Reply 60 of 65, by Roman555
AlexZ wrote on 2026-07-17, 08:27:...
In 64bit mode, I would definitely use 3GB RAM. The best bet is buying 3x registered ECC DDR 333 and run it at 400 (should work at 3 3 3 8 ). Server RAM is often very cheap as people fear it and nobody buys retro servers. If the price is about 5€ per stick then it's worth it. Registered RAM is in general better if many memory sticks are used, like 3 with s754 or 4 with s939.
It's pity but s754 mainboards usually won't support registered ECC DDR, especially nForce based. I really don't know the main reason why manufactures so limited their s754 products.
Maybe because of many s754 steppings won't support it. The Venice E9 90nm does.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
