Reply 56400 of 59455, by Bj0rn83
I bought this Dell XPS P166s from my local thrift store for 65 euro, kinda expensive if you ask me but it came with a AT101W keyboard and a creative ct1920 goldfinch expansion card so I'm happy.
Asus p3v133 | P533mhz | AWE64 | MT-32 | SC-55 | MU80 | Roland MPU401at |
Reply 56401 of 59455, by PcBytes
Today's scores:
- neat In-Win clone-like build w/ Luckystar 6VA694, TNT2 M64 and RTL8139A NIC, 650MHz P3 (SL3XV)
-ASUS A7N8X Deluxe R2.0/GOLD - in dire need of recap
-ATI Rage 128 Pro AIW
-2x DEER PSUs more ancient than stinky bones (@momaka - VIVA caps 🤣)
-Acer Aspire 6930 lappy (C2D)
-various SIMMs including some strange stuff w/ a BP44C chip (????)
- S3 Trio 64V+ PCI
- 40GB Seagate ST340823A (literally the 40GB version of the OGXbox HDD!)
- Skyhawk SH400A8H PSU - no idea who's the OEM but good god this thing is PACKED inside
Reply 56402 of 59455, by Dimitris1980
Carmageddon Macintosh version
Logitech Z533 speakers
Logitech Wingman Extreme Digital Joystick
Lost in Time PC CD version
Atari SM124 monitor
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower, Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 56404 of 59455, by dominusprog
Dimitris1980 wrote on 2025-03-24, 08:13:
Carmageddon Macintosh version Logitech Z533 speakers Logitech Wingman Extreme Digital Joystick Lost in Time PC CD version Atari […]
Atari SM124 monitor
Nice joystick 👍🏻.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 56405 of 59455, by Dimitris1980
dominusprog wrote on 2025-03-24, 15:34:
Atari SM124 monitor
Nice joystick 👍🏻.
Thank you 👍😊. I bought it only for 12 euros and it was new and sealed 😀 . I opened it, installed the drivers in Windows 95 and sometime I will test it with games like Wing Commander IV and X-Wing vs Tie Fighter. 😀
- Cyrix 120
- Atari 1040 STF
Reply 56406 of 59455, by PcBytes
PcBytes wrote on 2025-03-23, 17:38:
Today's scores: […]
Today's scores:
- S3 Trio 64V+ PCI
Figured I'd bring up some photos. The horizontally placed case is the one I got the A7N8X out from, and the In-Win like case with the CYBER badge is the 650MHz P3 system.
Reply 56407 of 59455, by Xicor
Hi all,
In the past weeks I have managed to find and pickup some odd and cool stuff.
First a Acer J1 motherboard. It is a pre-VLB 486 EISA motherboard. It has some a awkward combination of features, like EISA + Acer Local Bus + cahe module and flashable bios, yet no vrm circuitry and no VLB for a MB from 1993.
The attachment Acer_j1_01.jpg is no longer available
The attachment Acer_j1_02.jpg is no longer available
The attachment Acer_J1_CAS_01.jpg is no longer available
PS: Pre-VESA Proprietary 32-bit Local Buses? This post has interesting information about this quirky MB .
From the same seller and bundled with the MB, a nice to have ISA SCSI combo card from Adaptec, the AHA1542BS100. Probably not very quick, but very useful given the floppy controller.
The attachment Adaptec_AHA1542BS100.jpg is no longer available
In another ad form the same seller (tip: allways check out the full listings of the same user) found an obscure multi IO card from Acer, and I had the suspicion, that somehow it was related with the previously acquired motherboard, and it would bee useful to diagnose the issues that I did have with this particular MB. From FCC id, one can conclude that it was an Acer made card that ofers VGA, HDD, FDD, parallel port and 2 RS232, designation or name as “E5” (there is also E-5 CARD on the silk screen). At http://www.uktsupport.co.uk/acer/mb/j1.htm it references the existence of a E4+ card for the Acer J1 motherboard, so it is likely a shipped option for the Acer J1.
The attachment Acer_E5_IO_card_01.jpg is no longer available
To be continued ....
Reply 56408 of 59455, by Xicor
Next a computer case “from” Fujitsu from the same seller. I didn’t had luck in the initial testing of the Acer J1. It did initiate some execution of code from the flash, but it halted on the keyboard controller test, that send me to a progressive rabbit hole in the attempt of reviving the motherboard. So, I reached out to the seller and learned that all this hardware belonged to a server/workstation from Fujitsu, the S4066. This was somewhat strange because I was expecting a Acer branded machine, but after seeing the first batch of photos that the seller kindly sent to me, it was obvious that it was in fact a re-branded Acer. In one of those images there was a clue to the problem, the key lock has a unusual combination of settings (on servers is somewhat the norm), so I check the area of the front panel connector (J5) and keybord controller, and found JC4 cut (factory made, like in some commodore MB). Shorting it made the MB boot properly (an halt function of sorts wired to the key switch). All of this made me think that it wound be a shame to not have the proper case of the MB, so I made a offer, and voila, the case with PSU, a 5.25 and a 3.25 floppy drive.
The attachment Fujitsu_S4066.jpg is no longer available
While all of this was happening, a motherboard for an IBM 5170 popped up for cheep and I could resist. It has some corrosion problems, but I think it can be fixed.
The attachment IBM_5170.jpg is no longer available
A week later found a Maxi Studio ISIS complete in box, with all the paperwork and stickers, plus a 32MB simm module for expanding the sound card.
