Reply 57660 of 58622, by RandomStranger
Picked up some external drives.
A YD-8UN10 USB floppy drive and a Buffalo DVSM-PC58U2V USB optical drive.
Mainly to use it with modern laptops and old thin clients.
The attachment IMG_20251021_124138.jpg is no longer available
Reply 57661 of 58622, by Susanin79
Two LOGI motherboards from the scrapyard
Picked up two not-so-common LOGI branded boards today — an XT and a 286. Both have clearly “seen things,” but I’m optimistic they can be brought back to life.
Reply 57662 of 58622, by Ozzuneoj
Susanin79 wrote on 2025-10-21, 14:49:
Those are so cool looking! I have never seen a white PCB motherboard from either of those eras. In fact, I don't recall seeing white motherboards until maybe the Socket 478 era when Soltek started doing it.
Reply 57663 of 58622, by Nexxen
Please open a thread fro these. Can't wait to see what works.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 57664 of 58622, by douglar
Ozzuneoj wrote on 2025-10-21, 15:06:
They have a really striking look, that's for sure. Are you going to keep the non-standard leading edge style power connector or will you put in a P8 & P9 ?
Reply 57665 of 58622, by Susanin79
douglar wrote on 2025-10-21, 15:46:
Not sure, may be temporary replace them and return back when boards would be repaired.
Reply 57666 of 58622, by Susanin79
Nexxen wrote on 2025-10-21, 15:17:
This would be a good idea. Will keep you posted.
Reply 57667 of 58622, by Ozzuneoj
Susanin79 wrote on 2025-10-21, 16:03:
This probably goes without saying, but double check the pinout. That connector could use a totally different pinout than a standard P8+P9.
Reply 57668 of 58622, by Susanin79
Ozzuneoj wrote on 2025-10-21, 16:15:
Of course, I will trace the pins with the ISA slot power pins, just not to burn something else)
Reply 57669 of 58622, by PcBytes
Another peculiar board in my collection. AM2NF3-VSTA.
Reply 57670 of 58622, by sunkindly
I bought a Socket 7 board with a Cyrix 6x86 already with it...not sure yet if it's going to replace the Socket 3 / 5x86 or await its own case. It supports 2.8V and dual voltage, would it theoretically work with a 2.9V Cyrix MII? Officially it supports up to a Pentium MMX 200 but there's not much on the board itself. Either way, I think figuring out what I want for a mid 90s build has been the most difficult of them all.
SUN85: NEC PC-8801mkIIMR
SUN92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN97: QDI Titanium IE | Pentium MMX 200MHz | Tseng ET6000 | SB 16
SUN00: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
Reply 57671 of 58622, by PC@LIVE
sunkindly wrote on 2025-10-21, 18:40:
I'm currently working on a socket 7, MB ACORP A-5VIA3P chipset VIA VPX, CPU Cyrix MII-333 (3.5X 75), you can see it on my page on MB tests, it's not the first Cyrix I have, but it's the last one I built, let's say I don't mind, but personally I prefer AMD K6 CPUs, especially those with integrated L2 cache.
Theoretically you could put any S.7 CPU on it, using an interposer, realistically you can only if the regulators are switching, while with linear ones, it is better not to exceed 200 MHz, or at most 233 MHz, which for a Cyrix is equivalent to a MII-266 or 300.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 57672 of 58622, by sunkindly
PC@LIVE wrote on 2025-10-21, 20:03:
Ah! I compared ours and unfortunately this board only supports up to a 3x multiplier and 66MHz FSB. It has a 512KB cache on stick with it which is interesting. It's all good though, I'm not really seeking performance moreso something unique (and therefore some self-imposed suffering haha). I was thinking about Super Socket 7 but it'd overlap a little too much with Slot 1 which I already have.
Reply 57673 of 58622, by bjwil1991
Bought some hardware for my IBM PC Portable 5155:
Extended RAM card
JoyClock (Joystick + RTC) card
SAAYM sound card
XT-SD card adapter (XT-IDE)
And some PITs for my 5150 - Intel P8253-5, AMD P8253-5, and NEC D8253-5 since I think the original one is actually dead.
The attachment Screenshot 2025-10-21 235404.png is no longer available
The attachment Screenshot 2025-10-21 235446.png is no longer available
The attachment Screenshot 2025-10-21 235511.png is no longer available
Reply 57674 of 58622, by PC@LIVE
sunkindly wrote on 2025-10-22, 02:04:
Ok
Well it seems strange to me that you can't use the multi 3.5X, to do 233 MHz (more than 200 MHz), just set 1.5X and the rest is done by the CPU, at least with 6X86MX and MII it works like that.
If, on the other hand, it is not possible to use CPUs faster than 200 MHz, it is possible that it depends on linear regulators, and the older S.7s are all like that.
Usually in motherboards with Intel chipsets, I don't recommend the Cyrix, VIA or other chipsets instead, are more suitable for creating that particular PC, although perhaps the final result could be quite slow, for a 200 MHz PC or a little more.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 57675 of 58622, by sunkindly
PC@LIVE wrote on 2025-10-22, 07:49:
Ok Well it seems strange to me that you can't use the multi 3.5X, to do 233 MHz (more than 200 MHz), just set 1.5X and the rest […]
Ok
Yeah, it’s an Intel 430VX so I’ll probably skip the experimenting with this one and throw in a Pentium.
Reply 57676 of 58622, by H3nrik V!
Ok
Most Pentium MMX (well at least ALL 233) interprets 1.5x multi as 3.5 since there is no separate setting for 3.5 ...
Reply 57677 of 58622, by nuno14272
BEAUTIFULL !!!!
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 57678 of 58622, by nuno14272
BEAUTIFULL !!!!
1| 386DX40
Reply 57679 of 58622, by Susanin79
Here it is 😀
