Reply 60 of 100, by polpo
- Member
Rabanik wrote on 2026-02-14, 08:38:Ok. So is it possible to swap the CS/S/M header by the SPDIF MPC and put CS/S/M header behind it? Or use 3-row 's CS/S/M pin h […]
polpo wrote on 2026-02-14, 07:09:Sorry, that is not possible with the current design. The PCB is in an enclosure that takes up width, and the Berg connector needs to have room to allow for the overhang of the mating connector over the sides.
Or use 3-row 's CS/S/M pin header. Thisway you can reach other 2.54mm for the overhang of the power supply connector.
I am sorry that I bother you with it. I really like your solution the most of all ODEs
because of everything is placed on a single PCB and with a nice 3.5" panel...
I think I am not alone who desires for digital outputs on your PicoIDE.
The hardware is finalized as it is heading into production so there will be no changes for this version. Like I said the “ext btn” pin header is present and it’s likely possible to get SPDIF output on it. You’ll just have to use a DuPont cable instead. But I am focused on stable drive emulation first before considering adding SPDIF output on those pins. Of course once the source is released I welcome the community to help out with implementing things like that, or even designing variants with different form factors.
