Reply 560 of 582, by Apple IIGS
Update: I tested Nuke-55sc on a more modern computer (Core i7 Pro, versus the Core 2 Duo previously used) and much of the latency while playing a real-time MIDI keyboard has vanished! It's not as responsive as my hardware SC-55mkII, obviously, but the average person likely wouldn't notice. No surprise that all the crackling and garbled sound has disappeared too. It's still quite remarkable to hear an emulated Sound Canvas with about 99% accuracy coming out of an ordinary desktop PC with just a plain old DAC!
I also finally figured out how to use the JV-800 side playing one of my MIDI keyboard in real-time using a USB->MIDI cable adapter! (a nice treat, since I had a JV-880 stolen from me before I had a chance to try it). I'm wondering though, how accurate is the JV-880 side of Nuke-SC55. Is it still a work in progress or is it considered complete? I noticed one patch (RevCymBend) wasn't working properly, and a few others seem to have some minor clipping or distortion. I don't have a real JV-880 to compare with, unfortunately.
Reply 561 of 582, by EmperorGrieferus
Listening to Descent OST through Yamaha MU80, I realized that it shares a fair amount of samples with SC-55. I wonder why.
Reply 562 of 582, by zaphod77
because the mu-80 has a tg300B mapping that it uses when it does a GS reset.
Reply 563 of 582, by syche
Hi!
I just recently started using Nuked SC-55 (before I've been using SC-VA for years) and I have some (perhaps dumb) questions.
1. Which is a better (or less problematic) emulated device for DOS gaming: SC-55 MK1 v 1.21 or SC-55 MK2? I guess, what I mean is which one is considered to render music in most DOS games more correctly and without quirks, or if the difference is negligible enough and can be ignored?
2. There is a warning in the readme file that due to a bug in the SC-55mk2's firmware, some parameters don't reset properly on startup and need additional actions to properly initialize. I presume then, that means SC-55 MK1's firmware doesn't have this bug and no additional actions are required? Am I right?
3. When Nuked SC-55 starts up it produces 6 "Unknown Write" errors on MK2 firmware and 14 "Unknown Write" errors on MK1 v 1.21 firmware. Is it expected behavior and does it mean anything bad in practice? Does it actually mean that it's preferable to use MK2 firmware with Nuked SC-55 (since there are much less errors during MK2's initialization)?
Sorry if these questions have already been asked and answered. Thanks!
Reply 564 of 582, by syche
Sorry, another question. Is there any definitive way to check for CTF issue, preferably a midi file where the difference can actually be heard on SC-55 MK1 vs MK2 playback? Thing is, I patched (I think) MK2 firmware with a patcher from earlier in this thread, which promises to solve this CTF problem on MK2. I'm not sure I've done it correctly though, since it's not actually clear from the description, which rom file I should patch (since there are 5 of them). So I'm not sure I was successful and I also don't know where to look and what exactly to listen to to be sure. 🤣
Reply 565 of 582, by gerwin
syche wrote on 2026-05-29, 18:32:
See here:
sc55mk2-ctf-patcher: A tool to modify SC-55mkII firmware to support CTF
Reply 566 of 582, by syche
gerwin wrote on 2026-05-29, 19:36:
See here:
Yep, I've read it before patching and tbh found it kinda inconclusive. I mean, it's good that now instead of no instrument it shows Polysynth or something like that, but I honestly for the life of me can't hear any difference at all. 🤣 Aren't there some problematic exemplary midi files where the difference is fairly obvious to one's ears. For example, on such and such midi file on 0:08 seconds you'll clearly hear an instrument with CTF that you won't hear without CTF, something like that, to be absolute sure the issue is gone.
Reply 567 of 582, by Falcosoft
syche wrote on 2026-05-29, 20:22:
See here:
Here you can download a canyon.mid version that is problematic on mkII. Channel 1 shows invalid intrument and so polysynth cannot be heard.
Re: SC-55 mkII "No Instrument" Message With canyon.mid and passport.mid
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 568 of 582, by syche
Falcosoft wrote on 2026-05-29, 20:38:
Ah! Ok, now I definitely hear it, thanks. Funny thing, I already compared this file before and didn't notice the difference, I don't know how I missed it the first time. 🤣 So basically a patched MK2 firmware now sounds correctly, exactly the same as MK1, which is pretty nice, I think (best of both worlds and such).
Reply 569 of 582, by Doom87
Falcosoft wrote on 2024-05-12, 08:24:
Just a side note, you can do both with FSMP both for Midi files and for games when FSMP is used as a Midi router. 1. Reverb: You […]
Xenon 2 wrote on 2024-05-12, 07:56:
There's something else that I wanted to talk about, and share, for a very long time, being related to Reverb, so I think that th […]
There's something else that I wanted to talk about, and share, for a very long time, being related to Reverb, so I think that the release of Nuked-SC55 is a good opportunity to finally do it.
