Reply 59260 of 59261, by Tiido
- l33t
You need a good motherboard too, with CPU and cache in the immediate vincinity of the VLB slot. Physical layout matters a lot and a board with cache on one side of board and VLB on another with CPU in the middle is unlikely to give stable performance since the capacitance and inductance from all that length of traces will get in the way of signal integrity.
I have actually not had troubles at all running several VLB cards at 40MHz without wait states, but 50MHz has required some cherry picking.