The attachment ISIS_Boxed_01.jpg is no longer available
The attachment ISIS_Boxed_02.jpg is no longer available
The attachment ISIS_Boxed_03.jpg is no longer available
Reply 56409 of 59455, by Xicor
At last but not the least, from Italy, a Zida Tomato sound card based on OPTi 82C930A with OPL3 clone, and bundled with it came a Media Magic Wavetable Daughterboard SH-WS32-D (pending confirmation). This waveblaster board is a bit obscure, cant find info on it except a Korean blog entry about GM82C650 and one old ad on ebay...
The attachment tomato_Opti.jpg is no longer available
Ps: image of top side form the cas module .... for those whom love this type of thing
The attachment Acer_J1_CAS_02.jpg is no longer available
Reply 56411 of 59455, by JustJulião
A pair of Canopus Total3D (Verite V1000L-P) cards with their "3D audio" add ons and the bundled software.
Let me know if any of these have not been uploaded yet and are of any interest.
The attachment IMG20250324134346.jpg is no longer available
It also came with 3D glasses. I wonder how awful it is!
The attachment IMG20250324211625.jpg is no longer available
And finally, a Cibox tower and its keyboard (not displayed here). It was not the one running when the photo was taken, hence the turned off lights.
The attachment IMG20250324212025.jpg is no longer available
Bonus piece of Art that was stuck in the Floppy drive. I wonder how old it is!
The attachment IMG20250324180255 (1).jpg is no longer available
Reply 56412 of 59455, by Major Jackyl
I got some awesome stuff over the weekend. The most interesting is this "Project PC" that is *maybe* working. It had a Dallas Mod and A CF adapter (I had neither), so for $25, it seemed like a lot of computer. Feelin' good about this one. It was from Computer Reset Warehouse and has the most yellow'd PCI slots (might replace). Usually internal parts survive. This case has no top, though, and looks like it was sitting in the sun.
The attachment 20250324_164352.jpg is no longer available
The attachment 20250324_164215.jpg is no longer available
The attachment 20250324_164315.jpg is no longer available
Next is a pair of Sony VAIO. One PCV-200 and one PCV-220. The 220 has AGP video card and ESS Miestro1, the 00 has PCI version of same video card and on-board audio. These things are AWESOME. Two video ins and RF in. And it has S-video/RCA out(s). They BOTH have ZIP, DVD and Floppy. One has a CD burner added. I'll be breaking one down later, hope they both work!!
The attachment 20250324_164657.jpg is no longer available
Finally, the "dollar stackers": One dollar, untested, motherboards. They seem like some fun models.
The attachment 20250324_164506.jpg is no longer available
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 56413 of 59455, by BitWrangler
Xicor wrote on 2025-03-24, 16:53:
Wile all of this was happening, a motherboard for an IBM 5170 popped up for cheep and I could resist. It has some corrosion problems, but I think it can be fixed.
Edit:Snip, quoted right pic, wrong pic appeared, strange.
Nope, not much you can do there, it will still be a 5170... 🤣 just kidding.
Odd corrosion, looks like it got rain or flood through the keyboard hole because the battery should have been a sealed lithium pack.
The less funny part of my first line is what a pain in the butt they are to take up to 1MB and 8Mhz, so you can actually begin to believe you've got a 286. You may have trouble finding a case that the board fits in, "AT" might prove to be a lie, when they fit close to a board like the Acer J1 and don't have the extra half an inch in length or another inch beside the keyboard connector to fit the one, the only, real AT.
Reply 56414 of 59455, by TheMobRules
Major Jackyl wrote on 2025-03-24, 22:18:
I think it has to be an issue with the plastic used for the PCI slots of ASUS motherboards during that era. I have a board from around the same time as that one (mine is P55TP4XE) and the PCI slots are as orange as yours. I've also seen it on multiple pictures of ASUS boards from 1995-96.
Reply 56415 of 59455, by PcBytes
Some FIC PA-2013 might also have that issue. I have like 4 (out of which only one works properly) and one of them has the PCI slots are just as yellowed. At first I thought it was nicotine causing it but it wasn't the case.
Reply 56416 of 59455, by Xicor
BitWrangler wrote on 2025-03-24, 23:26:
LoL...
True, hard to upgrade and not even a full tower case may be a safe bet, but I will cross that bridge when I arrive to it. 😉
Reply 56417 of 59455, by Ozzuneoj
Well, I went on a bit of a road trip today with high hopes of finding something interesting. I passed up some neat old computers because they were priced at what the machines might be worth online, which is totally fine. They had a Commodore PC10 with a monitor, keyboard and other stuff. An Atari 520ST with a monitor, KB + mouse. A boxed Tandy CM-5 monitor and a PC-XT clone of some sort with a monochrome monitor.
Thankfully, none of these are things on my bucket list so I wasn't overly tempted. I bought a bunch of misc stuff, but (thankfully?) the guy who had owned all of this stuff must not have kept a ton of PC components, so I didn't have to empty my bank account.
Anyway, the box these were in ended up being the highlight of the visit. I thought it was just an SB16, some paperwork and a CD-ROM drive, but when I got home I realized it was way cooler than that.
Hardware sleuths: What makes this lot so cool? 😀
(And no, it isn't just that it's an SCSI caddy drive to go with the SB16 SCSI)
The attachment 20250325_022004.jpg is no longer available
The attachment 20250325_022025.jpg is no longer available
The attachment 20250325_022249.jpg is no longer available
The attachment 20250325_022432.jpg is no longer available
Reply 56418 of 59455, by chrismeyer6
Ozzuneoj wrote on 2025-03-25, 07:10:
Well, I went on a bit of a road trip today with high hopes of finding something interesting. I passed up some neat old computers […]
Is it that the SB16 is the Scsi version with the ASP upgrade?
Having all the documentation and software for the card as well as all of those CD caddies is just awesome.
Reply 56419 of 59455, by Pino
A TNT2 Ultra with DVI output, which is rare.
And a decent socket 939 board with AGP slot