Back in 2002, when I had discovered the https://www.doomworld.com/classicdoom/info/music.php web page, containing the MP2 files, of the Doom and Doom 2 recordings made with a Roland Sound Canvas SCC-1, I just couldn't believe that it could sound that much better, compared to my Sound Blaster AWE32.
But, despite of the much better instruments' quality, I suspected that there was also some tweaking/tuning done to these recordings, which seemed like a lot of Reverb applied to them, but these recordings had made me take the decision of buying a Roland Sound Canvas SC-55mkII.
However, once I had been able to listen to the Doom musics, for the first time with my SC-55mkII, despite that I was pleased by the much better instruments' quality, compared to my Sound Blaster AWE32, I was a bit disapointed by the lack of Reverb, by default, and it felt rather "soft", compared to the MP2 recordings.
So, I've first increased the Reverb level, for all of the MIDI channels, from the default value of 40, up to the maximum value of 127 : this sounded much better, but still, it wasn't as "powerful" as the MP2 recordings.
Then, I've also increased the overall/master Reverb level, from the default value of 64, up to the maximum value of 127 too, and finally, it sounded exactly like the MP2 recordings that I liked so much.
After having listened to many of my favorite games' MIDI musics with these maximum Reverb settings, I've become addicted to it, and I couldn't enjoy listening to them with the default Reverb level values anymore.
And so, I had taken the decision to use these maximum Reverb settings permanently, for absolutely everything I would listen with my SC-55mkII, along with also using permanently, the custom Voice Reserve configuration, of 2 voices for the channels 1-12, and 1 voice for the channels 13-16, like I've explained in my previous post in this forum thread ( Re: Nuked-SC55, low-level Roland SC-55mkII emulator announcement ).
However, in order to prevent all of these custom settings from being reset back to their default values, if playing a game or MIDI music/file sending either a "GS Reset" or "GM System On" SysEx message, a solution is to set both the "Rx GS Reset" and "Rx GM On" settings to "off", using the front panel buttons.
I've created a MIDI file, attached to this post, allowing to quickly and easily set your real Roland Sound Canvas synth, or Nuked-SC55, to the maximum Reverb level, and also to customize the Voice Reserve configuration.
For the Reverb, it will set each of the 16 MIDI channels' Reverb level to the maximum value of 127, which is useful for games or MIDI musics/files which don't set any channel Reverb value (like Doom, Doom 2, Heretic, Hexen, Raptor and Rise of the Triad), and also set the overall/master Reverb level to the maximum value of 127, using the "F0 41 10 42 12 40 01 33 7F 0D F7" SysEx message, which will benefit and boost the Reverb for every games or MIDI musics/files.
As for the custom Voice Reserve configuration, since I also wanted to provide a better configuration for the original SC-55 users, in addition to the SC-55mkII users, then instead of creating 2 different MIDI files, I had the idea of doing it with one single MIDI file, by first sending a SysEx message to set the Voice Reserve number, to 2 voices for the channels 1-12, and to 0 voice for the channels 13-16, which will work on both the original SC-55 and the SC-55mkII, and then sending another SysEx message to set the Voice Reserve number, to 2 voices for the channels 1-12, and to 1 voice for the channels 13-16, which will obviously be ignored/discarded by the original SC-55, but will work on the SC-55mkII.
At least, this additional custom Voice Reserve configuration for the original SC-55, will prevent notes being cut off too early, for the games using the channels 11 and/or 12, in addition to the channels 1-10, like Heretic, for example.
Also, since there are games and MIDI musics/files sending either a "GS Reset" or "GM System On" SysEx message, which would reset all of the settings changed by my "Max Reverb" MIDI file, like the original DOS version of Doom, Doom 2, Heretic, Hexen and Raptor, sending one "GM System On" SysEx message when launching/starting them, I also wanted to provide a convenient solution/way to set both the "Rx GS Reset" and "Rx GM On" settings to "off", but it seems that there's no SysEx message, allowing to do that, unless there are such SysEx messages being hidden/undocumented ?
This would have been particularly useful for the Roland Sound Canvas synth models without a LCD display and front panel buttons, like the SC-55ST, CM-300 or CM-500, which don't have a way to set the "Rx GS Reset" or "Rx GM On" settings to "off" then.
However, in this case, instead of using the original DOS version of Doom, Doom 2, Heretic or Hexen, a solution could be to rather use a source port instead, which doesn't send any "GS Reset" or "GM System On" SysEx message.
