Reply 60 of 70, by Nicolas 2000
I didn't find an option to disable the onboard gameport in BIOS. The mobo manual shows one, my BIOS doesn't have it. While there, I did disable the two serial ports and the parallel port as I'm not using those anyway. I've also disabled modem related stuff.
The gameport problem remains: the joystick section of control panel says that it is not configured well and to check device manager; device manager of course says it is functioning well...
In games I see that the joystick is actually responsive, it's just not calibrated. And I can't calibrate it because control panel thinks my gameport is not set up properly. Oh joy.
Anyway, I think I'll redo the entire Audigy2 installation, this time following the Vogons guide (just not starting from a fresh 98 install, I'll just uninstall everything Audigy related in software and device manager). That might solve this issue and should give me sound in DOS, which would be a solution for the Slicks n Slide problem in Windows.
