Reply 60 of 80, by ntalaec
Falcosoft wrote on 2026-08-16, 15:53:1. If I understand you correctly Duke Nukem 3D works for you perfectly without MSKVBEF7 and 'shows severe graphical issues' with MSKVBEF7 loaded?
That is correct. I can run all the VESA resolutions up to 800x600. But I can't see any difference between 640x480 and 800x600 besides framerate (typing DNRATE during game). When MSKVBEF7 is loaded, there is a performance loss (10% or so) and 800x600 resolution has graphical issues. Others run fine.
Thanks for updating VSYNCFIX. 640x400 now works in Links 386 but it does not resize to full screen. I get a black bar at the bottom which fills the 80 pixels missing from 640x480 resolution. I was expecting to fill the entire screen and get an almost correct aspect ratio (16:9 from my screen vs 16:10 ratio using 640x400). It's possible to fill the screen? I have the same problem in Windows 3.11 using VBESVGA driver.
I get full screen with EGA 640x400 games from here: https://lilura1.blogspot.com/2022/02/IBM-PC-S … x400-games.html without loading any utility.
Three suggestions for VSYNCFIX:
-Add unload support. It's only 1 KB but I only use it for Links 386.
-Do not allow more than one instance.
-Add this utility to your web (https://falcosoft.hu/dos_softwares.html). It's difficult to find it here, buried in a forum.
