Mechwarrior 2 Decomp/Recomp
Reply 60 of 61, by MalekBrood
Mikeyy00 wrote on Today, 02:34:
MalekBrood wrote on Today, 02:23:
Screenshot would be super helpful too.
I suppose a screenshot would help! This was taken using Vulkan but the normal DX12 version as the same issue when and using Enhanced Renderer and Titanium textures. The original textures shows the skybox normally, however the Clan Jade Falcon dropships have the Clan Wolf logo on them. I have attached a screen shot of this too.
Hope this helps and keep up the great work, it's amazing what you've done here and with GBL too. I'm looking forward to Mercs next! 😄
1.1.4 should fix the logo. The skybox is probably the wrong PRJ file in your folder. Under the Titanium folder, the MW2.PRJ file should be the 16 bit version roughly 64MB, if it's smaller, it's the 8bit one from Titanium. Replace it with the correct one. It also needs the Skygnd.PAR file thats about 25kb.
[/quote]
I've attached a screenshot of my Titanium folder, from what you said above, it looks fine to me. I did use the farpatcher on mw2.prj to increase the view distance, I wonder if that could have caused this?
[/quote]
It may have? The port is based on stock files from DOS/Titanium.. could you duplicate the folder and replace the PRJ 's with non modified as a test? The PRJ should be 64MB too.. not 62.
[/quote]
Mmmm...I'm a bit confused now because I have tried 3 different Titanium versions that I managed to find on Internet Archive (I only own the dos/3Dfx physical CD). All three have the same MW2.PRJ file size of 62,524 KB (in the 16Bit folder on the CD). I'm not sure which or where to find the version that has the 65mb version of the MW2.PRJ. Any ideas on where I can get my hands on it?
Reply 61 of 61, by ubertrout
MalekBrood wrote on Today, 14:34:
I don't have it in front of me ironically, but could it be the one included with the PowerVR version?
