyone owns this board, feel free to share any trouble shooting tips here.
Such S370+ISA boards are not that common (anymore), so it would be bummer if this one had to be scrapped.
From the manual (also available as download in that link above):
The attachment MSI 694T-PRO__oversikt lyssignaler i manualen.jpg is no longer available
Bulged cap is here:
The attachment MSI 694T-PRO__bulged cap placement.jpg is no longer available
Got a multimeter?
Check if the cap is short.
If yes, pull it f from the board and retest.
Since it has others in parallel, it should at least post without it.
I built:
Reply 55164 of 60088, by CMB75
Of course I had to jump onto the bandwagon and bought a core 2 quad Q9650. Because I'm a scaredy-cat I overpaid a little and bought a used one from Europe instead of a NOS one from China. Maybe my chances are better not to get a new chinesium fake one. Fingers crossed...
Reply 55165 of 60088, by dona311
zuldan wrote on 2024-11-18, 02:07:
Nice find! I'd like to find a similar case here in Italy, buy in my area good "old" cases are very scarce.
It will definitely be a nice build!
Reply 55166 of 60088, by bestemor
myne wrote on 2024-11-18, 05:39:
Got a multimeter? Check if the cap is short. If yes, pull it f from the board and retest. Since it has others in parallel, it sh […]
Bulged cap is here:
Got a multimeter?
Thankyou for the tip!
No multimeter available, and don't wanna mangle the board quite yet, if I have to return it.
But option duly noted. Will test some more with other things before I report back to the seller, and then we'll see what other options there are from his response.
(..as for the bulged cap itself, it looks very different from all the others on the board, being the lone tallest one there.
But if the smaller ones next to it can cope without it, for a boot/post at least, I might try getting it off at a later time, after borrowing a multimeter that is.)
Reply 55167 of 60088, by myne
Oh. It has different makings?
I built:
Reply 55168 of 60088, by PcBytes
Not exactly PC oriented, but I ordered a modded Dreamcast.
Gonna be fun figuring out how to deal with it.
Reply 55169 of 60088, by DudeFace
PcBytes wrote on 2024-11-18, 12:03:
Nice! i'd say its classed as pc hardware, its powered by windows CE, has a power VR gpu a mouse and keyboard and also runs linux, so definitley counts, i've just dug mine out after 20 years and would like to fit a dual bios, a serial adapter and a gdemu, for now ive had to stick with cd's, ive been trying out a bunch of tate shmups and the atomiswave conversions, check out the dreamcasttalk forums if you havent already theres someone there whos made a pico mod (USB4MAPLE) for usb xbox360 controllers, usb mouse and keyboard and which also lets you use a usb stick as a vmu.
Reply 55170 of 60088, by PcBytes
I was actually recommended the BlueRetro adapter, which supports virtual VMU
Reply 55171 of 60088, by Major Jackyl
I had quite the haul. Most notable are a pair of AGP cards (a GeForce2GTS and GeForce4MX440) and a pair of Sound Blaster live!
The attachment 20241117_211031.jpg is no longer available
The attachment 20241117_210300.jpg is no longer available
Other items include a Jazz drive and media (first time ever having one, will be testing/playing with it later), a NIB Antec 380W PSU, and a fat stack of DDR.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 55172 of 60088, by Kahenraz
Be careful when buying used Jaz cartridges. The plastic can get soft or brittle if stored in a poor environment, causing the platter to sheer off from the spindle when rotating at speed. Ask me how I know!
Reply 55173 of 60088, by Wes1262
more marketplace drama
I buy job lot of 3 cards (40€). I try them. None works. I send pictures with proof. Seller says, "if they don't work there's no need to send them back. Just don't leave me a negative feedback."
Then I contact him and I decide to keep one of the cards because the heatsink is in really good conditions and I might need it in future.
I tell him I will keep one of the cards and I propose to send him half of what I paid (20€) just for the heatsink.
I send him back the other two cards, but now he won't release the dispute unless I send him the 20€ I PROMISED first.
