Reply 56280 of 58873, by PcBytes
Scores today:
-Kobian KOB 815EP FSX + P3 866
-MSI MS-6378 v3 w/ Duron 1000 - Trident Blade 3D, interesting.
-Fujitsu MAX3147NC 146GB Ultra320 SCSI HDD - Dell OEM it seems 😀
Reply 56281 of 58873, by kinetix
found the motherboard of a Sanyo MBC-550/555
it is not in theretroweb. Ill send it to them after I dump the bios
someone badly removed the keyboard connector. also misisng is the composite video output and one DRM chip. but Ill try to rebuild it. need to understand the floppy drive interface,
I´ll love if someone send me detailed pics form both sides of the board around the missing connector
plus, found several more EPROMS, including one more of on type Ive been looking to fully populate a EPROM/FLASH/SRAM board
UPDATE: well, I found part of the motherboard schematics in Archive.org
Reply 56282 of 58873, by brassicGamer
This EISA/VLB motherboard which I got for an absolute steal on the 'big auction site'. Came without cache, keyboard controller or BIOS. Did the following work:
- cleaned board fully,
- battery mod for the special RAMified Dallas after desoldering and socketing,
- installed spare keyboard controller,
- removed 28-pin socket and installed 32-pin socket as the motherboard had footprint and connections for 32-pin flash chips,
- hot-flashed BIOS using a Pentium motherboard after downloading .bin from theretroweb,
- ordered 16K x 4 chip because the board uses an old style cache configuration with tag and dirty bit,
- installed 256KB cache,
- ordered spare crystals as there is no clock IC.
Board is now working fully.
The attachment IMG_20250214_225420_edit_77505819948069.jpg is no longer available
Reply 56283 of 58873, by Trashbytes
PcBytes wrote on 2025-03-09, 12:41:
Scores today: […]
Scores today:
If by interesting you mean absolutely awful then yes its interesting.
Reply 56284 of 58873, by kagura1050
I received this two days ago. It's a Trident 8900D-R 1MB, my first ISA VGA. It's unused (with nice box and Windows 3.1 driver floppy) and I bought it on Yahoo! Auctions for 4500 yen (about $30).
I'd been keeping an eye on auction sites for about two years, hoping to find an ISA VGA for under 2000 yen ($13), but it seemed impossible, so I gave up.
Well, I'm glad I got a good one in the end.
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
Timezone : UTC+9
Reply 56285 of 58873, by vetz
kagura1050 wrote on 2025-03-10, 00:27:
So it was you who got it! I was keeping an eye on that auction. Good to see it went to a good home.
Reply 56286 of 58873, by PcBytes
Trashbytes wrote on 2025-03-09, 23:36:
Scores today: […]
Scores today:
Awful, maybe, I have yet to test it further. But given it shows up during the late Socket 7 era, is why I find it rather interesting. (MVP4, to be specific.)
Reply 56287 of 58873, by gerry
PcBytes wrote on 2025-03-10, 10:17:
Scores today: […]
Scores today:
Duron 1000 though, that's going to be pretty good 😀
Reply 56288 of 58873, by momaka
Welp, last weekend at the flea market wasn't that great - there were lots of stuff to choose from and quite a few "semi" retro PC towers from the P4 / Athlon XP era. For some reason, though, I ended up getting the more crappy items than I would have liked... but it is what it is.
This is what approx. $18 worth of cash got me:
$4: Two newer Creative SB PCI cards (one's a Live 24-bit, and the other X-Fi / Xtreme Fidelity... forgot what SB models exactly, they are outside drying from the wash.)
$2.50: 2x Seagate Barracuda 7200.7 IDE HDDs, 40 GB - appear to power up and head seek OK. To be tested later today, most likely.
$1: a 10 GB WD IDE HDD with rather quiet bearings (still) and a 160 GB Hitachi Deskstar SATA HDD that is probably hosed. The WD head-seeks OK, the Hitachi is yet to be tested, as PCB has bad water damage and it sounds like the head is crashed / not on the parking ramp inside.
$2.50: Sapphire Radeon 9600 Pro Advantage! Ed. with 3.6 ns RAM. Not tested, but looks OK, minus missing the metal bracket. Cooler was caked with dry nicotine dust but not much stuck to the card. It's outside drying right now.
$1: MSI GeForce 2 MX 400 AGP 128-bit SDR with 6 ns RAM... because, why not? Looked pristine.
$3: Gigabyte GA-8iPE1000 Pro2 socket 478 board with 2.6 GHz P4 (not sure if NW or Prescott yet.) Seemed like a good deal, until I got home and saw two nasty gashes on the bottom of the board that somehow I didn't notice at the time of the sale. The traces appear to be going to the PS/2 ports, USB ports, and etc. (I think!) They are very fine, so this will be "fun" to repair.
