Reply 57240 of 59576, by Archer57
tehsiggi wrote on 2025-07-27, 07:53:
Well.. I wonder why that card isn't working properly?
(apart from the missing caps here and there on the PCB)
The attachment venice_has_fallen.jpg is no longer available
Yikes. This one is even more dead than the one i got. I still did not get to fixing mine, this tiny caps scare me. I have the tools and everything, but still it is a significant challenge to solder them.
I wonder if this bridges are all the same and if stealing one from some newer dead card would work...
Did they only add that thermal pad for protection on newer cards like x19xx and above? So far i've seen a few cards like this from older series with no pad and i suspect it was not removed from all of them by previous user - probably was not there at all.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 57241 of 59576, by RaverX
I always wondered why there would be there a thermal pad, but no heatsink on top... It seemed counterproductive. But it makes sense now, it was to protect the chip. Very bad idea. They should have put a heatspreader, like on any modern CPU.
Reply 57242 of 59576, by myne
Well.. I wonder why that card isn't working properly? (apart from the missing caps here and there on the PCB) […]
tehsiggi wrote on 2025-07-20, 09:11:
A dead Radeon x1600Pro AGP from ebay. For science!
MMM! Chippies!
Crunch crunch!
I built:
Reply 57243 of 59576, by Socket3
marxveix wrote on 2025-07-24, 13:06:
Sapphire AMD HD7970 Dual-X 3GB […]
Fastest Radeon with XP support. I was lucky enough to find a working ghz edition.
Reply 57244 of 59576, by marxveix
Socket3 wrote on 2025-07-28, 14:02:
Fastest radeon HD series and maybe fastest radeon overall, but R9 2xx and 3xx also can be used i think. It has 2x8pin, not 1x8pin + 1x6pin. I am gona use it with AM3+ motherboard, that also has XP support. I hope PCI-E 2.0 will not hold it back with Phenom II X2/X4 or some latest FX CPU-s, it will be dualboot with XP and Windows 10 i think.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 57245 of 59576, by Archer57
RaverX wrote on 2025-07-28, 10:49:
Or they could have done what nvidia did and put it on the other side of the PCB, either cooled(and protected) by the main heatsink or by separate one.
But apparently it works well enough without cooling...
It is interesting that they added the pad later though, probably means there were plenty of cases of damage to the bridge, which is not surprising given they left bare die and those tiny caps exposed like that...
Reply 57246 of 59576, by CrFr
Bought a new round floppy drive cable.
The attachment floppy_cable.jpg is no longer available
Reply 57247 of 59576, by old school gamer man
CrFr wrote on 2025-07-28, 16:27:
nice. those make things so much more simple even if you can sometimes get a cleaner setup with flat cables. like who wants to fiddle with a IDE/FDD cables to get it right wen you can just toss in a round cable.
Reply 57248 of 59576, by fosterwj03
Nothing special, just bought a Matrox G450 PCI from eBay. A Vogons thread in the video section mentioned that the Windows 3.x drivers recognize the G450 as a G400. I'll test this myself, but I'm hoping that the NT 3.51 drivers would likewise ID the card as a G400. That would give me a bit of a boost in OpenGL (such that it is) over my G200.
Reply 57249 of 59576, by tehsiggi
Archer57 wrote on 2025-07-28, 15:08:
Or they could have done what nvidia did and put it on the other side of the PCB, either cooled(and protected) by the main heatsi […]
Has nothing to do if it is an earlier or later card. My x700s all had the pad.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 57250 of 59576, by dormcat
vutt wrote on 2025-07-25, 16:07:
Managed to score locally this beauty (TC430HX). Looks like solid DOS machine with S3 graphics and Yamaha OPL+MIDI.
Dang, those were probably the best combination for a late DOS / early Win9x build, not to mention in such a great condition. 🤤 I wondered why Intel or other MB manufacturers didn't make more models with integrated graphic and sound chips before the Pentium 4 era.
Reply 57251 of 59576, by BitWrangler
dormcat wrote on 2025-07-29, 00:22:
Kind of a time thing, they were changing platforms more often than some folks change underwear during that period. For 6 months the HX with S3 was high/midrange, and then quickly was low end, and competition arrived with cheaper integrated into SOC graphics, that were a bit better than S3 original architecture. Then onboard graphics tended to seem low end, despite the existence of onboard Voodoo3... though I think that just had 6 months in the sun too.
Reply 57252 of 59576, by Law212
Grabbed this tonight for 2oo bucks.
I had an agp version before but sold it. Couldnt resist having one in box and for near what I sold my non boxed one for.
Reply 57253 of 59576, by Archer57
Some more rialto gore:
The attachment hd4650.jpg is no longer available
The attachment x1650pro.jpg is no longer available
Got this ones for free with another card i was buying, at least now i have a donor for this specific tiny caps and x1650pro is looking relatively promising. Just need to sit down and do some soldering...
Neither had protective pad too, i wonder if it was newer there or if it was removed... honestly - such a bad design placing unprotected chip with exposed die and tiny caps on the backside of the card...
Reply 57254 of 59576, by PcBytes
That's how 90% of my dud X1950s look 🤣
Reply 57256 of 59576, by PcBytes
tehsiggi wrote on 2025-07-29, 12:10:
If you're lucky enough, the pads on the rialto are still in place.
On my x1600, they aren't 😁
They mostly are but soldering them is way off my scope. I've soldered stuff just as small but those are specifically hard to do.
I do have two Rialto-equipped cards waiting to arrive today so yeah, gonna see whether I can get 'em running. One is a Sapphire, the other is a Powercolor, both X1950 Pro.
Reply 57257 of 59576, by douglar
I bought 25 DIP 20 RAM chips from China off ebay. Allegedly Siemens HYB514256B-60
Holy remarks! 23 out of 25 seem to work at the expected speed, but I wish I knew what the original markings were.
Sorry about the AI wiggles in the picture. Can't quite figure out how to turn that off.
The attachment Chips.jpg is no longer available
Still, at $0.75 a chip including tax and shipping and failures, it's hard to complain when it works.
Reply 57258 of 59576, by Archer57
Aand it's alive:
The attachment 1650pro_2001.jpg is no longer available
The attachment 1650pro_2001_temp.jpg is no longer available
The attachment 20250730_001149_cutD.jpg is no longer available
The attachment 20250730_001128_cutD.jpg is no longer available
Still need to clean the flux, but wanted to test it first...
This felt like brain surgery, waaaay out of my comfort zone, but doable now that i have proper size caps.
Cooler is kind of junk, stays at 100%, noisy and still 60C in single 3dmark run on open stand...
Also knowing which driver is actually functional helps a lot to not waste time with that at least....
Reply 57259 of 59576, by Stesch
douglar wrote on 2025-07-29, 14:15:
I bought 25 DIP 20 RAM chips from China off ebay. Allegedly Siemens HYB514256B-60 […]
Nice! But I wonder why they always remove the original markings even when the chips fullfill the speed rating they print on them? It's the same with Is61C1024 chips from China, at least the -15 and -20 marked ones, they work fine (just sometimes, some few chips will be dead on arrival) but always have that shady scratchy surface with obviosly not original markings...
crayon eater (but only the tasty ones)