First he was "yeah just throw them in the bin". Now he wants me to pay 20 more on top of the 40 I've already paid.
Reply 55174 of 60088, by Thandor
Antec PlusView 1080AMG (and 1000AMG) is the name of the case. I bought one new back in the day and still use it for my main rig 😀. Newer cases are better in regard of cooling and noise insulation but still I think this case looks lovely so it’ll stay in service for as long as the ATX standard lives 😜.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 55175 of 60088, by zuldan
Thandor wrote on 2024-11-19, 07:06:
Antec PlusView 1080AMG is the name of the case. I bought one new back in the day and still use it for my main rig 😀. Newer cases are better in regard of cooling and noise insulation but still I think this case looks lovely so it’ll stay in service for as long as the ATX standard lives 😜.
Interesting, it looks identical to the Chieftec Dragon. I think the main maker of the case sold it to Cheiftec, Antec plus others. Can you remember how much the case cost? And what year you bought it?
Edit: It’s the same case https://forums.anandtech.com/threads/antec-pe … 080amg.1516372/
Thanks for letting me know the exact model!
Reply 55176 of 60088, by Thandor
zuldan wrote on 2024-11-19, 08:38:
Interesting, it looks identical to the Chieftec Dragon. I think the main maker of the case sold it to Cheiftec, Antecedent plus […]
Interesting, it looks identical to the Chieftec Dragon. I think the main maker of the case sold it to Cheiftec, Antecedent plus others. Can you remember how much the case cost? And what year you bought it?
Apparently they were available as 1000AMG and 1080AMG. Perhaps it depends on wether you bought a case with or without PSU.
I couldn't find my orders from back in the day but the pricewatch of a Dutch website (Tweakers.net) of the time mentions 131.90 EUR for the non-windowed version. I guess that's about the same price I paid for the case.
I do have pictures of the original box! My case was the PlusView 1000AMG. Weirdly enough I always thought I had the 1080AMG...
Reply 55177 of 60088, by zuldan
Thandor wrote on 2024-11-19, 09:20:
Wow thank you for the box pictures. Really interesting! I love the case, it’s beautiful.
Reply 55178 of 60088, by Nexxen
Bought 2 286 boards.
One does post (3x ic chipset) - https://theretroweb.com/motherboards/s/leadma … inc-lm-103fs-16
The other does not (HT12 chipset) - ??? no idea which one it is but can you spot "what's wrong with this picture"? (placebo quote)
Probably this one: https://theretroweb.com/motherboards/s/lucky-star-cm-286ghs
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 55179 of 60088, by appiah4
Shponglefan wrote on 2024-10-19, 17:02:
Continued to round out my sound card collection this past month with some new additions, including the Media Vision Pro Audio St […]
Continued to round out my sound card collection this past month with some new additions, including the Media Vision Pro Audio Studio 16XL, Ensoniq Soundscape Elite, Orchid GameWave 32, some sort of Boca Research modem/ sound card combo, and a Sound Blaster Live 5.1 Platinum boxed set.
Despite owning a lot of sound cards, this is the first Sound Blaster Live card I've ever acquired. Figured I might as well get the complete box as a starting point.
The attachment Media Vision Pro Audio Studio 16XL.jpg is no longer available
The attachment Ensoniq Soundscape Elite.jpg is no longer available
The attachment Orchid GameWave 32.jpg is no longer available
The attachment Boca Research Sound Card.jpg is no longer available
The attachment Sound Blaster Live Plat 5.1 Boxed.jpg is no longer available
Late reply, but all of these are fantastic finds. The PAS and Ensoniq cards are fairly standard, but I am really curious about the Boca Research sound card. Boca was a very big player in the Modem market back when FaxModems were the shit; I believe they eventually got bought out by someone or rebranded or something and disappeared into obscurity.. I never heard of their sound cards before, but it all makes sense considering Modems are basically audio equipments to some degree. I would love to hear your impressions of this sound card.. I would also love to find a specimen somewhere myself.
