New CDROM ODE Emulator using Raspberry Pi
Reply 60 of 79, by DangerMouse
danifunker wrote on 2025-12-21, 13:16:
Ok, have you tried re-assigning some of the GPIO buttons because of the known conflict between the i2s audio PINs and this HAT?
Where can I read about this or how can I reassign it?
HDMI + waveshare HAT works fine. I reported this above.
Reply 61 of 79, by DangerMouse
Perhaps you meant changing the configuration by setting the resistors on the HAT?
Reply 62 of 79, by DangerMouse
It looks like there's no easy way to make the Waveshare HAT and I2S work together. Too bad. Both hardware and software modifications are needed to get them working together.
Reply 63 of 79, by danifunker
No, don't change the resistors on the HAT, we don't support the other modes on the HAT. I've tried that before.
One user in the discord recommended the following settings to use in config.txt:
[sh1106]
backlight_pin=0
reset_pin=25
spi_cpol=0
spi_cpha=0
spi_clock_speed=24000000
spi_chip_select=0
button_up=6
button_down=5
button_ok=20
button_cancel=16
button_key3=0
button_left=0
button_right=0
button_center=0
dc_pin=24
"Up on the joystick is up, left is down middle button is ok and bottom button is cancel. Here is a copy of the config.txt for reference."
Try this and let me know what happens.
The issue is that the waveshare HAT has some GPIO in the same PINs as the standard i2s connections.
Reply 64 of 79, by DangerMouse
Adding this to config.txt didn't help, nor did adding it to config-options.txt. The controls weren't remapped, and the buttons still work as before.
Reply 65 of 79, by danifunker
Oh sorry, this has to go into config.txt, but you also have to update displayhat under [usbode]
displayhat=sh1106
This should allow the new remapping to work.
Reply 66 of 79, by DangerMouse
Thank you very much, it works perfectly now!
Reply 67 of 79, by DangerMouse
MDF/MDS images are not read correctly in DOS (garbage instead of a list of files), but cdaudio plays good. It works fully correctly in WinXP, but I haven't tested it in Win98. Tested from RC3 to the latest build on several different images.
Reply 68 of 79, by danifunker
I never tested MDS/MDF files in MSDOS but did in Windows 98 they seemed to work fine. It's possible that subchannel support doesn't work correctly in MSDOS. Are there any specific MSDOS games you have that needs MDS/MDF support?
Reply 69 of 79, by DangerMouse
danifunker wrote on 2025-12-22, 11:50:
There are no such games, and the format can be converted if necessary. I don't see the point in fixing the error. I actually noticed a bug by accident: the same image was in different formats for the cdaudio test, so at first I thought the image file was corrupted.
Please also check if logging is disabled completely. I had it set to 0 in the settings in one of the builds, but the logs were still written to the file.
Reply 70 of 79, by danifunker
In the web interface, you can try to clear out the log file path. I think that will stop the logging. Let me know if that works for you.
Reply 71 of 79, by DangerMouse
danifunker wrote on 2025-12-22, 15:57:
The web interface doesn't save an empty log file name. I removed it from config.txt and no more logs are written.
Reply 72 of 79, by DangerMouse
Assembled with a volume control for cdaudio in DOS/VXD drivers.
Reply 73 of 79, by danifunker
Oh very cool! Would you mind to show the schematics for the volume control?
Reply 74 of 79, by DangerMouse
danifunker wrote on 2026-02-04, 08:51:
10k (B103) 5pin potentiometr.
The inputs and outputs can be reversed if volume adjustment is required by rotating in the opposite direction.
Reply 76 of 79, by Rawit
DangerMouse wrote on 2025-12-22, 11:56:
Perhaps XS and GT Racing 97 need this.
YouTube
Reply 77 of 79, by DangerMouse
When's the final release of the new version - not the RC?
Reply 78 of 79, by danifunker
I want to get USB CDROM booting working and multi-bin cue support before releasing a "final" version. I did recently push an update, please try it out.
Reply 79 of 79, by DangerMouse
danifunker wrote on 2026-05-27, 21:37:
btw...
I tested it on socket 775 with an older version - bootable CD-ROM images booted just fine, same as on slot 1 motherboards, though I didn't experiment much with those.