$3: TurboX H81M PCID LGA1150 motherboard (H81 chipset). Had a single bad pin in the CPU socket and a burned trace near the ATX connector. I have seen and repaired this kind of damage before on an ASUS board, so decided to give it a try. Normally, I'm pretty careful about protecting the LGA socket... but this time, I don't know what happened, so I completely forgot. By the time I got home, I had 15 mashed pins to repair. Those are taken care of now, so I just need to deal with the burned trace next... and oh, a bumped cap at the bottom, which was also a present issue at the time of sale. Wish me luck with this one. Don't know why I got it when literally at the end of the day, there was another guy selling an H87 ASUS board with only 3 bent pins in the CPU socket.
I didn't stay until the end, so didn't pickup any CDs or DVDs for my "data hoards".
On the plus side, at least this time I didn't overload myself like a mule.
Reply 56289 of 58873, by eesz34
I recently got a 8900D too. Not new, but nearly new in the original box without the disks and packaging. It's going into a 386DX40.
Reply 56290 of 58873, by PcBytes
momaka wrote on 2025-03-10, 14:19:
Welp, last weekend at the flea market wasn't that great - there were lots of stuff to choose from and quite a few "semi" retro P […]
That's slim in terms of weight. The pack of boards my recycler just sent my way weighs no less than 12kg alone. Zoinks.
On the upside... lots of rare stuff, including a Voodoo 3 PCI.
Reply 56291 of 58873, by Trashbytes
Scores today: […]
Scores today:
Oh no, no no no others have walked that path before you including myself and its truly an awful video card which is odd since Trident were well known for some decent mid range cards.
Reply 56292 of 58873, by PcBytes
I've dealt with SiS 6326. I doubt the Trident being any worse than that.
Reply 56294 of 58873, by Tiido
I got to play with one of these not so long ago, and unfortunately, I can say little positive about the experience 😒
Reply 56296 of 58873, by devius
PcBytes wrote on 2025-03-10, 21:15:
I don't know about the Blade3D specifically, but the 3DImage 9750 has such horrible image quality in 3D that even a S3 Virge is preferable. Unless there was some kind of tech miracle between that and the Blade I doubt it's much better.
Reply 56297 of 58873, by Tiido
Shponglefan wrote on 2025-03-10, 22:39:
Why, what happened?
* The OSD system is cluncky and lacks simple things like image positioning. Whatever is used seems to be from a low end TV and not something really fitting for a monitor.
* It couldn't display stuff like BIOS boot screens over VGA connection (at least on the computer we were playing with, a Samsung monitor had no issue whatsoever).
* The CVBS inputs were doing stuff like deinterlacing and had absolutely awful image quality. It was also frame-rate converting and did a horrendous job at it. If you absolutely need to see something you can use them but any gaming is better forgotten.
* HDMI input was able to accept the oddball output from my OSSC that was tuned to perfect capture of Mega Drive's analog RGB output, but it was doing very poor frame-rate conversion when 50Hz signal was input.
* Bezel covers few of the edgemost pixels of the panel, i.e Speedsys frame is invisible because of it.
* The panel has pretty slow response time, absolutely unfitting for scrolling games. Sonic on MD turned into a total blurry mess as soon as things started to move.
* Power on/off button is wired the wrong way around
The monitor lacked the board with SCART input so I cannot comment on if its inputs were better behaving. I would surely hope so because the rest has was a disappointment to put it mildly.
I did like the swivel and tilting capability and sound wasn't half bad among other monitors with little built in speakers.
Reply 56298 of 58873, by Shponglefan
Tiido wrote on 2025-03-10, 23:09:
* The OSD system is cluncky and lacks simple things like image positioning. Whatever is used seems to be from a low end TV and n […]
Why, what happened?
Thanks for commenting, I'll have to test what I can and see what results I get.
I've confirmed that this monitor unfortunately does do frameskipping under DOS resolutions. This is disappointing since the panel was advertised as supporting up to 75Hz. But I'm now wondering if it's one of those supports the input mode, but then frameskips down to 60Hz for the panel.
(Note this was taken at 1/15 shutter speed so the image is a bit blown out).
The attachment Checkmate Monitor frame skipping at 70Hz.jpg is no longer available
I also tested the Speedsys thing you mentioned and can confirm, the bezel is pretty much on top of the first row of pixels on mine. You can slightly see the border, but it's not a great look.
The attachment Checkmate Monitor Speedsys.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 56299 of 58873, by 65C02
Why, what happened?
And isn't the 1280x1024 resolution difficult to cleanly scale to (unlike 1600x1200, 1920x1200, or 4K)?
I like the idea of a retro themed LCD, but the 5:4 panel doesn't seem like the best choice for it.