Finally, when the "Rx GS Reset" or "Rx GM On" settings have been turned "off" by using the front panel buttons on a SC-55 or SC-55mkII, then performing a manual "Init GS" or "Init GM" by using the front panel buttons, won't set these 2 settings back to "on" : only performing a manual "Init All" by using the front panel buttons will do it.
Actually, this is a good thing, since that, if you need to reset your synth, then you won't have to set the "Rx GS Reset" or "Rx GM On" settings back to "off", everytime you perform a manual "Init GS" or "Init GM" by using the front panel buttons.
Also, since Doom, Doom 2, Heretic, Hexen, Raptor and Rise of the Triad, don't set any Reverb or Chorus value for the MIDI channels, remember to not switch back to any of these games, without resetting your synth (and replaying my "Max Reverb" MIDI file), after having played another game or MIDI music/file which sets Reverb and/or Chorus values for the MIDI channels, like Duke Nukem 3D, for example.
1. Reverb:
You can change only the SysEx reverb level and leave the reverb type on default but you can also change the reverb type/preset.
The attachment reverb.png is no longer available
2. Disable receiving SysEx messages:
You can disable receiving SysEx messages both from played Midi files and from Midi input.
Moreover you can also set the Midi reset to 'No SysEx' that disables sending SysEx resets but at least sets default instruments and contoller values.
BTW, you can also set default Custom SysEx type as reset type where the modified voice reserve SysEx can be set.
The attachment sysex.png is no longer available
I'm looking for EXACTLY the same thing!
I want to play Doom 1 with the soundtrack Michael Michael Massay had tweaked with the max reverb, etc.
I tried messing around with reverb console commands but I cannot replicate that exact sound.
Is there a wad/mod of this for Doom 1?
Someone made Michael Massay's tweaked OST into a WAD for Doom 2:
https://www.moddb.com/mods/doom-ii-enhanced-ost
I hope there's a way!
Reply 570 of 582, by Karmeck
Something somthing, Nuked-SC55 is now GPL 2.0
Reply 571 of 582, by zaphod77
Or later. Meaning gpl3 projects can use it as well now. Curious why the change happened, but overall it's probably a good thing.
Reply 572 of 582, by Karmeck
zaphod77 wrote on 2026-09-05, 02:03:
I think it was in this thread that nukeykt said license would change when hype died down.
Reply 573 of 582, by zaphod77
I think the idea was to relicense it when other stuff got advanced enough that it was silly locking this project out still. this seems to have not happened, with 88emu on the way, and emusc much improved and tabula sonora being out.
Reply 575 of 582, by zaphod77
Output proven identical now? Where is it, then? 😀
Reply 576 of 582, by gerwin
Nukeykt added the following header to his Nuked SC-55 github repo today;
Notice: development and maintaining of this emulator has stopped Thanks to everyone who was using and enjoying it! You can use o […]
Thanks to everyone who was using and enjoying it! You can use one of awesome forks like the one from jcmoyer.
This was my dream project for about a decade (since I got SC-55 unit in 2014) and culmination of my reverse-engineering works, and I'm glad I was able to pull it through.
Unfortunately this project also caused me pretty severe burnout, so I decided to take a break from project back in 2024. This coupled with pressure to relicense the project and usage info/code from my code against my will/without permission or outright license violations, made me very hard to pick it back.
So in 2026 decision was made to relicense the project to GPL2, archive the repository and completely cease any further work. Sorry if I disappointed anyone with this decision, but doing so is going be better to my mental health.
Sorry to hear that not all was well on a personal level. I hope things improve in that regard. I for one appreciate his Nuked SC-55 release for what it is, and understand that he has put a lot of effort in, and that it is neither necessary nor proper to expect him to put more effort into this project.
Reply 577 of 582, by Shreddoc
A big thank you to nukeykt, the scene admires and appreciates your success here.
Burnout is a big deal in this field, too. In my opinion, the combination of modern high-paced society, endless corporate notifications, the weight of social expectation we put upon ourselves ("I'm me! Thus, I must do this project at 200% human ability! Anything less, and I am shaming myself, and letting people down!"), etc : We have to push ourselves to 99% mental capacity to achieve incredibly complex goals which would have seemed impossible just years ago.
And you know how much it takes to crash a machine that's always running at 99%?? I do, because I do it to myself all the time!
Reply 578 of 582, by badmojo
Yes much respect to Nukeykt for his amazing efforts - creating something that brings joy to so many people should bring intense pride. It's a shame that putting yourself out there like this also brings risk, but that's humanity for ya. Some people build, some people destroy.
